analog cable to IP converters?
olof
Post by olof »
At my gate I have an analog Siedle Vario intercom system which I want to change. To an IP-based video-intercom system.
But I want to use the existing Siedle wiring (10-12 wire ´bus´ system) instead of having to dig up the garden and put in CAT6 cabling.
So, are there any ´devices´ that are able to convert or transmit IP signals over such wiring? Total length of this wiring is around 25 meters
thanks in advance for any tips
Olof
raymonvdm
Re: analog cable to IP converters?
Post by raymonvdm »
Do you have a picture of the wire? You can try to use the kabel as UTP (without the twist) maybe it just works due to the limited cable lengt?
Post-IT
Post by Post-IT »
2N has their 2Wire module system. It delivers IP and PoE over two wires. They also have a good intercom system. I've installed several IP Audio and Video Kits.
www.2n.cz
