Hello everyone, I have a PowerMax PRO, anyone knows the identity of the connecting pins of the module internal or external GSM.
My thanks
Connecting GSM
Moderators: Rene, Willem4ever
Connecting GSM
Reason: We're not deaf!
Re: Connecting GSM
I have a Powermax Pro and an internal GSM module, but I do not have a clue what you are after.
Re: Connecting GSM
Rene thanks for the reply, and I have a gsm of that to connect to the PM but I need to know what makes each pin of the PM or you would not know how to plug it.
In gsm know which are not in PM
Re: Connecting GSM
Sorry to say, but I think your question is still not clear to anybody.
Do you have the GSM module for the PowerMax or do you have a normal GSM (cellphone) you're trying to connect?
- If you have a GSM module for the PowerMax, then I guess you want to know how to connect it?
- If you have a regular GSM (cellphone) you probably won't be able to connect it all, but I don't own the PM so I'll leave it to somebody else to answer this.
Re: Connecting GSM
Excuse my English, I try to explain
I have a GSM modem that would connect the PM.
I know the designation of the pins of GSM, and want to know if anyone has a description of the pins on the PM for how to connect this GSM
Thanks
Thanks
- adapter to DB9 and 4p4c plug thelefone
- gsm adapter.jpg (33.38 KiB) Viewed 5504 times
- conections on GSM
- GSM conections.jpg (123.92 KiB) Viewed 5504 times
Re: Connecting GSM
I dont think that will work, you can only connect a powermax GSM modem which will react to the powermax commands.
Not sure if the Powermax uses the standard AT commands, guess not. If you are really technical you can probably pull it off. As far as I know no technical documentation on this also, btw Visonic does even not have documentation on regular products
