Relative modulation level 0.00??
yjb
Post by yjb »
I'm looking for an explanation related to the Relative modulation level.
Quite often I see that the the flame status is on, while the relative modulation level is equal to 0.00:
Not only does OTGW report that the flame status is "on", the Gasmeter is running at the same time, so I guess that 0.00 is not always 0.00.
On the other hand, I see as well that that the Celcia-20 reports "Delivered output 1" while otgw reports "Relative modulation level: 0.00"
From the Celcia-20 manual:
delivered output (0 means: the boiler is off, 5 means: the boiler is
delivering the maximum output)
Is this something related to my boiler (Quinta-35C), or do other people see the same with other boilers?
Once again, not sure if something is wrong, just want to satisfy my curiosity.
emmeesse68
Re: Relative modulation level 0.00??
Post by emmeesse68 »
Same situation with my Ferroli BlueHelix Pro 32c. It seems to me that the flame status is controlled by rising/lowering the "control setpoint", that looks like the maximum water temperature the thermostat allows (the "Max. central heating water setpoint" is set by boiler's contrl panel)
I think (but I have no proof, thus it's just a guess) relative modulation 0.0 instructs boiler to deliver the minimum possible power, that would be different depending on the boiler make/model.
Modulation is one parameter only, but boilers can modulate at least two things: flame and circulation pump. Maybe boilers have onboard logic to decide wether to modulate one or the other, appearently OT controls one overall relative modulation.
Anyway, before adopting OpenTherm control, I was driving my boiler with the zone valves end switches, in an on/off style. By observing the boiler's display, I could notice flame was being modulated anyway, and the pump noise used to vary, so I guess there's some logic on the boiler itself that would modulate even in an on/off control situation.
