Visonic Software
Moderators: Rene, Willem4ever
Re: Visonic Software
Postby belibaste » Mon Aug 13, 2012 2:28 pm
@Jfn:
it's stange: I don't find point (1) at +5V.
How do you mesure it?
I don't find GND also;
do you have more informations?
thanks
belibaste
Postby redo » Mon May 06, 2013 11:50 pm
marunga wrote:Also, I've read the EEPROM. Maybe if I could write the Powermax+ firmware, I can change this in to a real Powermax+ . Does anybody have a dump from the PMAX+ EEPROM?
regards,
m
hi marunga , please can you send me , the reading eeprom ? i need this for repair my powermax alarm
redo
Postby Rene » Tue May 07, 2013 12:41 pm
rapidrainer wrote:Hi,
I've just tried the remote programmer software with a BT vp1000 (UK) using a laptop to remotely connect. It all appears to work fine (The software calls twice and the VP1000 picks up the call). But I cannot get past the login phase. I suspect that this has a lot to do with a "Download Code" that is required for the software to authenticate with the alarm. Does anyone know how the "Download Code" is determined for the VP1000? I know it is possible for remote connectivity since a company in the UK, Intamac, connected remotely and changed some settings for me. (Intamac do the monitoring on behalf of BT). Any thoughts?
Regards
See http://knowledgebase.homesecuritystore. ... e+reset%3F to reset the pin codes to their default value.
Previous
