JeeNode KaKu receive how?
Moderator: Mdamen
pvgent
Post by pvgent »
I have the following components:
- JeeNode v6
- OOKPlug 443Mhz
- Kaku AWST 8802 (double switch)
- Kaku AWST 6000 (motion detector)
- Kaku ACM 300 (built-in Switch used for hallway light)
What i want is to receive/decode de signals send from de Kaku AWST 8802 en Kaku AWST 6000
I tried OOKRelay2 and the OOKPlug on P1, P2, P3 en P4 but no result.
Can someone point me in the right direction.
airox
Re: JeeNode KaKu receive how?
Post by airox »
Checkout this topic on the jeelabs forum: http://forum.jeelabs.net/node/348
It has the KAKU A-type support.
pvgent
Post by pvgent »
@airox, thanks for the reply, i will check it.
pvgent
Post by pvgent »
Tried it, but still no progress, i bought a second OOKPlug to be sure. Soldered the two jumpers (resistor and power +3v), put an antenna on the receive board. Tried the OOKPlug on all 4 Ports on the JeeNode with no luck, anyone suggestions?
airox
Post by airox »
You're not getting any signal or whatsover? You could try some guys at http://forum.jeelabs.net/, they're into the jeelabs and OOKplug stuff.
