visonic serial port not answering.
Moderators: Rene, Willem4ever
Postby labium » Wed Mar 21, 2018 9:17 pm
goedevening,
i cant get sertial data back from my powermax pro on a serial port from the duo serial board the other serial port is connected to a powermax 1 unit which works well- , i want to use the powermax installer software but aint getting any info from the powermax. who knows what is wrong ?
labium
Re: visonic serial port not answering.
Postby Akatar » Wed Mar 21, 2018 11:09 pm
labium wrote:goedevening,
i don't know if you use a gsm module? as far as i know they don't work both.
Akatar
Postby Akatar » Wed Mar 21, 2018 11:13 pm
here it is:
LET OP! Indien een GSM module wordt geplaatst dan kan de CELL/PC poort van de dual RS-232 print niet toegepast worden om een computer aan te sluiten. In dit geval verwijder tijdelijk de GSM module verbinding of gebruik de PL/PC aansluiting! BELANGRIJK! De aansluitklemmen voor de interne en externe sirenes zijn DC uitgangen voor 12V sirenes. Indien een luidspreker aan één van deze uitgangen wordt aangesloten, zal deze kortsluiting veroorzaken en de PowerMax Pro ernstig beschadige
Akatar
Postby labium » Fri Mar 23, 2018 10:22 am
i have no gsm module. i have powerlink 1 connected , which works i also bought a usr tcp232 -t2 to see if i can read something from the ttl port . waiting for the female femal jumber cables
visonic interior.jpg (191.46 KiB) Viewed 1432 times
labium
Postby Akatar » Fri Mar 23, 2018 10:45 am
please remove the powerlink, i thought there were also troubles with the powerlink connected.
Akatar
Postby labium » Fri Mar 23, 2018 10:49 am
but i have 4 cameres acting via the powerlink , i dont want loose that, i dont know how to flash the original firmware of the marmitek cameras this are i think marmitek cameras with visonic firmware, tried to put one time original firmware on those cameras didnt succeed they did not accept it. https://www.visonic.com/Data/Uploads/Ca ... 800517.pdf
labium
Postby Akatar » Fri Mar 23, 2018 12:10 pm
just try if that works, so you know what the reason is
according to some people:
Apparently the PowerMax Pro only has two COM ports. If you have a GSM module installed, it disables the right RS232 port. Plugging in the PowerLink II disables the left RS232 port. When you unplug the PowerLink II it takes a while for the PowerMax to re-enable the left RS232 port (that is where power cycling works sometimes but not all the time).
Akatar
Postby labium » Fri Mar 23, 2018 2:31 pm
i will try .
labium
