When i startup HomeSeer on my laptop (Core I5) it is started within seconds and much faster then the EEE Box, but i need this laptop for work I don`t want to buy a complete controller like Vera Edge, Fibaro HC2, Fibaro HCL because they are too closed for my needs. I would like to buy a "cheap" hardware pc platform with "full" power cpu resources to run my Domotica software on
In my quest for the new box i found the following solution and would like to know if it is fast enough for HomeSeer (or OpenHAB since i`m using both)
GIGABYTE BRIX GB-BXBT-2807 as i also found (dutch) out that is seems to be as slow as a Intel Atom CPU (which the B202 has)
Note:
- I already tested DomotiGa on a RaspberryPI (B) but it has too few ports for all my interfaces, even using multiple USB Hubs.
- I`m also running OpenHAB / Domotiga on another B202 using Ubuntu Server 14.04
