HS3 MQTT Plugin
Moderator: Willem4ever
Re: HS3 MQTT Plugin
in the "MQTT / Publish" configuration screen you can change the default topic name. (for the value update only, the string value is always published using the default topic)
Geert-Jan
Geert-Jan
- Member
Re: HS3 MQTT Plugin
Hi Geert-Jan
After some months using your plugin, since few days ago it's crashing often.
I turned on LOGLEVEL_ERROR and I found a lot of errors: "Error: Could not get device EDO. Exception=System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto. en HSPI_MQTT.HS3MQTT.getEDO(DeviceClass dv)"
"Referencia a objeto no establecida como instancia de un objeto. en " minds: "Reference to object isn't established as a instance of the object at..."
I'm using HS 3.0.0.297 and plugin 1.5.0.0 on Windows 7 Ultimate 32 bits
I don't know if it's related to the problem. Any hints to start troubleshooting? My system rely a lot on MQTT and your plugin and starting from scratch is something I would like to avoid.
Thank you.
Mario
Thank you.
Mario
Re: HS3 MQTT Plugin
Mario,
did you upgrade from a previous MQTT version recently?
The error points to the fact that the plugin cannot find the MQTT configuration stored for the device.
Can you check the content of the MQTT plugin / Subscription page. You should egt an overview of all the MQTT topics, including the Homeseer devices, you are subscribed to. Next, select the 'Edit' button for one of the homeseer devices, the subpage MQTT should show the device configuration. What do you see in the logging if you change an item and click save?
Geert-Jan
Geert-Jan
- Member
Re: HS3 MQTT Plugin
Hi Geert-Jan
Thank you very much for your quick anwer. Thanks to your hints I think it's working fine again.
I went into each device selecting the "Edit" button and everything looked normal, so I went again into each one of the devices pressing the Save button in the MQTT tab and the Done button in the main tab. This did the trick, now I don't see errors anymore.
Thank you!
Thank you!
Re: HS3 MQTT Plugin
Everytime i start up Homeseer, I find that "Monitor MQTT Broker" is disabled?
Can I alter this? Is this a Bug?
See attached.
See attached.
- Screen Shot 2018-03-28 at 14.37.08.png (233.31 KiB) Viewed 36148 times
Re: HS3 MQTT Plugin
the 'monitor' broker setting is non-persistent. Idea at the moment of implementing was to prevent a flood on subscriptions, so it is not a bug - it is a feature.
Geert-Jan
Geert-Jan
- Member
Re: HS3 MQTT Plugin
Geert-jan,
have you seen my topic ?
i was wondering if you know if this could be solved in the plugin or if this is a problem in HS ?
viewtopic.php?f=74&t=11993
Re: HS3 MQTT Plugin
I was trying to troubleshoot an MQTT Publish but the full list of devices won't render (I'm on the newest version of Chrome Beta) on the MQTT Publish settings page. Anyone else having this issue (this was both before and after the update to the latest HomeSeer version)?
Re: HS3 MQTT Plugin
Nevermind, figured it out. It was due to not assigning a room to my Outdoor "Floor" devices. Once I added an "Outdoor" room they started showing up.I was trying to troubleshoot an MQTT Publish but the full list of devices won't render (I'm on the newest version of Chrome Beta) on the MQTT Publish settings page.
Re: HS3 MQTT Plugin
Hey all,
I’ve recently installed the MQTT plugin for HS3 (Windows) and am using it with Eclipse Mosquitto MQTT, Home Assistant (Hass.io), and Node Red. My issue is that every day or two (I haven’t been able to pin down a pattern or a cause yet) under Publish, some of my Topic names are deleted and the Value and String are cleared as well. This of course causes Node Red to be unable to communicate with those devices. This is getting quite frustrating and I can’t seem to figure it out. Any help or suggestions on this would be appreciated. Thank you.
Re: HS3 MQTT Plugin
is HS restarted in the meanwhile?
Can you enable the logging in the MQTT plugin (MQTT Config page, set loglevel to WARN). What is in the logging when you disable and enable the plugin. It seems that the settings are not stored in the database, maybe the logging gives me more info.
Geert-Jan
Geert-Jan
Re: HS3 MQTT Plugin
I’m so sorry for the long delay. I do restart HS3 from time to time but I can’t correlate the issue with restarting HS3 from time to time.
Below are the warning logs for disabling and enabling the MQTT plugin:
Feb-17 13:13:06
Plug-In
Finished initializing plug-in MQTT
Feb-17 13:13:06
Starting Plug-In
MQTT loaded in 2527 milliseconds
Feb-17 13:13:06
Starting Plug-In
Plugin MQTT started successfully in 1833 milliseconds
Feb-17 13:13:06
MQTT
Info: start
Feb-17 13:13:05
MQTT
Info: UpgradeMQTTPublishDevices: Upgraded 0 devices
Feb-17 13:13:04
Starting Plug-In
Initializing plugin MQTT ...
Feb-17 13:13:04
Info
Plugin MQTT has connected. IP:127.0.0.1:54935
Feb-17 13:12:29
MQTT
Info: stop
Feb-17 13:12:29
Plug-In
Shutting down Plug-In: MQTT
Please let me know if any other information you may need. Thank you!
Feb-17 13:13:06
Plug-In
Feb-17 13:13:06
Starting Plug-In
Feb-17 13:13:06
Starting Plug-In
Feb-17 13:13:06
MQTT
Info: start
Feb-17 13:13:05
MQTT
Feb-17 13:13:04
Starting Plug-In
Feb-17 13:13:04
Info
Feb-17 13:12:29
MQTT
Info: stop
Feb-17 13:12:29
Plug-In
- Member
Re: HS3 MQTT Plugin
Hi.
How can I remove a subscription from the list (unsubscribe to a topic)?
I don't want to delete de HS device, only the subscription so the plugin ignores it.
Thank you.
Mario
Thank you.
Mario
