Relay board for Z-wave ?
Postby Menno » Tue Dec 03, 2013 5:12 pm
Are there Relay-board with 8 outputs, or even better, I/O boards with 8 in- and 8 outputs for Z-Wave?
Menno
Re: Relay board for Z-wave ?
Postby Henk » Tue Dec 03, 2013 9:58 pm
I was searching for a similar piece of hardware but it is not yet on the market .
Current offers of Zwave I/O are expensive like the binary sensor of Fibaro for input or the double relay output module for output ...
I'm considering using an Arduino as an I/O frontend plenty of I/O including analog and even some preprocessing is possible . The Arduino will communicate by an Ethernet module and using the Virtual Device option in the HC2 to poll and push I/O .
The cost will be less than a binary sensor module ..... but right now lack of knowhow how to write the LUA code . It would be nice if there is a Zwave shield available for the Arduino .... ...
As an example I develop based on an Arduino a sophisticated sunscreen controller including wind/sun/rain sensor it would be nice if this can communicate with the Zwave world ...
Any volunteers ?
Henk
Henk
Postby nullx8 » Wed Jan 29, 2014 6:18 pm
i faced the same problem.
solved it with a raspberry and pi-face module.
8 in 8 outs (2 relays already on board) added 2 temperature sensors ... everything working like a charm with micasaverde controller and a tiny pyton app on the PI ..
on top of that it does also datalogging onto a mysql database
nullx8
Return to Z-Wave Forum
