Hi there,
i am busy with my domoticz configuration and the time is not correct. The lang/longtitude is correct filled in for my location, but still the time is not correct. It is set to 2 hours earlyer.
What can i do next???
set correct time in domoticz [SOLVED]
greetz,
Iwan
Iwan
- Fantic
Re: set correct time in domoticz
you need to make sure the OS timezone and time is set correctly, so when running on a PI go into raspi-config and set the timezone correct and make sure NTP is set correctly.
Regards, Maarten.
This was the direction i needed. Everything was fine.
Startd putty and logged in with user: pi and password: raspberry.
i typed in sudo dpkg-reconfigure tzdata . A small program started where i just needed to select my region, and city and voila...everything was set.
Thanks Fantic for pointing me in the right direction.
greetz,
Iwan
Iwan
