Compatible with USB Aeon V2
Dylantje
Post by Dylantje »
I have a usb Aeon V2.
Which Zwave devices work well with this USB stick?
I have several sensors that are yet again not work on this USB.
Thanks
wwolkers
Re: Compatible with USB Aeon V2
Post by wwolkers »
Most devices should just work.
What devices do you have that don't work? Do they work with another USB stick?
Also, what software are you using for Z-Wave?
Dylantje
Post by Dylantje »
I use Domoticz.
With Aeon usb V2
Not working:
Vision Pir
Everspring pir
Philio 4 in 1
The only one wath good works when it is alone in the netwerk.
Is the: Aeon Multisensor
When i include a other of these 3, the Zwave network is going to a problem...
Runs on RPi
Phaeton
Post by Phaeton »
I have problems with the everspring. It batterypowered and i never got it to work good with aeon labs stick en homeseer. Others i dont know. Are they zwave certified?
groeten,
wwolkers
Post by wwolkers »
Domoticz uses the openzwave library, so the problem is most likely there.
You could check if there is a zwave logfile, or even zwcfg.xml file, most probably the 3 devices you have are not yet fully supported by openzwave.
Also, since these are battery operated devices, they will not get detected properly until woken up at least once.
You could add the device , and then check the manual to see how you do a manual wakeup, see if that helps.
Dylantje
Post by Dylantje »
And is there no option to add this sensor to openzwave?
Or to my library so it is working lokal?
Return to “Z-Wave Forum”
