Monitoring Remeha devices
Re: Monitoring Remeha devices
Postby MindBender » Tue Mar 15, 2011 7:34 pm
Yes. This plugin allows you to control the setpoint and read the current temperatures. I supports a regular serial port and a NetMedia SitePlayer serial port over Ethernet. After testing is done, I will release a first version and I hope to add advanced configuration and monitoring features to later releases. It won't be a free plugin, though.
MindBender
Postby yjb » Tue Mar 15, 2011 7:55 pm
Will this plugin also support the gateway, or only the cable that connects to the heater itself?
yjb
Postby MindBender » Tue Mar 15, 2011 8:23 pm
yjb wrote:Will this plugin also support the gateway, or only the cable that connects to the heater itself?
Just the gateway
MindBender
Postby MaikelK » Mon Oct 14, 2019 6:13 pm
Does anybody still has the links to this project?
I have an on/off relay on my Calenta and dont want to invest in a modulating relay for my Evohome.
I do like to know boiler % and the temperatures etc.
If i read this topic correctly this should be possible. But I cant open the links i get a bad gateway error.
MaikelK
Postby MindBender » Thu Oct 17, 2019 9:15 am
Do you need a Gateway? I think I still have it laying around, because it was a bit of a pity to toss it out.
MindBender
Postby MaikelK » Thu Oct 17, 2019 9:27 am
I don’t need the gateway because then I would also need to control the boiler with opentherm, which is not a good option.
So if someone has the information of the links etc. it would be great!
MaikelK
Postby MindBender » Thu Oct 17, 2019 10:19 am
No, you do not; The Gateway takes care of operating the boiler, using OpenTherm. You only need two instruct the GateWay to do things for you, protocol documented here:
http://www.nerdclub.nl/remeha_gateway/index.html
MindBender
Postby hvxl » Sat Oct 19, 2019 5:21 pm
MaikelK wrote:So if someone has the information of the links etc. it would be great!
The missing links have all been archived by the Wayback Machine.
Previous
Return to Hvac, Heating Opentherm Forum
cron
