Remeha set outside temperature using MQTT
Posted: Mon Feb 02, 2015 9:06 pm
by ModbusMan
My OTG is connected to a Rehema iSense thermostat (from 2009) I am using otmonitor running as a daemon on a raspberry pi and communicate with otmonitor using MQTT.
Everything works great as far as reading out data from the thermostat and boiler.
Now I would like to go a step further and send the "outside temperature" to the thermostat. I've tried to publish the value to the MQTT topic "outside" as well as "outsideTemperature". Still not able to see anything on either the otmonitor status or messages webpages.
Is it actually possible to set the outside temperature in this way? If so, how?
Thanks
Re: Remeha set outside temperature using MQTT
Posted: Tue Feb 03, 2015 11:29 pm
by MindBender
OTG? MQTT? OMGWTFROFLOLWUTBBQ?
Anyway; Remeha Celcia 20 and iSense thermostats read their outdoor temperature from the boiler, which must be equipped with an analog outside temperature sensor. On the Celcia 20, it was accessible by a press on the information button. On the iSense it's burried too deep in the menu to be of any practric use. Both thermostats use it in their control algorithm though.
Posted: Wed Feb 04, 2015 12:23 am
by hvxl
Setting the outside temperature via MQTT isn't currently supported. I've put it on the feature request list for a future version of otmonitor.
Posted: Thu Feb 05, 2015 12:38 am
by ModbusMan
@hvxl Thanks. Is it possible to set any other setpoints via MQTT in the current version of otmonitor. Or is MQTT for reading OTGW data only.
I also tried sending data directly to the OTGW via the serial port using a bash script whilst otmonitor is running but that seems to mess things up. Guess too many apps sending data at the same time to one serial port is not such a good idea...
Posted: Thu Feb 05, 2015 10:23 pm
by hvxl
Oops, looking at the code I see that setting the outside temperature through MQTT is supposed to be possible in the current version of otmonitor. The topic to use is: actions/otmonitor/outside, assuming you didn't change the MQTT Device Identifier from the default of otmonitor. Otherwise adjust accordingly. The only other supported topic is actions/otmonitor/setpoint. I assume you can guess what that does.
Having multiple applications interfacing with a single serial port at the same time is usually not going to work. Besides MQTT, there are only 3 ways for scripts to interact with the gateway via otmonitor:
- Send a command over TCP to the Remote Access relay server.
- Issue a command as a query string to the web interface /command path.
- Using the dbus com.tclcode.otmonitor.Command method at the / path.
I admit that the options are a bit limited.
Posted: Sat Dec 19, 2015 1:39 am
by ModbusMan
Sorry for the late reply...
Must admit that I never got the MQTT publish function to work. Now I use MQTT to read the info and the web interface to send the outside temperature to my Remeha iSense thermostat. Works great using Fhem together with a RPI.
Posted: Thu Dec 24, 2015 11:11 pm
by raymonvdm
MQTT Seems to be working
