HS3 MQTT Plugin
Alles m.b.t. de Homeseer MQTT Broker Plugin van Willem Eradus (Dutch Forum)
Moderator: Willem4ever
Re: HS3 MQTT Plugin
Postby dad » Mon Sep 21, 2015 12:53 pm
Hi Geert-Jan,
Thanks, I have updated the mosquitto broker to 1.4.3 and that is up and working with the plug in on the RPi2.
Just need to work on getting it to send out information!
Thanks
Dad
dad
Re: HS3 MQTT Plugin
Postby raymonvdm » Wed Sep 23, 2015 9:19 pm
I`m also running the MQTT Plugin on HS3 (Windows) and it is picking up the data my raspberry pi is publishing using crontab (temperature every minute) But just found out my SD card died so i cannot give the example of the crontab :cry:
But i now would like to know how to use the possibilities MQTT is giving us. I would like to have graphs of several temp sensors. I have done this in the past with some help using mysql. But is this also possible using MQTT ?
The cron entry
#* * * * * php /home/domotiga/php_get_status_homeseerDB2V2.php T 3 > /etc/snmp/woonkamert.txt
#* * * * * php /home/domotiga/php_get_status_homeseerDB2V2.php T 6 > /etc/snmp/woonkamerv.txt
The script which was created for me
<?php
$link = mysql_connect("192.168.110.188", "homeseer", "homeseer");
mysql_select_db("HomeSeerDB2", $link);
array_shift($argv);
$vid = 'value';
$result = mysql_query("SELECT value FROM tbldevices where hc='$argv[0]' and dc='$argv[1]' order by id desc limit 1");
while($row = mysql_fetch_array($result)){extract($row);echo $$vid;}
mysql_close($link);
The output (which is picked up by Cacti)
cat /etc/snmp/kantoort.txt
212
How do i change this to MQTT because there is an MQTT (free) plugin and not a insert to MySQL (free) plugin for HS3
raymonvdm
Re: HS3 MQTT Plugin
Postby geert-jan » Mon Sep 28, 2015 6:55 am
the MQTT plugin writes the MQTT data in a Homeseer device, the device values are available in events and scripts.
I use 'location2' as device type; Electra, Water, Gas.
The script below is called from a Homeseer event every hour, and writes the actual device values for each device where the type is 'Electra', 'Gas' or 'Water' to a MySQL database. The types can easily be extended, with Temperature, Humidity, etc.
Imports MySql.Data.MySqlClient
Sub main(Optional ByVal pParms As String = "")
  Dim en
  Dim dv
  en = hs.GetDeviceEnumerator
  if IsReference(en) Then
    do while not en.Finished
      dv = en.GetNext
      if not dv is nothing then
          select case dv.location2(hs)
          case "Electra"
            writeDB("electra", dv, 1000)
          case "Gas"
            writeDB("gas", dv, 1000)
          case "Water"
            writeDB("water", dv, 1)
          end select
      end if
    loop
  end if
End Sub
Sub writeDB(ByVal dbTable as String, ByVal dvRef as Object, devFactor as Integer)
  Dim conn As MySqlConnection
  Dim myCommand As New MySqlCommand
  Dim timestamp As String
  Dim devValue As Integer
  timestamp = Datepart("yyyy",Now()) & "-" & Right("0" & DatePart("m",Now()),2) & "-" & Right("0" & DatePart("d",Now()),2) & " " & Right("0" & DatePart("h",Now()),2) & ":" & "00:00"
  if NOT dbTable = Nothing
    conn = New MySqlConnection()
    conn.ConnectionString = "server=<ip address>; user id=<user id>; password=<password>; database=<database>"
    devValue = Convert.Toint64(dvRef.devValue(hs) * devFactor)
    Try
          conn.Open()
          myCommand.CommandText = "INSERT INTO " _
      & dbTable _
      &  " (deviceName, timestamp, deviceValue, deviceType, deviceId)" _
      & " VALUES ('" _
                  & dvRef.Name(hs) & "','" _
                  & timestamp & "','" _
                  & devValue  & "','" _
                  & dvRef.location2(hs) & "','" _
                  & dvRef.Code(hs) & "')"
      myCommand.Connection = conn
      myCommand.ExecuteNonQuery()
      conn.Close()
   Catch myerror As MySqlException
      hs.writelog ("datalog", "Error Connecting to Database: " & myerror.Message)
   End Try
end If
End Sub
Sub updateCounter(Optional ByVal pParms As String = "")
    dim electraTotal as double
    dim dev1 as integer
    dim dev2 as integer
    dim dev3 as integer
    Dim arrParm() As String
    ' Extract parameters
    arrParm = pParms .ToString.Split(";")
    dev1= arrParm(0)
    dev2= arrParm(1)
    dev3= arrParm(2)
    electraTotal = hs.devicevalueex(dev1) + hs.devicevalueex(dev2)
    hs.setdevicevaluebyref(dev3, electraTotal, true)
    hs.setdevicestring(dev3, electraTotal & " KWh", true)
end sub
Adapt the fields between'<>' in conn.ConnectionString = "server=<ip address>; user id=<user id>; password=<password>; database=<database>" to your configuration.
Geert-Jan
geert-jan
Re: HS3 MQTT Plugin
Postby Jeffrey » Fri Oct 09, 2015 4:08 pm
I would really like it if the plugin can also publish messages.
My usecase is that I would like to create some Mysensors based stuff and control them via MQTT. There is a plugin for mysensors, but it's limited in functionality and supported sensors/actors. If your plugin can send MQTT messages (based on created devices in Homeseer) it doesn't matter what actor is on the other side.
Jeffrey
Re: HS3 MQTT Plugin
Postby raymonvdm » Fri Oct 09, 2015 4:33 pm
This is already possible on the /MQTTPublish page u can select devices of which the status should be published
raymonvdm
Re: HS3 MQTT Plugin
Postby Sparkman » Wed Nov 11, 2015 3:41 pm
Hi Jeffrey, were you able to make this work? I'm looking to do the same. Did you run into any issues?
Thanks
Al
Sparkman
Re: HS3 MQTT Plugin
Postby Moskus » Thu Nov 12, 2015 8:31 am
You should really post this on the HomeSeer forum. There are people looking for it! :)
HSPro 2.5.0.60, X10 CM11, Z-wave Aeon Stick2, RFXCOM, Script Connector, BT connector, DI Connector, DooNetwork, HSTouch, Squeezebox plugin, iTach WF2IR & GC-100-6 with UltraGCIR, BLicon, DenonAVR, WebcamXP, Jon00s MaxiBee and Webpage builder
Moskus
Re: HS3 MQTT Plugin
Postby Jeffrey » Thu Nov 12, 2015 1:27 pm
Hi Al,
Did not got around to test this unfortunatelly.
Jeffrey
Re: HS3 MQTT Plugin
Postby raymonvdm » Thu Nov 12, 2015 1:50 pm
The plugin is publishing values without issue :D
raymonvdm
Re: HS3 MQTT Plugin
Postby Sparkman » Thu Nov 12, 2015 7:18 pm
Hallo Geert-Jan,
Thanks for making the plugin available. I've installed it and it looks to be working well although I still need to test with a MQTT broker. I have a feature request already though :D Would it be possible to provide sorting on the MQTTPublish page and perhaps a way to not load all devices at the same time? I have over 1500 HS3 devices, so this page loads very slowly and sometimes times out. When it does load, the devices are not grouped, so hard to find items.
Thanks again!
Al
Sparkman
Re: HS3 MQTT Plugin
Postby Sparkman » Thu Nov 12, 2015 7:19 pm
Jeffrey wrote:Hi Al,
Thanks for letting me know.
Cheers
Al
Sparkman
Re: HS3 MQTT Plugin
Postby geert-jan » Fri Nov 13, 2015 7:36 am
@Sparkman: thanks for the feature request. Sorting the list should not be a big problem. Reducing the devices to load, e.g. with a filter, will take some more time.
Geert-Jan
geert-jan
Re: HS3 MQTT Plugin
Postby Sparkman » Fri Nov 13, 2015 3:44 pm
Thanks Geert-Jan! Just a thought for a filter, a manually created "whitelist" where I could enter the reference IDs of the devices I want to publish would be ok for my needs. Thanks for considering it.
Cheers
Al
Sent from my iPhone using Tapatalk
Sparkman
Re: HS3 MQTT Plugin
Postby tominthevan » Sun Nov 15, 2015 9:37 am
I am trying to use Geert-Jan's MQTT plugin and a Raspberry Pi. As per the installation instructions I have:
1. copied the files HSPI_MQTT.exe and Mqttlib.dll to the Homeseer top level folder (/usr/local/Homeseer on the Pi)
2.copied (for now, the original) file hspi_mqtt.config to the config folder in the Homeseer top level directory.
I've restarted Homeseer (several times). The instructions say to go to the Homeseer interfaces page. I can't find a page labeled interfaces but I suspect it might be the the manage plugins page. On that page I can find several plugins to manage, but none associated with MQTT.
Where am I going wrong?
Tom
tominthevan
Re: HS3 MQTT Plugin
Postby geert-jan » Sun Nov 15, 2015 1:10 pm
Which version of the plugin did you install? For the raspberry you need the version with 'rpi' in the file name.
Gr. Geert-Jan
geert-jan
PreviousNext
Return to Homeseer MQTT Plugin Forum
cron
