Output relays
Output relays
Postby Wima » Tue Jan 05, 2016 10:40 pm
I am looking for an output relay board witch can be controlled bij HS3 (by LAN or USB)
By looking at the existing plugins for HS I think something like the sprinkler boards but
those are to specific relating to the sprinkler control
Perhaps one of you has some experience with I/O boards. I could not find a ready build one.
I am not good in programming, so an Arduino or RaspberryPi is not an option.
Thanks
Wil
even the genious ask questions
Wima
Re: Output relays
Postby Bwired » Tue Jan 05, 2016 11:12 pm
i have this for sale, i think there is a HS script available and I think Peterpc is using this also
viewtopic.php?f=15&t=10998
Re: Output relays
Postby Wima » Wed Jan 06, 2016 6:25 am
That could be the one. Do you got any clou how to control the board?
Again: I am not a programmer :-(
Wil
Wima
Re: Output relays
Postby Wima » Wed Jan 06, 2016 7:28 am
Perhaps found something intrestring: http://www.pimzos.com/nl/aviosys-ip-power-9223k-d.html.
These ports can be turned on/of by a HTTP command. So I think through HS easy to control with an event.
Also found pc-control.co.uk/control/products/board ... laybee.php discovered that
there is a plugin build bij Jon00 to control the board within HS.
Does someone got experience with the above ? Does it work?
Wil
Wima
