At home I have floor heating on 3 different floors and each floor is controlled by a thermostat that is wired to the electrovalve that open close the water circuit. As I am often away for work I would like to install a thermostat that I can remotely controlled. Is there any thermostat model that can be wi-fi controlled by a pc?
Cheers!
Andrea
Wi-fi controlled thermostat
Re: Wi-fi controlled thermostat
Here you go: http://www.heatmisershop.co.uk/thermost ... mostat-p96
I've got 2 of them (2 zones) and they can be operated by a web interface or iOS or android app... there's also perl scripts and php classes to control them from the command line should that be your poison
great thanks a lot!
Looks nice !
Where did u buy em from ?
[EDIT] mmm, i don't have 230V available at my thermostat [/EDIT]
230 volt?
I dont see opentherm as well ?
