script help
script help
Postby Edwin » Thu Jan 05, 2017 10:54 am
h i need some help withthis lua script, "i get the error xml word niet goed gelezen" what is my mistake?
i added the xml file and the script file
please help
thanks.
xml file:
<appliances>
<appliance>
<macaddress>000D6F00003FF4FA</macaddress>
<name>CloseInBoiler</name>
<currentpowerusagewatts>0</currentpowerusagewatts>
</appliance>
<appliance>
<macaddress>000D6F00003FEC94</macaddress>
<name>CV-ketel</name>
<currentpowerusagewatts>9</currentpowerusagewatts>
</appliance>
<appliance>
<macaddress>000D6F00003FF1DD</macaddress>
<name>Droger</name>
<currentpowerusagewatts>3</currentpowerusagewatts>
</appliance>
<appliance>
<macaddress>000D6F0000384709</macaddress>
<name>HsProServer</name>
</appliance>
<appliance>
<macaddress>000D6F00003FEE9C</macaddress>
<name>Koelkast</name>
<currentpowerusagewatts>92</currentpowerusagewatts>
</appliance>
lua script:
commandArray = {}
function XML_Capture(cmd,flatten)
   local f = assert(io.popen(cmd, 'r'))
   local s = assert(f:read('*a'))
   f:close()
   if flatten  then
      s = string.gsub(s, '^%s+', '')
      s = string.gsub(s, '%s+$', '')
      s = string.gsub(s, '[\n\r]+', ' ')
   end
   return s
end
--zet up TRUE op in logfile weer te geven
debug = true
--vul hier de idx in van domoticz en hun namen
CloseInBoiler = 219
--CVketel = 216
--Droger = 217
--HsProServer = 218
--HWTemp_Flow = 108
--HWTemp_Return = 109
--HWTemp_Tank_Top = 110
--HWTemp_Tank_Bottom = 111
--vul hier de id`s of mac adressen in op volgorde
--kunnen nog meer bij gezet worden
sensorID_1 = "000D6F00003FF4FA"
--sensorID_2 = "000D6F00003FEC94"
--sensorID_3 = "000D6F00003FF1DD"
--sensorID_4 = "000D6F0000384709"
-- plaats hier het ipadres van plugwise
Device_IP = "192.168.2.167:xx"
if debug == true then
        print("Reading values from: 'http://"..Device_IP.."/xml/edwin.xml'")
end
-- de xml file van plugwise
XML_string=XML_Capture("curl -s 'http://"..Device_IP.."/xml/edwin.xml'",1)
valid = string.find(XML_string, "<response>")    -- controle
        print(XML_string)
    end
    if valid == nil then
        print ("Xml word niet goed gelezen,Geen Update")
    else
--vind de eerste sensor op zijn unieke id
    i = string.find(XML_string,sensorID_1)          -- vind de eerste sensor op uid
    p = string.find(XML_string,"<currentpowerusagewatts>",i)          --zoek voor de eerste verschijning van <currentpowerusagewatts> na uid
   CloseInBoiler=string.sub(XML_string,p+0,p+0)  --het verbruik is 5 karakters na  <currentpowerusagewatts> - i.e. 24-26
    commandArray[1] = {['UpdateDevice'] = CloseInBoiler.."|0|"..CloseInBoiler} --stuur geupdate waardes naar Domoticz
            print("temp returned = ".."'"..CloseInBoiler.."'")
        end
    end
return commandArray
Edwin
Re: script help
Postby yjb » Thu Jan 05, 2017 6:01 pm
Without looking further it seems that you are missing the closing quote of the appliances branch:
</appliances>
yjb
Re: script help
Postby Edwin » Thu Jan 05, 2017 8:12 pm
Thanks for your help,
But where you mean?
Edwin
Re: script help
Postby yjb » Thu Jan 05, 2017 8:52 pm
Since you start the entire definition with the following tag (appliances):
<appliances>
Everything that follows is part of that definition, but at some point XML expects an "ending" tag as well. As definitions are balanced, the 1st tag is also the closing tag of the entire definition
</appliances>
There might be other stuff wrong, but from an XML perspective you are missing a closing delimiter.
yjb
Re: script help
Postby Edwin » Thu Jan 05, 2017 10:44 pm
Sorry this is the xml file:
<?xml version="1.0" encoding="iso-8859-1" standalone="yes"?>
<appliances>
if ((Request.get["mac"] != undefined) && (Request.get["mac"] != ''))
$macfilter = Request.get["mac"]
else
$macfilter = ''
/if
foreach Plugwise.Appliances
$appliance = $_Value
if (($macfilter == '') || ($macfilter == $appliance.Module.MacAddress))
echo "<appliance>"
echo "<macaddress>",$appliance.Module.MacAddress,"</macaddress>"
echo "<name>",$appliance.Name.Replace("'","`").Replace("&","+").Replace("<","("),"</name>"
echo "<currentpowerusagewatts>",$appliance.PowerUsage,"</currentpowerusagewatts>"
echo "</appliance>\n"
/if
/foreach
</appliances>
The one in my first post is the outcome in internet explorer.
I think its something else or am i wrong?
Edwin
Re: script help
Postby yjb » Fri Jan 06, 2017 8:11 am
I'm sorry, I can't help you with the lua stuff, as I do not really have experience. I would; check again in a flatfile editor that the trailing /appliances is really part of the xml (as it should be).
yjb
Re: script help
Postby Edwin » Fri Jan 06, 2017 9:02 am
Ok
Thanks for youre help
Edwin
cron
