Smoke detector
stefxx
Smoke detector
Post by stefxx »
Hi!
I am looking for (2 or 3) smoke detectors. The requirements are:
- 220v with backup battery
- Connect to HomeSeer HS3 (using Z-Wave or RFXCom)
A matching CO detector would make it even better :)
Any suggestions? Quality is important, but so is price...
mlamie
Re: Smoke detector
Post by mlamie »
Probably the Popp sensor is the best you can get with Z-wave. Special note, it can also be used as alarm (you can trigger the siren). I have seen Mertens smoke sensors with z-wave, but I don't know if they share there device specifics to others.
So please check the compatibility for HS3.
Check all the z-wave smoke sensor products products.z-wavealliance.org/Search/Inde ... Text=smoke
433mhz is probably cheaper.
Akatar
Re: Smoke detector
Post by Akatar »
perhaps nest? there is a hs3 plugin
stefxx
Re: Smoke detector
Post by stefxx »
Thanks.
I can only find the "Smoke Sensor / Siren (004001)" Popp sensor for ca. 70 euros. And that is without an "optional AC adapter" that costs ca. 20 euros. I bit more than I am willing to spend on a smoke detector.
The nest is even more expensive, but it does include CO detected which is great. Something to think about.
I keep looking... thanks again!
jeroenc
Re: Smoke detector
Post by jeroenc »
Be aware that since CO is heavier then air a CO sensor needs to be installed low near the floor, where a smoke detector needs to be installed high.
Any tips for a Domotica proof separate CO sensor?
Verzonden vanaf mijn iPhone met Tapatalk
