Page 2 of 4
Visonic Software
Posted: Mon Oct 13, 2008 11:18 pm
by Bastiaan
MAX232 converterts the RS232 signal to 5v levels. Very common interface.
Wouldn't it be possbile to access the system using a modem and phoneline? It shows this in the manual and in the software.
Visonic Software
Posted: Mon Oct 13, 2008 11:21 pm
RFXCOM Serial module also has MAX232. Let's see if that will fit into the Visonic [:o)]
Visonic Software
Posted: Mon Oct 13, 2008 11:25 pm
by TANE
I have the Rfxcom version...that one will not fit..
Visonic Software
Posted: Mon Oct 13, 2008 11:40 pm
I think the Visonic rs232 print is not worth the money, it's only for programming the panel and once you programmed it, it probably takes ages when you use it again
Visonic Software
Posted: Mon Oct 13, 2008 11:44 pm
by Rene
You can rent mine for 10 euro/day
One thing you are able to do only via the software configuration, at least I think so, is to replace the 5 generic zone names to more meaning full names.
Visonic Software
Posted: Sun Oct 19, 2008 11:53 am
by Nielsy
Dear all,
I have now also a Visonic powermax+ system from marktplaats and already reset it( for the install code so that now standaard). Download the installationguide from the visonic site. But I can't get out of it.
Now is my question is the rs232 module with the software easier to config the system? because than I can order so module or maybe somebody living close to me how have time and wants to help me ( tegen betaling uiteraard ) I living in the middel of Breda and Roosendaal.
Or maybe somebody have a easy quickguide for Visonic systems ??
Thanx already for you help guys..
Visonic Software
Posted: Sun Oct 19, 2008 12:00 pm
by TANE
you can download the software and try.
uploading to powermax is not possible without the interface.
It's not the most easy interface
Visonic Software
Posted: Sun Oct 19, 2008 1:31 pm
by MindBender
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Nielsy</i>
<br />I have downloaded : Remote_Programmer_3_0_37_6.zip
But it's password procteded. ( I try : visonic,Visonic,Powermax,powermax )
But no go.
Or must I used a other link / program?
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Yes, it seems you need Brutus.
Visonic Software
Posted: Tue Dec 16, 2008 12:21 am
by marunga
Has anyone built the Serial Cable ?
I wil try to build one next week.
regards,
m
Visonic Software
Posted: Tue Dec 16, 2008 12:33 am
by TANE
I have the interface...looks not easy to self build
When installing the interface I saw also a PC interface direct on the Powermax pro..not sure what this is..
Visonic Software
Posted: Tue Dec 16, 2008 12:43 am
by marunga
Found this:
http://www.homesecuritystore.com/ezstor ... uctID=1135
Only has one RJ-45 connector (unlike the one in the photos). Can anyone post some photos of the "one-plugged" interface?
And after I've assembled the RS-232 module, will add a bluetooth transmiter
Visonic Software
Posted: Tue Dec 16, 2008 1:24 am
by Rene
@marunga: This is for the PowerMax, the previous photo is the interface required for the Powermax Pro.
Visonic Software
Posted: Tue Dec 16, 2008 1:35 am
by marunga
[:D] Yep, just found up... and this is the one I want:Powermax+
Does anyone have one of these and post some "zoomed" photos ? or better, a schematic [;)]
Visonic Software
Posted: Sun Dec 21, 2008 2:52 pm
by Oud One
Is the some on ther have the cable wire diagram from the rs-232 print to the pc it is a rj-45 to dj-9 it is for the powermax pro.
Visonic Software
Posted: Sun Dec 21, 2008 3:37 pm
by Jfn
Concerning the wiring-diagram, have a look at the MAX-232 datasheet. Looking at pictures of the PCB the circuit-board is a very standard TTL <--> RS-232 convertor.
When blu-tooth was not mainstream, you had those adapter-cables for plugging your mobile-phone into your PC. If you have one of those you could use that.
Looking again at the PCB:
1: +5V
2: RX from PowerMax to external
3+4: TX/DTR from external to Powermax
All signals TTL level
I could not find GND (picture too dark), but that can be found very easily using a multi-meter.
