XSL for Recom(Remeha) configuration and language XML files
Posted: Sun Feb 19, 2012 12:06 pm
My plan is to connect an Arduino to a Remeha Avanta to get the heater diagnostics data via the serial interface into the MySQL database on my Synology NAS. The hardest part is understanding what the Remeha sends. I already looked on this forum and the Blog and I saw that a lot of work already has been done. I took some time to create an XML stylesheet (XSL) to make the XML configuration files, that come with the Recom software, easier to read. My first version is attached to this post. To make it work, you need to do the following:
1) Copy the attachment into the Recom configuration folder.
2) Add the following to all XML configuration files:
When you double click the XML, after making the change, the file is displayed as 'friendly' HTML using simple tables. Another nice feature is that the XSL also uses the language files (in this example the dutch one) to translate the codes to readable text. Another thing the XSL does is proper processing the 'node-ref' elements.
I hope you will find it is useful. You can modify the XSL to suit your needs, the current version is enough for me to get started on my project.
Freddy
<?xml-stylesheet type="text/xsl" href="remeha.xsl"?>
Freddy
