Pulse probe for Elster V100 watermeter
Posted: Wed Dec 03, 2008 1:28 am
by Jeroen Bartels
I've been trying to get a pulse probe for my Elster V100 watermeter.
My watermeter is pulse ready but I have a hard time findig a reed probe for it. I bought a normal reed contact for it but that's not working properly.
This watermeter sold over 50 million pieces worldwide so the probe should be sold seperately somewere...
Has anyone of you bought one?
Posted: Fri Dec 05, 2008 3:14 pm
by Sooty
I think this is the right one although you would have to check with them to be sure.
http://www.mytub.co.uk/product_informat ... uct=367424
Seems a bit expensive for a reed switch. I got a pulse unit for my Elster gas meter from these people.
If you would like me to check if it's the right one and / or help with the purchase / postage, just let me know.
Paul..
Posted: Wed Dec 10, 2008 9:51 pm
by DJF3
JayBee,
Did you manage to find it? Have you talked to Mytub.co.uk?
I have the same watermeter, looking for the same thing.
/DJ
Posted: Wed Dec 10, 2008 11:40 pm
by Jeroen Bartels
I finally managed to do it with a normal reed contact. Bought it at Conrad.
Bestnr.: 502036 - 89
It's a really small one and therefore you have to place it in the right spot.
I do get a pulse now every ,5 liter and I will order the RFX meter set tomorrow.
Posted: Wed Dec 10, 2008 11:59 pm
by Pieterpaul
Can you tell me how & where you place the reed contact? With a picture maybe? Do you think it would work for the one in
http://www.domoticaforum.eu/topic.asp?TOPIC_ID=1385 as well?
Thanks, PP
Posted: Thu Dec 11, 2008 9:23 am
by Jeroen Bartels
If you look at the picture above you see a black dot left and up from the serial number. That's a hole that is ment for the reed relais. That watermeter is pulse'ready'.
I didn't have to take anything apart.
Posted: Thu Dec 11, 2008 10:26 am
by Pieterpaul
Too bad, even though mine is claimed to be pulse ready, it doesn't have a hole [:(]
Posted: Thu Dec 11, 2008 4:43 pm
by Jeroen Bartels
And making a hole in your watermeter would not be a good idea. [:p]
Posted: Thu Dec 11, 2008 5:38 pm
by Pieterpaul
I can always try [:o)]
Posted: Thu Dec 11, 2008 5:45 pm
by Herbus
Hi Jaybee,
I'm lucky. Checked my meter and it seems to be the same.
Did you remove the black plastic cap or did you place the reed contact on it?
Jos
Homeseer 2.2.66
ACT TI203, DooNetwork
Posted: Thu Dec 11, 2008 9:28 pm
by Jeroen Bartels
Just remove it. it's just a cap (but its tight).
The reed contact is suposed to go in the bigger hole.
Posted: Fri Dec 19, 2008 3:24 pm
by Herbus
Good suggestion! Works fine. Good and cheap solution.
Homeseer 2.2.66, HSTouch
ACT TI203, DooNetwork, RFXCom, RFXMeter (gas, electricity, water), Oregon THGR 228 N
