Alternative for Qees power strip?
Re: Alternative for Qees power strip?
I bought a single smartplug and the 6 port smartplug and i`m polling it every minute from within Domotiga ( which is polling al my Measurment Z-Wave devices)
Any more News on this device?
Did anyone get it to read power from each single power outlet?
Is nuonenergiewinkel.nl the only place to get in Europe?
Power readings from every socket is working fine in Homeseer, accumulated power per socket also. Accumulated power for all sockets is not working like it should.
How are you using this device in HomeSeer. I`m trying to poll them all but it seems to fail most of the time
Any word on the powerreadings somewhere else it was states that the powerreading of the individual sockets did not match the total power reading, is this still the case?
I can confirm that the power reading of individual sockets do not match the total power reading; The total power reading is identical with the power reading on socket 1.
I have 2 powernodes (Nuon Smartplug 6) in use with Homeseer.
geert-jan wrote:I can confirm that the power reading of individual sockets do not match the total power reading; The total power reading is identical with the power reading on socket 1.
How are you polling the devices for there power reading because they seem to fail in my setup?
Thanksgeert-jan wrote:I can confirm that the power reading of individual sockets do not match the total power reading; The total power reading is identical with the power reading on socket 1.
My first reaction seems lost 'in the cloud', hereby a retry.
I poll the smartplug in two ways;
- via a 'standby killer' script that monitors the actual energy consumption and switches off the socket when the connected device is in standby.
This (vb) script runs every 5 minutes, does a hs.PollDevice(deviceId), followed by 'some action', waits for 45 seconds, and then polls the next socket. The wait is used to prevent a peak load on the z-wave network. Another advantage is that the GREEN LED does not flash if you poll the smartplug with an interval lower than 2 minutes .
- via an event that polls the total consumed energy.
This script runs once per hour and executes the following homeseer action per socket: ' Select Z-Wave Action / Poll a Node' (2 smartplugs times 6 sockets = 12 actions in total)
Would you like to share the vb script ?
Maybe i just created the same solution using an event (poweroff is a bridge to far for now)
Click to zoom
Can you tell me which ZDK u are running on the Nuon Devices (using http://homeseerurl/zwho)
Click to zoom
3.33 (Unknown ZDK Version) App: 4.21
3.33 (Unknown ZDK Version) App: 4.20
My standby killer script. I run the script as you showed in your screen dump, difference is that the script is called instead the 'z-wave command'. Every socket is polled once per 5 minutes, with an interval of 45 seconds between each socket. I have an event per power node, so the script will take about 270 seconds to run, which is less that the poll interval of 300 seconds.
Please note that the total execution time of the script shall be lower than its interval; when polling more than 6 devices you should decrease the wait (e.g. divide the poll interval by the number of devices to poll).
The script monitors the actual power consumption. If two measurements indicate that the actual power consumption is below a threshold, the script will switch of a device, i.e. the powernode socket.
The script:
Save the script in a file, with extension '.vb and run the script as following:
Where:
The script:
Sub main(parm as Object)
Dim deviceId As String
Dim deviceIdCurrentPower As String
Dim powerLevel as Integer
Dim previousPower as Integer
Dim currentPower as Integer
Dim arrParm() As String
' Extract parameters
arrParm = parm.ToString.Split(";")
deviceId = arrParm(0)
deviceIdCurrentPower = arrParm(1)
powerLevel = arrParm(2)
previousPower = hs.DeviceValue(deviceIdCurrentPower)
' Get current power consumption for devices
hs.PollDevice(deviceIdCurrentPower )
hs.WaitSecs(0.1)
currentPower = hs.DeviceValue(deviceIdCurrentPower)
' Turn off device:
' if device is On
' and was on in previous check also (to prevent switching off device directly)
if hs.IsOn(deviceId)
if previousPower > 0 AND previousPower < powerLevel AND currentPower < powerLevel
hs.Transmit(deviceId, "off")
end if
end if
End Sub
<scriptname>.vb("main", <device Id>;<device Id 2>;<power in 0.01 Watt>")
- scriptname = the name of the script
deviceId = the device to switch off
deviceId 2 = the device that gives the actual power consumption
power = the limit to switch off 'deviceId'. The power is in units of 0.01 Watt, i.e. 200 means 2 Watt
using domotiga now without z-wave and would like to use this device, what do i need to connect this item to my pc?
I have used Domotiga in the past and to use this device you should have a Aeon Labs Z-Wave stick (and both should be not to far away of each other. This problem is solved if you have a Z-Wave network because each device wil act as a repeater to build a mesh network)
thank u, will order one!
