Plug-in module for outside
kriz83
Post by kriz83 »
I'm looking for a Z-Wave (or something else) plug-in module for switching my christmas lights outside.
The module will be approx 20cm above the ground.
Will IP44 suffice, or is this not enough ?
Kriz
wwolkers
Re: Plug-in module for outside
Post by wwolkers »
IP Explanation and Ratings
EN 60529 outlines an international classification system for the sealing effectiveness of enclosures of electrical equipment against the intrusion into the equipment of foreign bodies (i.e. tools, dust, fingers) and moisture. This classification system utilizes the letters "IP" ("Ingress Protection") followed by two or three digits. (A third digit is sometimes used. An "x" is used for one of the digits if there is only one class of protection; i.e. IPX4 which addresses moisture resistance only.)
Degrees of Protection - First Digit
The first digit of the IP code indicates the degree that persons are protected against contact with moving parts (other than smooth rotating shafts, etc.) and the degree that equipment is protected against solid foreign bodies intruding into an enclosure.
0 No special protection
1 Protection from a large part of the body such as a hand (but no protection from deliberate access); from solid objects greater than 50mm in diameter.
2 Protection against fingers or other object not greater than 80mm in length and 12mm in diameter.
3 Protection from entry by tools, wires, etc., with a diameter of thickness greater than 1.0mm.
4 Protection from entry by solid objects with a diameter or thickness greater than 1.0mm
5 Protection from the amount of dust that would interfere with the operation of the equipment.
6 Dust tight.
Degrees of Protection - Second Digit
The second digit indicates the degree of protection of the equipment inside the enclosure against the harmful entry of various forms of moisture (e.g. dripping, spraying, submersion, etc.)
1 Protection from dripping water.
2 Protection from vertically dripping water.
3 Protection from sprayed water.
4 Protection from splashed water.
5 Protection from water projected from a nozzle
6 Protection against heavy seas, or powerful jets of water.
7 Protection against immersion.
8 Protection against complete, continuous submersion in water.
kriz83
Post by kriz83 »
Indeed I have read this on many sites.
But opinions vary whether to use this under some kind of roof or if it can be used 'in open air'.
I'm just wondering what you guys think/are doing.
wwolkers
Post by wwolkers »
Personally, I would always go for 6 or higher for outside.
kriz83
Post by kriz83 »
But does any plug-in module of this kind exist ?
