Otmonitor webserver error
rtenklooster
Post by rtenklooster »
For some reason, my outside temperature gets displayed as ???
This happens when I don't even have a outside temperature set using OT=XX.X
I think this is the reason my mobile (iphone site) gives a internal server error. Error is: expected floating point Got ???
Anyone having the same problems?
Re: Otmonitor webserver error
It happens because you don't have an outside temperature set. The iphone web page was not designed to cope with that. I will fix it in a next version.
As a work-around you can download the attached file and unzip it in the directory where your otmonitor program is located. Then point your mobile to http://<your-site>/iphone-fix.html instead of htp://<your-site>/iphone.html.
iphone-fix.zip
(1.42 KiB) Downloaded 308 times
