is it allowed to use a = sign in your strings ?
Alles m.b.t. de Homeseer MQTT Broker Plugin van Willem Eradus (Dutch Forum)
Moderator: Willem4ever
Postby vincenttor » Sun Mar 04, 2018 1:49 pm
Well the thing i bumped into is this.
Blueiris supports mqtt now, so i thought let's give it a try.
Works actually quite good , back and forth with receiving and sending strings.
But since BlueIris decided to use strings like these :
camera=cam1&preset=17
It is not working , i guess this is maybe a limitation from homeseer ?
See the video i have made down here.
Is there something that can be done ?
(yes i know there is a blueiris plugin but i'd like to use mqtt only since its light weight and working with most home automation software.)
vincenttor
Re: is it allowed to use a = sign in your strings ?
Postby vincenttor » Sat Mar 10, 2018 8:59 am
nobody with the same "problem" ?
since i can't seem to change the strings from blueiris im a bit stuck with this.
Also with the other mqtt plugin a same sort of problem excists when using the = sign, this plugin thinks that the payload comes after the =.
vincenttor
Postby vincenttor » Sat Apr 07, 2018 7:59 am
nobody that has a solution for this ?
vincenttor
Postby Akatar » Sat Apr 07, 2018 9:48 pm
probably not
Akatar
Postby geert-jan » Tue Apr 10, 2018 7:00 am
The issue is that the URL parameters (as used in the Homeseer webpages) are encoded as 'parameter=value'. If the 'value', i.e. the event parameter, contains the '=' sign, there is no way to differentiate between a 'parameter=value' and a value containing the '=' sign. They are all handled as 'parameter=value'.
What may work, but I cannot test this at the moment: use %3D instead of the '=' sign.
Geert-Jan
geert-jan
Postby vincenttor » Sat Apr 14, 2018 8:18 am
Thanks Greet,
will see if i get this working.
have to get everything up and running again.
vincenttor
Return to Homeseer MQTT Plugin Forum
