im trying to change the room setpoint via the otmonitor tool.
That seems to have no effect, log is attached
I´ve read that some thermostats do not support remote setpoint override - is there a thermostat, which supports remote overrides and is worth changing to?
Thanks
20:13:37.318512 T001D0000 Read-Data Solar storage temperature: 0.00
20:13:37.695391 BF01D0000 Unk-DataId Solar storage temperature: 0.00
20:13:38.316251 T001E0000 Read-Data Solar collector temperature: 0.00
20:13:38.693381 BF01E0000 Unk-DataId Solar collector temperature: 0.00
20:13:39.321336 T00210000 Read-Data Exhaust temperature: 0.00
20:13:39.690581 B40210025 Read-Ack Exhaust temperature: 0.14
20:13:40.310026 T10810200 Write-Data Message ID 129: 512
20:13:40.688602 BD0810200 Write-Ack Message ID 129: 512
20:13:41.307097 T00001100 Read-Data Status: 00010001 00000000
20:13:41.684208 B4000112A Read-Ack Status: 00010001 00101010
20:13:42.305234 T90101300 Write-Data Room setpoint: 19.00
20:13:42.680830 B50101300 Write-Ack Room setpoint: 19.00
20:13:43.301135 T10171300 Write-Data Room Setpoint CH2: 19.00
20:13:43.678856 BD0171300 Write-Ack Room Setpoint CH2: 19.00
20:13:44.299500 T90181308 Write-Data Room temperature: 19.03
20:13:44.674970 B50181308 Write-Ack Room temperature: 19.03
20:13:45.296281 T80800000 Read-Data Message ID 128: 0
20:13:45.674310 BE0800000 Data-Inv Message ID 128: 0
20:13:46.296041 T10821653 Write-Data Message ID 130: 5715
20:13:46.671554 BD0821653 Write-Ack Message ID 130: 5715
20:13:47.290245 T00001100 Read-Data Status: 00010001 00000000
20:13:47.668406 B4000112A Read-Ack Status: 00010001 00101010
20:13:48.288204 T90012234 Write-Data Control setpoint: 34.20
20:13:48.419227 Command: TC=17.35
20:13:48.442341 TC: 17.35
20:13:48.667218 B50012234 Write-Ack Control setpoint: 34.20
20:13:49.285837 T90082120 Write-Data Control setpoint 2: 33.13
20:13:49.662895 B50082120 Write-Ack Control setpoint 2: 33.13
20:13:50.284122 T10380000 Write-Data DHW setpoint: 0.00
20:13:50.660447 BD0380000 Write-Ack DHW setpoint: 0.00
20:13:51.280695 T80200000 Read-Data DHW2 temperature: 0.00
20:13:51.658484 BE0200000 Data-Inv DHW2 temperature: 0.00
20:13:52.278494 T801A0000 Read-Data DHW temperature: 0.00
20:13:52.656514 BE01A0000 Data-Inv DHW temperature: 0.00
20:13:53.305283 T00001100 Read-Data Status: 00010001 00000000
20:13:53.655052 B4000112A Read-Ack Status: 00010001 00101010
20:13:54.273938 T001B0000 Read-Data Outside temperature: 0.00
20:13:54.675747 B401B08E8 Read-Ack Outside temperature: 8.91
20:13:55.269589 T80190000 Read-Data Boiler water temperature: 0.00
20:13:55.647179 B401931DC Read-Ack Boiler water temperature: 49.86
20:13:56.268056 T801C0000 Read-Data Return water temperature: 0.00
20:13:56.645180 B401C1F68 Read-Ack Return water temperature: 31.41
20:13:57.265500 T801F0000 Read-Data Flow temperature CH2: 0.00
20:13:57.641834 B401F215C Read-Ack Flow temperature CH2: 33.36
20:13:58.262905 T00110000 Read-Data Relative modulation level: 0.00
20:13:58.640229 BC0110900 Read-Ack Relative modulation level: 9.00
20:13:59.260316 T00001100 Read-Data Status: 00010001 00000000
20:13:59.636273 B4000112A Read-Ack Status: 00010001 00101010
20:14:00.267770 T80130000 Read-Data DHW flow rate: 0.00
20:14:00.633772 B70130000 Unk-DataId DHW flow rate: 0.00
20:14:01.254870 T001D0000 Read-Data Solar storage temperature: 0.00
20:14:01.630866 BF01D0000 Unk-DataId Solar storage temperature: 0.00
20:14:02.252464 T001E0000 Read-Data Solar collector temperature: 0.00
20:14:02.629791 BF01E0000 Unk-DataId Solar collector temperature: 0.00
20:14:03.250281 T00210000 Read-Data Exhaust temperature: 0.00
20:14:03.626742 B40210025 Read-Ack Exhaust temperature: 0.14
20:14:04.246360 T10810200 Write-Data Message ID 129: 512
20:14:04.625842 BD0810200 Write-Ack Message ID 129: 512
20:14:05.244361 T00001100 Read-Data Status: 00010001 00000000
20:14:05.622171 B4000112A Read-Ack Status: 00010001 00101010
20:14:06.241003 T90101300 Write-Data Room setpoint: 19.00
20:14:06.618255 B50101300 Write-Ack Room setpoint: 19.00
20:14:07.264593 T10171300 Write-Data Room Setpoint CH2: 19.00
20:14:07.615432 BD0171300 Write-Ack Room Setpoint CH2: 19.00
20:14:08.236451 T90181308 Write-Data Room temperature: 19.03
20:14:08.612385 B50181308 Write-Ack Room temperature: 19.03
20:14:09.233677 T80800000 Read-Data Message ID 128: 0
20:14:09.610638 BE0800000 Data-Inv Message ID 128: 0
20:14:10.247657 T10821653 Write-Data Message ID 130: 5715
20:14:10.607174 BD0821653 Write-Ack Message ID 130: 5715
20:14:11.227283 T90020004 Write-Data Master configuration: 00000000 4
20:14:11.605206 B50020004 Write-Ack Master configuration: 00000000 4
