Opening window with homewizard
badeend
Post by badeend »
I would like to be able to open a window using some kind of motor. I was thinking it should be possible to make, but i'm not familiar with elektronics.
I was wondering if anyone knew of some kind of plug and play device i could use for this. It would be even better if this used homewizard since i allready have this installed at my house.
Other suggestions are ofcourse also welcome. I'm eager to learn and to try to build it. So any help i can get is welcome!
Thanks!
raymonvdm
Re: Opening window with homewizard
Post by raymonvdm »
It is possible using a AXA Remote 2.0 for example and rewire the remote with a relais to control it using the remote or build an RS232 interface for it
