ELV MAX! Protocol-Reader in PHP
Forum about the home automation suites by ELV etc
Moderator: jrkalf
Postby mega » Sat Oct 29, 2011 5:41 pm
since 2 Days I have this Max-System and worked on a PHP-based-decoder.
To use this script, change the IP to your Cube-IP and get it run on a NAS, HomeServer or XAMPP.
It may also work with portforwarding from the Internet. but that is not tested.
Maybe we get our own webinterface that also can be used on a NAS/Homeserver or so.
To use this script, change the IP to your Cube-IP and get it run on your NAS, HomeServer or XAMPP.
Or use it online, open/forward a port to the cube.
The Script:
http://mega-nas.de/max/
Max! 1 x Cube, 4 x Thermostat, 1 x Wandthermostat,1 x Fensterkontakt
mega
Re: ELV MAX! Protocol-Reader in PHP
Postby mega » Wed Nov 02, 2011 1:42 pm
It should now read and decode all known data and puts them in arrays.
Next step is a webinterface to present the data.
Is anyone else working with/on this?
mega
Postby wwolkers » Fri Nov 04, 2011 10:49 am
I've instlled it on my local server to take a look at it. Works for me, but I haven't had any chance to do anything more with it.
wwolkers
Postby mega » Thu Dec 01, 2011 6:04 pm
Script is changed to also read the wall-thermostat.
mega
Postby Petr » Thu Dec 01, 2011 8:03 pm
I am thinking about the Max! Cube for my new central heating.
I really like the concept and the thermo-heads with big display and buttons.
But I see all (almost negative or embarrassed) postings here and on the ELV forum and I am little bit sceptical about the functionality.
I have following questions:
  • what is the main goal of the "Max! Cube <=> ELV server" communication protocol recognition (I mean do you think it is possible to use the protocol for our own application to control the Max!Cube?)
  • what about the "Max! Cube <=> EQ3 thermo head" wireless protocol. Are there any attempts to decode and understand it (so it is possible to control it via CUL or CUN [url]see http://www.busware.de[/url] for example)?
  • are there any attempts to integrate the Max! with fhem? http://fhem.de/
Regards
Petr
Petr
Postby mega » Thu Dec 01, 2011 9:04 pm
1. With the communication protocol recognition it will be possible to make a own interface or integrate to other interfaces/apps/....
2. this seems to not be needed because the Cube can be used with LAN .
3. not by me, but it should be possible.
You may buy and test the system. some users have problems, others not.
mega
Postby Rainer » Wed Oct 17, 2012 4:55 pm
I have installed this on my local webserver and it works.
I use firmware 1.3.5 on my max! cube.
The port is not 80 anymore but 62910 works fine.
Has anybody worked a bit on this?
Does anyone know about changing values?
Rainer
Rainer
Postby mega » Sun Jan 06, 2013 10:36 am
Here is the complete interface, includes sending:
http://www.mega-nas.de/max/max.zip
This is discontinued! It may not work on newer firmware.
mega
Postby ceemjay » Mon Jan 07, 2013 9:00 am
Hi Mega
Thanks for your contributions.
I have only just got my MAX! stuff, found this thread yesterday and downloaded your code, so am a real beginner. But what does "This is discontinued!" mean exactly? You are no longer developing it or MAX! has changed in some way??
Thanks
ceemjay
ceemjay
Postby mega » Mon Jan 07, 2013 7:01 pm
I do not devolop more for that.
Max is too scrap, i now have homematic (since some months)
mega
Postby pjakobs » Sun Nov 09, 2014 11:48 pm
I see that I'm late to the party, but I just bought the Max! stuff. So far, no complaints, but not being able to access it from the shell / through an API was not acceptable. This is why I searched for a scripted solution and found this code. I have started to refactor the reader.php script to ultimately turn it into a RESTful API. Here's my first take on it:
<?php
// All Max! Commands
    DEVICE_LIST = 'L';
    CONFIGURATION = 'C';
    METADATA = 'M';
   SET_CREDENTIALS = 'B';
    GET_CREDENTIALS = 'G';
    SET_REMOTEACCESS = 'J';
    SET_USER_DATA = 'P';
    GET_USER_DATA = 'O';
    INCOMING_HELLO = "H:";
    INCOMING_FAILURE = "F:";
    INCOMING_DEVICE_LIST = "L:";
    INCOMING_CONFIGURATION = "C:";
    INCOMING_METADATA = "M:";
    INOMING_NEW_DEVICE = "N:";
    INCOMING_ACKNOWLEDGE = "A:";
    INCOMING_ENCRYPTION = "E:";
    INCOMING_DECRYPTION = "D:";
    INCOMING_SET_CREDENTIALS = "b:";
    INCOMING_GET_CREDENTIALS = "g:";
    INCOMING_SET_REMOTEACCESS = "j:";
    INCOMING_SET_USER_DATA = "p:";
    INCOMING_GET_USER_DATA = "o:";
    INCOMING_SEND_DEVICE_CMD = "S:";
    OUTGOING_URL = "u:";
    OUTGOING_INTERVAL = "i:";
    OUTGOING_SEND = "s:";
    OUTGOING_METADATA = "m:";
    OUTGOING_INCLUSION_MODE = "n:";
    OUTGOING_CANCEL_INCLUSION_MODE = "x:";
    OUTGOING_MORE_DATA = "g:";
    OUTGOING_QUIT = "q:";
    OUTGOING_ENCRYPTION = "e:";
    OUTGOING_DECRYPTION = "d:";
    OUTGOING_SET_CREDENTIALS = "B:";
    OUTGOING_GET_CREDENTIALS = "G:";
    OUTGOING_SET_REMOTEACCESS = "J:";
    OUTGOING_SET_USER_DATA = "P:";
    OUTGOING_GET_USER_DATA = "O:";
    OUTGOING_SEND_DEVICE_CMD = "s:";
    OUTGOING_RESET = "a:";
    OUTGOING_RESET_ERROR = "r:";
    OUTGOING_DELETE_DEVICES = "t:";
    OUTGOING_SET_PUSHBUTTON_CONFIG = "w:";
    OUTGOING_GET_DEVICE_LIST = "l:";
    OUTGOING_SET_URL = "u:";
    OUTGOING_GET_CONFIGURATION = "c:";
    OUTGOING_TIME_CONFIG = "v:";
    OUTGOING_SEND_WAKEUP = "z:";
// Max! Date encoding
    9D0B    1001110100001011
            MMMDDDDDM YYYYYY
            100     0        = 1000b  = 8d  = month
               11101         = 11101b = 29d = day
                      001011 = 1011b  = 11d = year-2000
    868B    1000011010001011
            MMMDDDDDM YYYYYY
            100     1         1001b = 9d  = month
               00110           110b = 6d  = day
                      001011  1011b = 11d = year-2000
echo "<pre>";
// Uncomment the follwing 2 lines
$host = "192.168.35.64"; // Your Cube-IP or hostame Here!
$port = "62910";
// open connection
$fp = @fsockopen($host, $port, $errno, $errstr, 5);
if (!$fp)
   switch($errno)
      case 111:
         die("Local software running - ".$errstr);
         break;
      case 113:
         die("No Connection - ".$errstr);
         break;
      default:
         die("Connection error - ".$errno." - ".$errstr);
         break;
socket_set_blocking($fp,false);
sleep(1);
$finished = 0;
$now = time();
// read from cube
$buff = "";
while (!feof($fp) && time() < $now+20 && $finished == 0)
   $line = fgets($fp);
   if (strpos($line,"L:") !== false) $finished = 1;
   if ($line != "")  $buff .= $line."\n";
   //sleep(1);
fclose($fp);
// fail
if ($finished != 1) die("Could not find an L record");
ob_start();
$arr = explode("\n\n",$buff);
print_r($arr);
echo '<hr />';
foreach ($arr as $v)
   $p_type=substr($v,0,2); //packet type
   switch($p_type)
      case "H:":
         Initial "Hello"
         H:KHA0008979,0744a8,0113,00000000,576c1768,18,32,0e0b09,0a08,03,0000
         IEQ0123456  Serial number
         00b3b4      RF address, hexadecimal
         0102        Firmware version, 1.0.2
         00000000    ?
         355df98a    ?
         03          ?
         32          ?
         $arr2 = explode(',',substr($v,2,strlen($v)));
         //$str = base64_decode($arr2[2]);
         $data["sys"]["SerialNumber"] = $arr2[0];
         $data["sys"]["RFAdress"] = $arr2[1];
         $data["sys"]["Firmware"] = $arr2[2];
         $data["sys"]["1?"] = $arr2[3]; //00000000
         $data["sys"]["HTTP-ConnID"] = $arr2[4];
         $data["sys"]["2?"] = $arr2[5];
         $data["sys"]["3?"] = $arr2[6]; //31
         $data["sys"]["Date"] = hexdec(substr($arr2[7],4,2)).".".hexdec(substr($arr2[7],2,2)).".".hexdec(substr($arr2[7],0,2));
         $data["sys"]["Time"] = hexdec(substr($arr2[8],0,2)).":".hexdec(substr($arr2[8],2,2));
         $data["sys"]["Timestamp"] = mktime(hexdec(substr($arr2[8],0,2)),hexdec(substr($arr2[8],2,2)),0,hexdec(substr($arr2[7],2,2)),hexdec(substr($arr2[7],4,2)),hexdec(substr($arr2[7],0,2)));
      break;
      case "M:":
         Metadata
         M:00,01,VgICAQVCw7xybwx6FQIKV29obnppbW1lcgx6PgUDDM8AS0VRMDgwODIzOBBXYW5kdGhlcm1vc3RhdCAxAQEMehVLRVEwNzIwMDA4EkhlaXprw7ZycGVyIHJlY2h0cwEBDHo+S0VRMDcxOTk2OAtIZWl6a8O2cnBlcgIEDK83S0VRMDg0MTI2NA5GZW5zdGVyIHJlY2h0cwEEDLI1S0VRMDg0MjExMgdGZW5zdGVyAgE=
         00000000  56 02 02 01 05 42 c3 bc  72 6f 0c 7a 15 02 0a 57  |V....B..ro.z...W|
         00000010  6f 68 6e 7a 69 6d 6d 65  72 0c 7a 3e 05 03 0c cf  |ohnzimmer.z>....|
         00000020  00 4b 45 51 30 38 30 38  32 33 38 10 57 61 6e 64  |.KEQ0808238.Wand|
         00000030  74 68 65 72 6d 6f 73 74  61 74 20 31 01 01 0c 7a  |thermostat 1...z|
         00000040  15 4b 45 51 30 37 32 30  30 30 38 12 48 65 69 7a  |.KEQ0720008.Heiz|
         00000050  6b c3 b6 72 70 65 72 20  72 65 63 68 74 73 01 01  |k..rper rechts..|
         00000060  0c 7a 3e 4b 45 51 30 37  31 39 39 36 38 0b 48 65  |.z>KEQ0719968.He|
         00000070  69 7a 6b c3 b6 72 70 65  72 02 04 0c af 37 4b 45  |izk..rper....7KE|
         00000080  51 30 38 34 31 32 36 34  0e 46 65 6e 73 74 65 72  |Q0841264.Fenster|
         00000090  20 72 65 63 68 74 73 01  04 0c b2 35 4b 45 51 30  | rechts....5KEQ0|
         000000a0  38 34 32 31 31 32 07 46  65 6e 73 74 65 72 02 01  |842112.Fenster..|
         000000b0
         0001 56 -> ?
         0002 02 -> ?
         0003 02 -> RoomCount
         0004 01 -> RoomID
         0005 05 -> RoomNameLength
         0006 42 C3 BC 72 6F -> RoomName
         000A 0C 7A 15 -> RF Address
         000D 02 -> RoomID
         000E 0A -> RoomNameLength
         000F 57 6F 68 6E 7A 69 6D 6D 65 72 -> RoomName
         0018 0C 7A 3E -> RF Address
         OO1B 05
         Room:
         Description        Startpos    Length      Example Value
         Room id            00          1           1
         Room name length   01          1           0A
         Room name          02          variable    Hobbykamer
         Address(?)                     3           003508
         Device:
         Device type        00          1           1
         Address            01          3           003508
         Serial Number      04          10          IEQ0109125
         Name length        0E          1           0C
         Name               0F          variable    Thermostat 1
         Room id                        1           01
          $arr2 = explode(',',$v);
         echo $arr2[0].','.$arr2[1]."\n".htmlentities($str)."\n";
         for($i = 0 ; $i <= strlen($str) ; $i++)
            echo dechex(ord(substr($str,$i,1)))." ";
         echo "\n";
         $pos = 0;
         $readlen =  1;
         $data["meta"]["?1"] = dechex(ord(substr($str,$pos,$readlen)))."";
         $pos += $readlen;
         $readlen =  1;
         $data["meta"]["?2"] = dechex(ord(substr($str,$pos,$readlen)))."";
         $pos += $readlen;
         $readlen =  1;
         $data["meta"]["RoomCount"] = dechex(ord(substr($str,$pos,$readlen)))."";
         $pos += $readlen;
         for($j = 1 ; $j <= $data["meta"]["RoomCount"] ; $j++)
            $readlen = 1;
            $RoomID = dechex(ord(substr($str,$pos,$readlen)))."";
            $data["rooms"][$RoomID]["RoomID"] = $RoomID;
            $pos += $readlen;
            $readlen = 1;
            $data["rooms"][$RoomID]["RoomNameLength"] = ord(substr($str,$pos,$readlen))."";
            $pos += $readlen;
            $readlen = $data["rooms"][$RoomID]["RoomNameLength"];
            $data["rooms"][$RoomID]["RoomName"] = htmlentities(substr($str,$pos,$readlen))."";
            $pos += $readlen;
            $readlen = 3;
            for($i = $pos; $i < $readlen+$pos ; $i++)
               $data["rooms"][$RoomID]["RFAdress(?)"] .= str_pad(dechex(ord(substr($str,$i,1))),2,"0",STR_PAD_LEFT)."";
            $pos += $readlen;
         $readlen = 1;
         $data["meta"]["DevCount"] = dechex(ord(substr($str,$pos,$readlen)))."";
         $pos += $readlen;
         0C  05 -> DevCount
         0D  03 -> DevType
         0E  0C CF 00 -> RFAddress
         21  4B 45 51 30 38 30 38 32 33 38 -> SerialNumber
         2B  10 -> NameLength
         2C  57 61 6E 64 74 68 65 72 6D 6F 73 74 61 74 20 31 -> DeviceName
         3C  01 -> RoomID
         for($j = 1 ; $j <= $data["meta"]["DevCount"]; $j++)
            unset($hilf);
            $readlen = 1;
            $hilf["DeviceType"] = dechex(ord(substr($str,$pos,$readlen)))."";
            $pos += $readlen;
            $readlen = 3;
               $hilf["RFAdress"] .= str_pad(dechex(ord(substr($str,$i,1))),2,"0",STR_PAD_LEFT)."";
            $pos += $readlen;
            $readlen = 10;
            $hilf["SerialNumber"] .= htmlentities(substr($str,$pos,$readlen))."";
            $pos += $readlen;
            $readlen = 1;
            $hilf["NameLength"] = ord(substr($str,$pos,$readlen))."";
            $pos += $readlen;
            //echo "debug === Device Name Length:".$hilf["NameLength"]."\n";
            $readlen = $hilf["NameLength"];
            $hilf["Name"] = htmlentities(substr($str,$pos,$readlen))."";
            $pos += $readlen;
            //echo "debug === Device Name:".$hilf["Name"]."\n";
            $readlen = 1;
            $hilf["RoomID"] = dechex(ord(substr($str,$pos,1)))."";
            $pos += $readlen;
            $data["rooms"][$hilf["RoomID"]]["Devices"][$j]["DeviceType"] = $hilf["DeviceType"];
            $data["rooms"][$hilf["RoomID"]]["Devices"][$j]["RFAdress"] = $hilf["RFAdress"];
            $data["rooms"][$hilf["RoomID"]]["Devices"][$j]["SerialNumber"] = $hilf["SerialNumber"];
            $data["rooms"][$hilf["RoomID"]]["Devices"][$j]["NameLength"] = $hilf["NameLength"];
            $data["rooms"][$hilf["RoomID"]]["Devices"][$j]["Name"] = $hilf["Name"];
            $data["rooms"][$hilf["RoomID"]]["Devices"][$j]["RoomID"] = $hilf["RoomID"];
      break;
      case "C:":
         Configuration
         C:0744a8,7QdEqAATAQBLSEEwMDA4OTc5AAsABEAAAAAAAAAAAP///////////////////////////wsABEAAAAAAAAAAQf///////////////////////////2h0dHA6Ly9tYXgtcG9ydGFsLmVxLTMuZGU6ODAvbG9va3VwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAENFVAAACgADAAAOEENFU1QAAwACAAAcIA==
         00000000  ed 07 44 a8 00 13 01 00  4b 48 41 30 30 30 38 39  |..D.....KHA00089|
         00000010  37 39 00 0b 00 04 40 00  00 00 00 00 00 00 00 ff  |79....@.........|
         00000020  ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff  |................|
         00000030  ff ff ff ff 0b 00 04 40  00 00 00 00 00 00 00 41  |.......@.......A|
         00000040  ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff  |................|
         00000050  ff ff ff ff ff 68 74 74  70 3a 2f 2f 6d 61 78 2d  |.....http://max-|
         00000060  70 6f 72 74 61 6c 2e 65  71 2d 33 2e 64 65 3a 38  |portal.eq-3.de:8|
         00000070  30 2f 6c 6f 6f 6b 75 70  00 00 00 00 00 00 00 00  |0/lookup........|
         00000080  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
         000000d0  00 00 00 00 00 00 43 45  54 00 00 0a 00 03 00 00  |......CET.......|
         000000e0  0e 10 43 45 53 54 00 03  00 02 00 00 1c 20        |..CEST....... |
         000000ee
         003508        RF address of the device
         Start Length  Value       Description
         00         1  D2          Length of data: D2 = 210(decimal) = 210 bytes
         01         3  003508      RF address
         04         1  01          Device Type
         05         3  0114FF      ?
         08        10  IEQ0109125  Serial Number
         12         1  28          Comfort Temperature
         13         1  28          Eco Temperature
         14         1  3D          MaxSetPointTemperature
         15         1  09          MinSetPointTemperature
         16         1  07          Temperature Offset * 2
                             The default value is 3,5, which means the offset = 0 degrees.
                             The offset is adjustable between -3,5 and +3,5 degrees,
                             which results in a value in this response between 0 and 7 (decoded already)
         17         1  28          Window Open Temperature
         18         1  03          Window  Open Duration
         19         1  30          Boost Duration and Boost Valve Value
                             The 3 MSB bits gives the duration, the 5 LSB bits the Valve Value%.
                             Duration: With 3 bits, the possible values (Dec) are 0 to 7, 0 is not used.
                             The duration in Minutes is: if Dec value = 7, then 30 minutes, else Dec value * 5 minutes
                             Valve Value: dec value 5 LSB bits * 5 gives Valve Value in %
         1A         1  0C          Decalcification: Day of week and Time
                             In bits: DDDHHHHH
                             The three most significant bits (MSB) are presenting the day, Saturday = 1, Friday = 7
                             The five least significant bits (LSB) are presenting the time (in hours)
         1B         1  FF          Maximum Valve setting; *(100/255) to get in %
         1C         1  00          Valve Offset ; *(100/255) to get in %
         1D         ?  44 48 ...   Weekly program (see The weekly program)
         $str = base64_decode($arr2[1]);
         echo $arr2[0]."\n".htmlentities($str)."\n";
         for($i = 0 ; $i <= strlen($str) ; $i++) echo dechex(ord(substr($str,$i,1)))." ";
         echo "\n";
         echo "\n";
         echo strlen($str)."\n";
         unset($hilf);
         $pos = 0;
         $readlen = 1;
         $hilf["?1"] = dechex(ord(substr($str,$pos,1)))."";
         $pos += $readlen;
         $readlen = 3;
         $pos += $readlen;
         $readlen = 1;
         $hilf["DeviceType"] = dechex(ord(substr($str,$pos,1)))."";
         $pos += $readlen;
         $readlen = 3;
            $hilf["?2"] .= dechex(ord(substr($str,$i,1)))." ";
         $pos += $readlen;
         $readlen = 10;
         $hilf["SerialNumber"] = htmlentities(substr($str,$pos,$readlen))."";
         $pos += $readlen;
         $deviceconf[$hilf["RFAdress"]]["?1"] = $hilf["?1"];
         $deviceconf[$hilf["RFAdress"]]["RFAdress"] = $hilf["RFAdress"];
         $deviceconf[$hilf["RFAdress"]]["DeviceType"] = $hilf["DeviceType"];
         $deviceconf[$hilf["RFAdress"]]["?2"] = $hilf["?2"];
         $deviceconf[$hilf["RFAdress"]]["SerialNumber"] = $hilf["SerialNumber"];
         switch($deviceconf[$hilf["RFAdress"]]["DeviceType"])
            case "0":
               // Cube
               $readlen = 1;
               $deviceconf[$hilf["RFAdress"]]["PortalEnabled"] = ord(substr($str,$i,$readlen))."";
               $pos += $readlen;
               $readlen =  4;
                  $deviceconf[$hilf["RFAdress"]]["?3"] .= dechex(ord(substr($str,$i,1)))." ";
               $pos += $readlen;
               $readlen =  8;
                  $deviceconf[$hilf["RFAdress"]]["?4"] .= dechex(ord(substr($str,$i,1)))." ";
               $pos += $readlen;
               $readlen = 21;
                  $deviceconf[$hilf["RFAdress"]]["?5"] .= dechex(ord(substr($str,$i,1)))." ";
               $pos += $readlen;
               $readlen = 4;
                  $deviceconf[$hilf["RFAdress"]]["?6"] .= dechex(ord(substr($str,$i,1)))." ";
               $pos += $readlen;
               $readlen =  8;
                  $deviceconf[$hilf["RFAdress"]]["?7"] .= dechex(ord(substr($str,$i,1)))." ";
               $pos += $readlen;
               $readlen = 21;
                  $deviceconf[$hilf["RFAdress"]]["?8"] .= dechex(ord(substr($str,$i,1)))." ";
               $pos += $readlen;
               $readlen = 36;
               $deviceconf[$hilf["RFAdress"]]["PortalURL"] .= htmlentities(substr($str,$i,$readlen))."";
               $pos += $readlen;
               $readlen = 60; for($i = $pos; $i < $readlen+$pos ; $i++) $deviceconf[$hilf["RFAdress"]]["?9"] .= ord(substr($str,$i,1))." ";  $pos += $readlen;
               $readlen = 33; for($i = $pos; $i < $readlen+$pos ; $i++) $deviceconf[$hilf["RFAdress"]]["?A"] .= ord(substr($str,$i,1))." ";  $pos += $readlen;
               $readlen =  3; for($i = $pos; $i < $readlen+$pos ; $i++) $deviceconf[$hilf["RFAdress"]]["StandardTimeZone"] .= htmlentities(substr($str,$i,1))."";  $pos += $readlen;
               $readlen =  9; for($i = $pos; $i < $readlen+$pos ; $i++) $deviceconf[$hilf["RFAdress"]]["?C"] .= ord(substr($str,$i,1))." ";  $pos += $readlen;
               $readlen =  4; for($i = $pos; $i < $readlen+$pos ; $i++) $deviceconf[$hilf["RFAdress"]]["DSTTimeZone"] .= htmlentities(substr($str,$i,1))."";  $pos += $readlen;
               $readlen =  9; for($i = $pos; $i < $readlen+$pos ; $i++) $deviceconf[$hilf["RFAdress"]]["?E"] .= ord(substr($str,$i,1))." ";  $pos += $readlen;
            break;
            case "1":
               // Thermostat
               $readlen =  1; $deviceconf[$hilf["RFAdress"]]["ComfortTemperature"] = (ord(substr($str,$pos,$readlen))/2)."";  $pos += $readlen;
               $readlen =  1; $deviceconf[$hilf["RFAdress"]]["EcoTemperature"] = (ord(substr($str,$pos,$readlen))/2)."";  $pos += $readlen;
               $readlen =  1; $deviceconf[$hilf["RFAdress"]]["MaxSetPointTemperature"] = (ord(substr($str,$pos,$readlen))/2)."";  $pos += $readlen;
               $readlen =  1; $deviceconf[$hilf["RFAdress"]]["MinSetPointTemperature"] = (ord(substr($str,$pos,$readlen))/2)."";  $pos += $readlen;
               $readlen =  1; $deviceconf[$hilf["RFAdress"]]["TemperatureOffset"] = (ord(substr($str,$pos,$readlen)))/2-3.5."";  $pos += $readlen;
               $readlen =  1; $deviceconf[$hilf["RFAdress"]]["WindowOpenTemperature"] = (ord(substr($str,$pos,$readlen))/2)."";  $pos += $readlen;
               $readlen =  1; $deviceconf[$hilf["RFAdress"]]["WindowOpenDuration"] = dechex(ord(substr($str,$pos,$readlen)))."";  $pos += $readlen;
               $readlen =  1; $deviceconf[$hilf["RFAdress"]]["Boost"] = str_pad(decbin(ord(substr($str,$pos,$readlen))),8,"0",STR_PAD_LEFT)."";  $pos += $readlen;
               $deviceconf[$hilf["RFAdress"]]["BoostDuration"] = bindec(substr($deviceconf[$hilf["RFAdress"]]["Boost"],0,3))*5;
               $deviceconf[$hilf["RFAdress"]]["BoostValue"] = bindec(substr($deviceconf[$hilf["RFAdress"]]["Boost"],3,5))*5;
               $readlen =  1; $deviceconf[$hilf["RFAdress"]]["Decalc"] = str_pad(decbin(ord(substr($str,$pos,$readlen))),8,"0",STR_PAD_LEFT)."";  $pos += $readlen;
               $deviceconf[$hilf["RFAdress"]]["DecalcDay"] = bindec(substr($deviceconf[$hilf["RFAdress"]]["Decalc"],0,3));
               $deviceconf[$hilf["RFAdress"]]["DecalcTime"] = bindec(substr($deviceconf[$hilf["RFAdress"]]["Decalc"],3,5));
               $readlen =  1; $deviceconf[$hilf["RFAdress"]]["MaximumValveSetting"] = dechex(ord(substr($str,$pos,$readlen)))*(100/255)."";  $pos += $readlen;
               $readlen =  1; $deviceconf[$hilf["RFAdress"]]["ValveOffset"] = dechex(ord(substr($str,$pos,$readlen)))*(100/255)."";  $pos += $readlen;
               for ($j = 1 ; $j <= 7 ; $j++)
                  $readlen = 26;// Sat, Sun, Mon, Tue, Weg, Thu, Fri
                  for($i = $pos; $i < $readlen+$pos ; $i+=2)
                     $bin  = str_pad(decbin(hexdec(dechex(ord(substr($str,$i,1))))),8,"0",STR_PAD_LEFT).str_pad(decbin(hexdec(dechex(ord(substr($str,$i+1,1))))),8,"0",STR_PAD_LEFT);
                     //echo $bin."  ";
                     $deg = bindec(substr($bin,0,7));
                     //$deviceconf[$hilf["RFAdress"]]["WeeklyProgramm".$j.""] .= ($deg/2)."^C ";
                     $min = bindec(substr($bin,7,9));
                     //$deviceconf[$hilf["RFAdress"]]["WeeklyProgramm".$j.""] .= number_format(($min*5/60),2)."hr | ";
                     $deviceconf[$hilf["RFAdress"]]["WeeklyProgramm".$j."deg"][] = ($deg/2);
                     $deviceconf[$hilf["RFAdress"]]["WeeklyProgramm".$j."time"][] = number_format(($min*5/60),2);
               $pos += $readlen;
            break;
            case "4":
               // Fensterkontakt
               echo "======debug======";echo $hilf["?2"];
               $deviceconf[$hilf["RFAdress"]]["WindowOpen"] = $hilf["?2"]&&0b00000010;
            break;
      break;
      case "L:":
         Device List
         L:DAzPAPkSGAQqAAAA1gsMehX5EhgAKgAAAAsMej7sEhgKKgAAAAYMrzfsEhAGDLI1bBIQ
         00000000  0c 0c cf 00 f9 12 18 04  2a 00 00 00 d6 0b 0c 7a  |........*......z|
         00000010  15 f9 12 18 00 2a 00 00  00 0b 0c 7a 3e ec 12 18  |.....*.....z>...|
         00000020  0a 2a 00 00 00 06 0c af  37 ec 12 10 06 0c b2 35  |.*......7......5|
         00000030  6c 12 10                                          |l..|
         00000033
         0          1  0B          Length of data: 0B = 11(decimal) = 11 bytes
         4          1  00          ?
         5          1  12          bit 4     Valid              0=invalid;1=information provided is valid
                             bit 3     Error              0=no; 1=Error occurred
                             bit 2     Answer             0=an answer to a command,1=not an answer to a command
                             bit 1     Status initialized 0=not initialized, 1=yes
                             12  = 00010010b
                                = Valid, Initialized
         6       1     1A          bit 7     Battery       1=Low
                             bit 6     Linkstatus    0=OK,1=error
                             bit 5     Panel         0=unlocked,1=locked
                             bit 4     Gateway       0=unknown,1=known
                             bit 3     DST setting   0=inactive,1=active
                             bit 2     Not used
                             bit 1,0   Mode         00=auto/week schedule
                                              01=Manual
                                              10=Vacation
                                              11=Boost
                             1A  = 00011010b
                                = Battery OK, Linkstatus OK, Panel unlocked, Gateway known, DST active, Mode Vacation.
         7       1     20          Valve position in %
         8       1     2C          Temperature setpoint, 2Ch = 44d; 44/2=22 deg. C
         9       2     858B        Date until (05-09-2011) (see Encoding/Decoding date/time)
         B       1     2E          Time until (23:00) (see Encoding/Decoding date/time)
         $v = substr($v,2,strlen($v));
         $str = base64_decode($v);
         //echo htmlentities($str)."\n";
         //$buff = "";
         //for($i = 0 ; $i <= strlen($str) ; $i++) $buff .= dechex(ord(substr($str,$i,1)))." ";
         //$buff .= "\n";
         //echo $buff;
         $pos = 0;
            unset($hilf);
            $readlen =              1; $hilf["ReadLength"] = htmlentities(ord(substr($str,$pos,1))).""; $pos += $readlen;
            $readlen =              3; for($i = $pos; $i < $readlen+$pos ; $i++) $hilf["RFAdress"] .= str_pad(dechex(ord(substr($str,$i,1))),2,"0",STR_PAD_LEFT).""; $pos += $readlen;
            $readlen =              1; $hilf["?1"] = dechex(ord(substr($str,$pos,1))).""; $pos += $readlen;
            $readlen =              1; $hilf["Data1"] .= str_pad(decbin(ord(substr($str,$pos,1))),8,"0",STR_PAD_LEFT).""; $pos += $readlen;
            $readlen =              1; $hilf["Data2"] .= str_pad(decbin(ord(substr($str,$pos,1))),8,"0",STR_PAD_LEFT).""; $pos += $readlen;
            if($hilf["ReadLength"] == 11)
               $readlen =              1; $hilf["?2"] = dechex(ord(substr($str,$pos,1))).""; $pos += $readlen;
               $readlen =              1; $hilf["Temperature"] = (ord(substr($str,$pos,1))/2).""; $pos += $readlen;
               $readlen =              2; for($i = $pos; $i < $readlen+$pos ; $i++) $hilf["DateUntil"] .= str_pad(decbin(ord(substr($str,$i,1))),8,"0",STR_PAD_LEFT).""; $pos += $readlen;
               $readlen =              1; $hilf["TimeUntil"] = (ord(substr($str,$pos,1))*0.5).""; $pos += $readlen;
            $deviceconf[$hilf["RFAdress"]]["LiveReadLength"] = $hilf["ReadLengt   h"];
            $deviceconf[$hilf["RFAdress"]]["LiveRFAdress"] = $hilf["RFAdress"];
            $deviceconf[$hilf["RFAdress"]]["Live?1"] = $hilf["?1"];
               $deviceconf[$hilf["RFAdress"]]["Live?2"] = $hilf["?2"];
               $deviceconf[$hilf["RFAdress"]]["Temperature"] = $hilf["Temperature"];
               $deviceconf[$hilf["RFAdress"]]["DateUntil"] = $hilf["DateUntil"];
               $year = substr($hilf["DateUntil"],-6,6);
               $month = substr($hilf["DateUntil"],0,3).substr($hilf["DateUntil"],8,1);
               $day = substr($hilf["DateUntil"],3,5);
               $deviceconf[$hilf["RFAdress"]]["DateUntil"] = bindec($day).".".bindec($month).".".bindec($year);
               $deviceconf[$hilf["RFAdress"]]["TimeUntil"] = $hilf["TimeUntil"];
               $deviceconf[$hilf["RFAdress"]]["TimestampUntil"] = mktime(floor($hilf["TimeUntil"]),($hilf["TimeUntil"]-floor($hilf["TimeUntil"]))*60,0,bindec($month),bindec($day),bindec($year));
            $deviceconf[$hilf["RFAdress"]]["valid"] = substr($hilf["Data1"],3,1);
            $deviceconf[$hilf["RFAdress"]]["Error"] = substr($hilf["Data1"],4,1);
            $deviceconf[$hilf["RFAdress"]]["isAnswer"] = substr($hilf["Data1"],5,1);
            $deviceconf[$hilf["RFAdress"]]["initialized"] = substr($hilf["Data1"],6,1);
            $deviceconf[$hilf["RFAdress"]]["LiveData7"] = substr($hilf["Data1"],7,1);
            $deviceconf[$hilf["RFAdress"]]["LowBatt"] = substr($hilf["Data2"],0,1);
            $deviceconf[$hilf["RFAdress"]]["LinkError"] = substr($hilf["Data2"],1,1);
            $deviceconf[$hilf["RFAdress"]]["PanelLock"] = substr($hilf["Data2"],2,1);
            $deviceconf[$hilf["RFAdress"]]["GatewayOK"] = substr($hilf["Data2"],3,1);
            $deviceconf[$hilf["RFAdress"]]["DST"] = substr($hilf["Data2"],4,1);
            $deviceconf[$hilf["RFAdress"]]["Not used"] = substr($hilf["Data2"],5,1);
            switch (substr($hilf["Data2"],6,2))
               case "00" : $deviceconf[$hilf["RFAdress"]]["Mode"] = "auto"; break;
               case "01" : $deviceconf[$hilf["RFAdress"]]["Mode"] = "manu"; break;
               case "10" : $deviceconf[$hilf["RFAdress"]]["Mode"] = "vacation"; break;
               case "11" : $deviceconf[$hilf["RFAdress"]]["Mode"] = "boost"; break;
            $deviceconf[$hilf["RFAdress"]]["LiveDataX"] = $hilf["Data3"];
            echo "\n";
      break;
if (basename($_SERVER['SCRIPT_FILENAME']) != "interface.php")
$ob = ob_get_contents();
ob_end_clean();
echo $ob;
print_r($data);
echo "\n<hr />\n";
print_r($deviceconf);
ob_end_clean();
echo "</pre>";
pjakobs
Return to Homematic, FS20, FHT, ESA and ELV
