http://jointspace.sourceforge.net/download.html
Anybody played with that? Its for philips t.v.'s, if you enable it you will get a json feed to talk to your tv etc, pretty nice. I've got a model that just missed it. I have joint space but not the port that is open. But maybe others here do.
I believe the new samsung models can also be used with uploading your own apps via the sdk.
In the end you would want -> if t.v. is on, what is being watched, or channel program perhaps. Not saying its possible, but on the philips it should.
Joint spaces (json philips)
- Snelvuur
- RDNZL
Re: Joint spaces (json philips)
Did you enable jointspace on your TV with the remote by entering "jointspace"?
I have also an older Philips without json but jointspace is available/working.
Regards, Ron.
- Snelvuur
I enabled it, but no json sadly. The iphone remote does work, but i rather want to get data from the t.v. myself.
My TV is a 32PFL7404 module without JointSpace support so i first need to replace the TV.
