New Visonic alarm Powermax Complete?
Posted: Thu Mar 29, 2012 3:47 pm
Hai, I would like to replace my SC9000 X10 alarm set for the Visonic Powermax Complete. I hope to get a more stable alarm system with a better performance. I now often have problems reaching the various door sensors due to thick concrete walls and floors with steel in them. With what I have read on the forum most of you are very satisfied with the Visonic alarm system.
I would like to see the status of all the sensors, what I've read I can do that by using the extensions board 868.95MHz receiver for Visonic sensors at €60,-. (I already have the RFXcom 433.92MHz LAN transceiver)
Further I would like to arm and disarm the alarm via HomeseerHStouch and my Hstouch android app.
I have read all the topics about the Powerlink hacks but there is no off the shelve solution as I understand. I am no programmer so the most in the topics I don't understand, I mean I am not very good with that do that unless I have some clear instructions. Than I usually manage to get i working.
So my questions;
Do I need the Powerlink with the Powermax complete to arm/disarm it with homeseer? If it is, it is a bit of an expansive solution I think. I know you can do more with it but If I have the extension for the RFXcom I also have all the information, from the sensors right?
Do I need the UK version to get it working or will I manage to get it working with a Dutch set?
So my questions;
