Hoster with external dns setup
Forum about all other NON Home automation stuff can be placed here....
Postby Snelvuur » Thu Dec 04, 2014 8:16 pm
Does anybody know a good domain hoster, i purely want to have domains registered. I have my own dns servers so i need to be able to point them to it. But the important part is cheap, nice and needs to be able to automatic extend domains (renewal of payment that is) problem is that i have some co.uk domains, some .com some .nl and some .eu even an .io problem is that most of these domain hosters support a lot of domains but not all of them. Thats my primairy objective, finding a domain hoster that has those all (since having multiple ones is just silly)
Thanks,
Erik
Snelvuur
Re: Hoster with external dns setup
Postby vanisher » Thu Dec 04, 2014 9:45 pm
A Domotica starter, currently running: Plugwise, Z-Wave, Jeenods, Homeseer / DomotiGa
vanisher
Postby Noel » Thu Dec 04, 2014 10:27 pm
+1 on transip.nl
Noel
Postby redleg » Thu Dec 04, 2014 11:56 pm
+1 on transip.nl
redleg
Postby Snelvuur » Fri Dec 05, 2014 1:28 am
While transip might have a good service, a good price would be one too. I compared them with places where i have domains now:
7,49 euro per year for .nl i have it now for 5,95 euro a year.
12,50 euro per year for .co.uk, i have that now for 6,32 euro a year (can get almost 3 years for 12,50)
9,99 euro per .com domain, i pay 6,64 euro for that.
As you can see if you have several domains, this adds up. Hence why its pretty hard to find a good one for also a good price, i don't mind if its a euro more but not multiple.
Snelvuur
Postby Phaeton » Fri Dec 05, 2014 7:17 am
Versio might do
Verstuurd vanaf mijn Nexus 5 met Tapatalk
groeten,
Phaeton
Postby Noel » Fri Dec 05, 2014 7:51 am
Transip has a lot of discount actions on the .nl. sometimes as low as 50cnt for a year. .com I normally register at GoDaddy.
.je are cheap when you go directly to Jersey and not through any registrar.
I do not think that you will find one place where everything (domains / hosting) is cheap. You will need to shop around.
Transip you just need to set the ip(s) of where it needs to go to. They have there own DNS.
Noel
Postby Snelvuur » Fri Dec 05, 2014 9:20 am
Discount only is for the first year, so i don't see that as the real price.
As comparisa, 123-reg in the uk does cheap uk. I am with hetzner, who offers .com via their panel cheap .com .eu and .org. I use namecheap for .io adresses and for everything else (this is an example of a domain hoster that does almost all) is www.domainnameshop.com , problem is that it aint the cheapest with some, but you do get discounts on regular domains if you exceed the number of domains (so you get 1 euro discount on most domains if you have more then 5 domains running there)
On top of that i usually add "cloudflare" the free service, does dns in the panel and does fast resolving from any location (http://blog.cloudflare.com/cloudflare-f ... stest-dns/) and you get free ssl certificate for your site + many more. Also helps against ddos attacks and stuff like that since it acts as a reverse proxy which hides your real ip from the internet (only need use MX record to be not proxied)
Snelvuur
Postby jeroen_ » Fri Dec 05, 2014 10:33 am
I typically use http://www.joker.com, cheap and ease of use, even supports DNSSEC and IPv6 properly.
You can use their DNS servers or your own or just do not delegate the entries at all...
jeroen_
Postby Snelvuur » Fri Dec 05, 2014 11:10 am
Joker is indeed also something like what i mean. Problem is that i dont see .io in their list.
Snelvuur
Postby jeroen_ » Fri Dec 05, 2014 11:21 am
Snelvuur wrote:Joker is indeed also something like what i mean. Problem is that i dont see .io in their list.
Gandi (https://www.gandi.net/) has .io for 29EUR/year (and thousands of others because of the nonsense gtld stuff)
I only use Gandi for SSL though; do know some folks using Gandi for their domains and it seems to work fine for them.
And actually speaking of TLDs, I stick to .ch/li as I know the law for those is proper unlike most other TLDs, next to stability etc...
jeroen_
Postby jeroen_ » Fri Dec 05, 2014 11:25 am
Ask yourself what the point of a 'free SSL' certificate is when the company that gives it to you can read along as they have full capability to MITM the connection and provide another 'free SSL' certificate... Just think about it, there is a reason why they are providing 'free' service to so many shady outfits....
Not that SSL in general is not broken because of the CA model and likely the code or even just the crypto behind it.
At minimum use https://www.owasp.org/index.php/Certifi ... ey_Pinning using the "Public-Key-Pins" HTTP header.
jeroen_
Postby Snelvuur » Fri Dec 05, 2014 1:07 pm
Only use this on my "pet" projects, on my real customers i get a real certiticate. Ghandi does seems to have them all though, but .com is double the price of what i have now. I think i should just live with the fact that if you need different ones that you need to use different providers...
Snelvuur
Postby Noel » Fri Dec 05, 2014 10:06 pm
For the more exotic tld's I sometimes use eurodns.com
Noel
Postby vanisher » Fri Dec 05, 2014 10:30 pm
You want ease of use and preferably one registar.... and for the lowest price possible.. quality and low price are not friends.
vanisher
Next
Return to Off Topic
