ELV MAX! protocol description
Forum about the home automation suites by ELV
Moderator: jrkalf
Re: ELV MAX! protocol description
Postby jesperlykke » Tue Mar 29, 2016 6:54 am
A quick question. Is there an interest in MQTT server for MAX! Home automation? Please mail me at mailbox@dmitry-kazakov.de if you want it the new release.
I will send you a mail, regarding this!
good work btw.
Rgds: Jesper
jesperlykke
Postby Phaeton » Tue Mar 29, 2016 7:01 am
yes, interested! still have some elv lying around and not used. MQTT would help me to add it to my system easy.
groeten,
Phaeton
Postby MarnixT » Thu Apr 07, 2016 11:18 pm
yes, would also interest me a lot!
MarnixT
Postby dmitry-kazakov » Thu Apr 14, 2016 6:17 pm
OK, MAX! home automation 1.3 is released:
http://www.dmitry-kazakov.de/ada/max_ho ... mation.htm
Changes to the previous version:
- MQTT server added;
- LAN discovery by default scans all known interfaces;
- Settings page allows explicit setting of the host address to scan or cube address to connect.
The section 3 describes the MQTT topics to get thermostat data. Also, thermostats can be controlled by publishing special topics on the server.
dmitry-kazakov
Postby hasan » Tue Oct 18, 2016 7:15 pm
Hi Dmitry,
I would like to use you application on my RPi where Domoticz is also installed. Is graphical support needed for your application?
Spasibo
hasan
Postby dmitry-kazakov » Thu Oct 20, 2016 8:59 pm
Yes, you need X11 and GTK3. These come with Debian and Fedora RPI distributions by default. It does not mean you have to have a monitor attached to the RPI's HDMI output. It is also possible to run a GUI application on start-up. E.g. see https://debian-administration.org/artic ... n_X_starts
dmitry-kazakov
Postby dmitry-kazakov » Mon Nov 21, 2016 6:28 pm
The new version of MAX! home automation 1.6 is released.
dmitry-kazakov.de/ada/max_home_automati ... mation.htm
It fixes the following bugs and issues:
  • Monitoring radio band duty cycle was added;
  • Commands that control thermostats are serialized and monitored for failures;
  • Cube radiator thermostats configuration save and restore added;
  • Thermostat schedule and parameters upload diagnostics added;
  • Offset temperature can be set negative;
  • HTTP server request documentation get-set_temperature changed to get-set-temperature;
  • Save file dialogs changed to ask override confirmation;
  • Bug fix in HTTP server that prevented querying the thermostat's measured temperature;
  • Valve position is correctly reported;
  • Thermostat parameters and schedule optimized to minimize RF traffic;
  • Documentation extended with instructions how to run the application remotely or in the headless mode.
Supported targets are x86: Windows, Linux Debian/Fedora/CentOS. ARMv7 (e.g. RPI 2): Linux Debian/Fedora
dmitry-kazakov
Postby Bwired » Mon Nov 21, 2016 10:26 pm
nice update!
perhaps you could also make a compiled ubuntu 16.04 version :)
Postby blb » Tue Nov 22, 2016 12:24 am
thanks for the new version! most appreciated, especially the save/restore thermostats config.
Bernard
blb
Postby dmitry-kazakov » Tue Nov 22, 2016 6:40 pm
Bwired wrote:nice update!
Debian packages should work for Ubuntu.
AFAIK, Ubuntu 6.10 has finally got GCC-6. So there would be no need as before to upgrade to the system to testing packages in order to be able to install Debian packages.
dmitry-kazakov
Postby fensoft » Wed Dec 07, 2016 2:34 pm
I've made this: https://github.com/fensoft/maxcube
I'm using it (as a jeedom plugin, with ~50 other people) for several month.
There is nothing to manage the calendar but at least everything else is working.
fensoft
Postby dmitry-kazakov » Wed Feb 22, 2017 6:27 pm
The new version of MAX! home automation 1.8 is released.
The new version fixes some bugs, adds E-mail reporting of low batteries and long-term data logging into an ODBC database (practically any database) or SQLite single-file database.
dmitry-kazakov
Postby dmitry-kazakov » Wed Apr 19, 2017 5:34 pm
The new version of MAX! home automation 1.9 is released
- MQTT on WebSocket support added;
- The MQTT server's topic names have the leading '/' removed because some MQTT clients reported having troubles with names starting with '/';
- When controlled over HTTP or MQTT the target temperature can be specified to be airing, comfort, and eco according to the thermostat settings;
- The thermostat address can be omitted when in control commands over HTTP or MQTT. In this case the command applies to all thermostats;
- HTTP access control (CORS) support added;
- HTTP server JSONP support added.
dmitry-kazakov
Previous
Return to FS20, FHT, ESA and ELV
cron
