Visonic Software
Moderators: Rene, Willem4ever
Visonic Software
Postby Bastiaan » Mon Oct 13, 2008 10:18 pm
MAX232 converterts the RS232 signal to 5v levels. Very common interface.
Wouldn't it be possbile to access the system using a modem and phoneline? It shows this in the manual and in the software.
Bastiaan
Visonic Software
Postby Digit » Mon Oct 13, 2008 10:21 pm
RFXCOM Serial module also has MAX232. Let's see if that will fit into the Visonic [:o)]
Visonic Software
Postby TANE » Mon Oct 13, 2008 10:25 pm
I have the Rfxcom version...that one will not fit..
Visonic Software
Postby Bwired » Mon Oct 13, 2008 10:40 pm
I think the Visonic rs232 print is not worth the money, it's only for programming the panel and once you programmed it, it probably takes ages when you use it again :-)
Visonic Software
Postby Rene » Mon Oct 13, 2008 10:44 pm
You can rent mine for 10 euro/day ;-)
One thing you are able to do only via the software configuration, at least I think so, is to replace the 5 generic zone names to more meaning full names.
Visonic Software
Postby Nielsy » Sun Oct 19, 2008 10:53 am
Dear all,
I have now also a Visonic powermax+ system from marktplaats and already reset it( for the install code so that now standaard). Download the installationguide from the visonic site. But I can't get out of it.
Now is my question is the rs232 module with the software easier to config the system? because than I can order so module or maybe somebody living close to me how have time and wants to help me ( tegen betaling uiteraard ) I living in the middel of Breda and Roosendaal.
Or maybe somebody have a easy quickguide for Visonic systems ??
Thanx already for you help guys..
Nielsy
Visonic Software
Postby TANE » Sun Oct 19, 2008 11:00 am
you can download the software and try.
uploading to powermax is not possible without the interface.
It's not the most easy interface
Visonic Software
Postby MindBender » Sun Oct 19, 2008 12:31 pm
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Nielsy</i>
<br />I have downloaded : Remote_Programmer_3_0_37_6.zip
But it's password procteded. ( I try : visonic,Visonic,Powermax,powermax )
But no go.
Or must I used a other link / program?
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Yes, it seems you need Brutus.
MindBender
Visonic Software
Postby marunga » Mon Dec 15, 2008 11:21 pm
Has anyone built the Serial Cable ?
I wil try to build one next week.
regards,
m
marunga
Visonic Software
Postby TANE » Mon Dec 15, 2008 11:33 pm
I have the interface...looks not easy to self build
When installing the interface I saw also a PC interface direct on the Powermax pro..not sure what this is..
Visonic Software
Postby marunga » Mon Dec 15, 2008 11:43 pm
Found this: http://www.homesecuritystore.com/ezstor ... uctID=1135
Only has one RJ-45 connector (unlike the one in the photos). Can anyone post some photos of the "one-plugged" interface?
And after I've assembled the RS-232 module, will add a bluetooth transmiter :-)
marunga
Visonic Software
Postby Rene » Tue Dec 16, 2008 12:24 am
@marunga: This is for the PowerMax, the previous photo is the interface required for the Powermax Pro.
Visonic Software
Postby marunga » Tue Dec 16, 2008 12:35 am
[:D] Yep, just found up... and this is the one I want:Powermax+
Does anyone have one of these and post some "zoomed" photos ? or better, a schematic [;)]
marunga
Visonic Software
Postby Oud One » Sun Dec 21, 2008 1:52 pm
Is the some on ther have the cable wire diagram from the rs-232 print to the pc it is a rj-45 to dj-9 it is for the powermax pro.
Oud One
Visonic Software
Postby Jfn » Sun Dec 21, 2008 2:37 pm
Concerning the wiring-diagram, have a look at the MAX-232 datasheet. Looking at pictures of the PCB the circuit-board is a very standard TTL <--> RS-232 convertor.
When blu-tooth was not mainstream, you had those adapter-cables for plugging your mobile-phone into your PC. If you have one of those you could use that.
Looking again at the PCB:
1: +5V
2: RX from PowerMax to external
3+4: TX/DTR from external to Powermax
All signals TTL level
I could not find GND (picture too dark), but that can be found very easily using a multi-meter.
Jfn
PreviousNext
