I made an automation to drive a sliding gate. Everything analogue using two relays and two contactors. The gate is driven bay a gear motor 3x400V.
Recently I put a radio remote control module. The module itself worked good until I connected it to the existing scheme.
The module looks to be influenced by induction of the relays and contactors. I mean when I press a button of the remote control is should close a micro relay inside and it does that, but from time to time immediately after closing the micro relay is switched off or vice versa (it is closed when I try to switch it off).
I solved the influence of relays (12 V dc) putting a diode on their coil.
I also solved also the influence of contactors (230 V ac) using two capacitors of 100 micro. Everything worked perfect before I connected the 3x400V motor.
After motor connection the remote module is again influenced and gives errors in switching (on and off).
I also mention that the command (12 V dc ) uses a cable in a steel pipe and supply cable for 3x400 V motor is also in a different steel flexible tube. I use a supply source of 12V dc/3 A. The comsumption is less then 1 A...
What do you suggest to try in order to reduce the motor influence?
Thanks in advance!
Remote module influenced by induction (I think...)
Jump to
- Forum matters
- ↳ News Forum
- Hardware Forum (English)
- ↳ Z-Wave Forum
- ↳ Fibaro
- ↳ Plugwise Forum
- ↳ Gadgets Forum
- ↳ Visonic Alarm systems
- ↳ LEDS, DMX & Lights Forum
- ↳ Opentherm Gateway Forum
- ↳ 1-Wire Forum
- ↳ PLCBUS Forum
- ↳ Smart Metering Forum
- ↳ ZigBee Forum
- ↳ Toon news and information
- ↳ Manuals/tutorials
- ↳ Toon Apps
- ↳ Toon Rooting
- ↳ Toon Hardware
- ↳ Toon Firmware
- ↳ Toon external control
- ↳ Toon miscellaneous
- ↳ Toon software development
- Software Forum (English)
- ↳ Announcements & News
- ↳ Linux Forum
- ↳ Windows Forum
- ↳ DomotiGa Forum
- ↳ OpenHAB Forum
- ↳ MQTT & Node.js
- Projects Forum (English)
- ↳ Home Automation Projects
- ↳ Bwired Forum
- ↳ Homeseer algemeen Forum
- ↳ Homeseer Scripts Forum
- ↳ Homeseer HStouch Forum
- ↳ Homeseer Plugins Forum
- Other (English)
- ↳ Off Topic
- ↳ Downloads & Links Forum
- ↳ Domoticaboek Heino Peters
- ↳ Dealers Corner
- ↳ Test
