Actually I have a complex multi-zone heating system with 2 Heat pump , and a Gaz Boiler. The heating system is controlled and managed by a Honeywell W6560C1100 regulation module. To this module is attached a Honeywell wireless CMS927 Chronotherm through a Honeywell R8810 OT gateway.
As I have been building a home automation system, my needs are quiet simple: being able through an HTTP command to:
- Get the room temperature
- write the room temperature setpoint
- Eventually set the specific mode ( absent, economy, etc …)
After a long searches on the Internet I build up the following solution:
- OTGW that I soldered myself connected to
○ W6560C ( as a boiler)
○ The R8810 ( as a thermostat)
○ As Raspberry Pi, through USB
- Raspbery Pi
○ Connected through USB to the OTGW
○ Otmonitor running as daemon
○ Python script pulling the datafile generated by Otmonitor and pushing the desired info to the home automation system
○ Python script writing the TC command to the OTGW
○ Apache server with PHP for the HTTP commands
I successfully made the chain working, but I am facing the following issues:
- The room temperature is not updated by the Chronotherm, and is always at 20°
- The room set point is considered by OTGW but not by the chronotherm, and everything continues as if the override didn't happen.
I tried to interact with the boiler (W6560C ) with the CH and the CS command, and it is working fine, but it looks like nothing is being exchanged between the OTGW and the chronotherm.
BTW, changing the setpoint on the Chronotherm is reflected both on the OTGW and the boiler.
So I am assuming that the CMS927 Chronotherm is not compatible with OTGW as:
- it is not providing the room temperature to the OTGW, nor the boiler
- It is not accepting the override of the room setpoint
So I am now investigating in different approach of Investing in a CMT 937 or CMT907 Chronotherm, leaving behind the wireless part as this looks to work fine with both OTGW and the W6560C.
Before doing that, I would like to ensure that problems I am facing is not due to any issues with my build of the OTGW, I followed successfully the diagnostic process of the PCB.
below this message a logfile, would it be possible for some you to check it to see, if there is something to understand from it?
Kindly regards,
Rouzi
13:08:30.241203 T80000200 Read-Data Status: 00000010 00000000
13:08:30.420495 B40000200 Read-Ack Status: 00000010 00000000
13:08:30.779435 T80000200 Read-Data Status: 00000010 00000000
13:08:30.897390 B40000200 Read-Ack Status: 00000010 00000000
13:08:31.318973 T80000200 Read-Data Status: 00000010 00000000
13:08:31.442436 B40000200 Read-Ack Status: 00000010 00000000
13:08:31.854222 T00050000 Read-Data Application-specific flags: 00000000 0
13:08:31.973783 BC0050000 Read-Ack Application-specific flags: 00000000 0
13:08:32.393846 T80190000 Read-Data Boiler water temperature: 0.00
13:08:32.514093 B401917CA Read-Ack Boiler water temperature: 23.79
13:08:32.934829 T10010A00 Write-Data Control setpoint: 10.00
13:08:33.066296 BD0010A00 Write-Ack Control setpoint: 10.00
13:08:33.470991 T80000200 Read-Data Status: 00000010 00000000
13:08:33.590813 B40000200 Read-Ack Status: 00000010 00000000
13:08:34.010757 T80000200 Read-Data Status: 00000010 00000000
13:08:34.134365 B40000200 Read-Ack Status: 00000010 00000000
13:08:34.552868 T80000200 Read-Data Status: 00000010 00000000
13:08:34.669311 B40000200 Read-Ack Status: 00000010 00000000
13:08:35.090278 T80000200 Read-Data Status: 00000010 00000000
13:08:35.211806 B40000200 Read-Ack Status: 00000010 00000000
13:08:35.630605 T80000200 Read-Data Status: 00000010 00000000
13:08:35.750958 B40000200 Read-Ack Status: 00000010 00000000
13:08:36.167613 T00050000 Read-Data Application-specific flags: 00000000 0
13:08:36.289294 BC0050000 Read-Ack Application-specific flags: 00000000 0
13:08:36.707435 T80190000 Read-Data Boiler water temperature: 0.00
13:08:36.828842 BC01917C7 Read-Ack Boiler water temperature: 23.78
13:08:37.255236 T10010A00 Write-Data Control setpoint: 10.00
13:08:37.372873 BD0010A00 Write-Ack Control setpoint: 10.00
13:08:37.794288 T80000200 Read-Data Status: 00000010 00000000
13:08:37.912763 B40000200 Read-Ack Status: 00000010 00000000
13:08:38.335204 T80000200 Read-Data Status: 00000010 00000000
13:08:38.453524 B40000200 Read-Ack Status: 00000010 00000000
13:08:38.873597 T80000200 Read-Data Status: 00000010 00000000
13:08:38.993180 B40000200 Read-Ack Status: 00000010 00000000
13:08:39.415390 T80000200 Read-Data Status: 00000010 00000000
13:08:39.535735 B40000200 Read-Ack Status: 00000010 00000000
13:08:39.955716 T80000200 Read-Data Status: 00000010 00000000
13:08:40.074472 B40000200 Read-Ack Status: 00000010 00000000
13:08:40.494337 T80000200 Read-Data Status: 00000010 00000000
13:08:40.614048 B40000200 Read-Ack Status: 00000010 00000000
13:08:41.035625 T80000200 Read-Data Status: 00000010 00000000
13:08:41.153741 B40000200 Read-Ack Status: 00000010 00000000
13:08:41.574753 T90800002 Write-Data Message ID 128: 2
13:08:41.694865 B50800002 Write-Ack Message ID 128: 2
13:08:42.119332 T80383C00 Read-Data DHW setpoint: 60.00
13:08:42.238503 B40383C00 Read-Ack DHW setpoint: 60.00
13:08:42.655942 T00395A00 Read-Data Max CH water setpoint: 90.00
13:08:42.778884 BC0395A00 Read-Ack Max CH water setpoint: 90.00
13:08:43.199695 T00050000 Read-Data Application-specific flags: 00000000 0
13:08:43.317086 BC0050000 Read-Ack Application-specific flags: 00000000 0
13:08:43.739344 T80190000 Read-Data Boiler water temperature: 0.00
13:08:43.860206 B401917C5 Read-Ack Boiler water temperature: 23.77
13:08:44.279939 T10010A00 Write-Data Control setpoint: 10.00
13:08:44.400033 BD0010A00 Write-Ack Control setpoint: 10.00
13:08:44.825491 T900E6400 Write-Data Maximum relative modulation level: 100.00
13:08:44.943235 BF00E6400 Unk-DataId Maximum relative modulation level: 100.00
13:08:45.362266 T90181400 Write-Data Room temperature: 20.00
13:08:45.480493 BF0181400 Unk-DataId Room temperature: 20.00
13:08:45.902218 T10101080 Write-Data Room setpoint: 16.50
13:08:46.023277 B70101080 Unk-DataId Room setpoint: 16.50
13:08:46.076826 AD0101080 Write-Ack Room setpoint: 16.50
13:08:46.447673 T00050000 Read-Data Application-specific flags: 00000000 0
13:08:46.564163 BC0050000 Read-Ack Application-specific flags: 00000000 0
13:08:46.988935 T80190000 Read-Data Boiler water temperature: 0.00
13:08:47.110226 BC01917C7 Read-Ack Boiler water temperature: 23.78
13:08:47.528625 T10010A00 Write-Data Control setpoint: 10.00
13:08:47.649131 BD0010A00 Write-Ack Control setpoint: 10.00
13:08:48.065225 T801C0000 Read-Data Return water temperature: 0.00
13:08:48.187408 B701C0000 Unk-DataId Return water temperature: 0.00
13:08:48.610274 T00110000 Read-Data Relative modulation level: 0.00
13:08:48.730582 BF0110000 Unk-DataId Relative modulation level: 0.00
13:08:49.150660 T00090000 Read-Data Remote override room setpoint: 0.00
13:08:49.269786 BF0090000 Unk-DataId Remote override room setpoint: 0.00
13:08:49.325828 A40091900 Read-Ack Remote override room setpoint: 25.00
13:08:49.689754 T801A0000 Read-Data DHW temperature: 0.00
13:08:49.810299 B601ABAE2 Data-Inv DHW temperature: -69.12
13:08:49.865427 AD004AA7D Write-Ack Remote command: 170 125
13:08:50.233059 T801A0000 Read-Data DHW temperature: 0.00
13:08:50.357839 B601ABAE2 Data-Inv DHW temperature: -69.12
13:08:50.778667 T001B0000 Read-Data Outside temperature: 0.00
13:08:50.898898 B401B0FB0 Read-Ack Outside temperature: 15.69
13:08:51.314294 T80000200 Read-Data Status: 00000010 00000000
13:08:51.434668 B40000200 Read-Ack Status: 00000010 00000000
13:08:51.855990 T00050000 Read-Data Application-specific flags: 00000000 0
13:08:51.978660 BC0050000 Read-Ack Application-specific flags: 00000000 0
13:08:52.400069 T80190000 Read-Data Boiler water temperature: 0.00
13:08:52.519409 BC01917C2 Read-Ack Boiler water temperature: 23.76
13:08:52.939113 T10010A00 Write-Data Control setpoint: 10.00
13:08:53.061295 BD0010A00 Write-Ack Control setpoint: 10.00
13:08:53.475847 T80130000 Read-Data DHW flow rate: 0.00
13:08:53.596889 B70130000 Unk-DataId DHW flow rate: 0.00
13:08:54.015555 T00120000 Read-Data CH water pressure: 0.00
13:08:54.135869 BF0120000 Unk-DataId CH water pressure: 0.00
13:08:54.562801 T10830000 Write-Data Message ID 131: 0
13:08:54.679267 BD0830000 Write-Ack Message ID 131: 0
13:08:55.092406 T80000200 Read-Data Status: 00000010 00000000
13:08:55.212414 B40000200 Read-Ack Status: 00000010 00000000
13:08:55.632716 T80000200 Read-Data Status: 00000010 00000000
13:08:55.751398 B40000200 Read-Ack Status: 00000010 00000000
13:08:56.204440 T80000200 Read-Data Status: 00000010 00000000
13:08:56.296149 B40000200 Read-Ack Status: 00000010 00000000
13:08:56.715343 T00050000 Read-Data Application-specific flags: 00000000 0
13:08:56.834003 BC0050000 Read-Ack Application-specific flags: 00000000 0
13:08:57.259692 T80190000 Read-Data Boiler water temperature: 0.00
13:08:57.382007 BC01917C2 Read-Ack Boiler water temperature: 23.76
13:08:57.802953 T10010A00 Write-Data Control setpoint: 10.00
13:08:57.925594 BD0010A00 Write-Ack Control setpoint: 10.00
13:08:58.345312 T80000200 Read-Data Status: 00000010 00000000
13:08:58.460392 B40000200 Read-Ack Status: 00000010 00000000
13:08:58.881893 T80000200 Read-Data Status: 00000010 00000000
13:08:59.002406 B40000200 Read-Ack Status: 00000010 00000000
13:08:59.422447 T80000200 Read-Data Status: 00000010 00000000
13:08:59.542928 B40000200 Read-Ack Status: 00000010 00000000
13:08:59.962592 T80000200 Read-Data Status: 00000010 00000000
13:09:00.080514 B40000200 Read-Ack Status: 00000010 00000000
13:09:00.503345 T80000200 Read-Data Status: 00000010 00000000
13:09:00.626258 B40000200 Read-Ack Status: 00000010 00000000
13:09:01.048845 T80000200 Read-Data Status: 00000010 00000000
13:09:01.168064 B40000200 Read-Ack Status: 00000010 00000000
13:09:01.588050 T80000200 Read-Data Status: 00000010 00000000
13:09:01.707576 B40000200 Read-Ack Status: 00000010 00000000
13:09:02.126197 T00050000 Read-Data Application-specific flags: 00000000 0
13:09:02.246422 BC0050000 Read-Ack Application-specific flags: 00000000 0
13:09:02.664251 T80190000 Read-Data Boiler water temperature: 0.00
13:09:02.785726 BC01917C2 Read-Ack Boiler water temperature: 23.76
13:09:03.204325 T10010A00 Write-Data Control setpoint: 10.00
13:09:03.326073 BD0010A00 Write-Ack Control setpoint: 10.00
13:09:03.751913 T80000200 Read-Data Status: 00000010 00000000
13:09:03.862870 B40000200 Read-Ack Status: 00000010 00000000
13:09:04.244428 Command: TT=30
13:09:04.270681 TT: 30.00
13:09:04.323506 T80000200 Read-Data Status: 00000010 00000000
13:09:04.400826 B40000200 Read-Ack Status: 00000010 00000000
13:09:04.452102 AD004AA96 Write-Ack Remote command: 170 150
13:09:04.826627 T80000200 Read-Data Status: 00000010 00000000
13:09:04.944290 B40000200 Read-Ack Status: 00000010 00000000
13:09:05.366391 T80000200 Read-Data Status: 00000010 00000000
13:09:05.486197 B40000200 Read-Ack Status: 00000010 00000000
13:09:05.907175 T80000200 Read-Data Status: 00000010 00000000
13:09:06.028093 B40000200 Read-Ack Status: 00000010 00000000
13:09:06.448156 T00050000 Read-Data Application-specific flags: 00000000 0
13:09:06.567101 BC0050000 Read-Ack Application-specific flags: 00000000 0
13:09:06.985844 T80190000 Read-Data Boiler water temperature: 0.00
13:09:07.108265 B401917C0 Read-Ack Boiler water temperature: 23.75
13:09:07.527291 T10010A00 Write-Data Control setpoint: 10.00
13:09:07.645588 BD0010A00 Write-Ack Control setpoint: 10.00
13:09:08.064184 T80000200 Read-Data Status: 00000010 00000000
13:09:08.185676 B40000200 Read-Ack Status: 00000010 00000000
13:09:08.605035 T80000200 Read-Data Status: 00000010 00000000
13:09:08.725840 B40000200 Read-Ack Status: 00000010 00000000
13:09:09.144998 T80000200 Read-Data Status: 00000010 00000000
13:09:09.263384 B40000200 Read-Ack Status: 00000010 00000000
13:09:09.688064 T80000200 Read-Data Status: 00000010 00000000
13:09:09.808396 B40000200 Read-Ack Status: 00000010 00000000
13:09:10.228774 T80000200 Read-Data Status: 00000010 00000000
13:09:10.348263 B40000200 Read-Ack Status: 00000010 00000000
13:09:10.766667 T80000200 Read-Data Status: 00000010 00000000
13:09:10.887424 B40000200 Read-Ack Status: 00000010 00000000
13:09:11.308094 T80000200 Read-Data Status: 00000010 00000000
13:09:11.427542 B40000200 Read-Ack Status: 00000010 00000000
13:09:11.846803 T00050000 Read-Data Application-specific flags: 00000000 0
13:09:11.965761 BC0050000 Read-Ack Application-specific flags: 00000000 0
13:09:12.385536 T80190000 Read-Data Boiler water temperature: 0.00
13:09:12.506617 B401917C0 Read-Ack Boiler water temperature: 23.75
13:09:12.924640 T10010A00 Write-Data Control setpoint: 10.00
13:09:13.050244 BD0010A00 Write-Ack Control setpoint: 10.00
13:09:13.467806 T80000200 Read-Data Status: 00000010 00000000
13:09:13.587753 B40000200 Read-Ack Status: 00000010 00000000
13:09:14.006525 T80000200 Read-Data Status: 00000010 00000000
13:09:14.125890 B40000200 Read-Ack Status: 00000010 00000000
13:09:14.548459 T80000200 Read-Data Status: 00000010 00000000
13:09:14.667260 B40000200 Read-Ack Status: 00000010 00000000
13:09:15.091403 T80000200 Read-Data Status: 00000010 00000000
13:09:15.211390 B40000200 Read-Ack Status: 00000010 00000000
13:09:15.630571 T80000200 Read-Data Status: 00000010 00000000
13:09:15.753036 B40000200 Read-Ack Status: 00000010 00000000
13:09:16.172303 T80000200 Read-Data Status: 00000010 00000000
13:09:16.290119 B40000200 Read-Ack Status: 00000010 00000000
13:09:16.714885 T00050000 Read-Data Application-specific flags: 00000000 0
13:09:16.833629 BC0050000 Read-Ack Application-specific flags: 00000000 0
13:09:17.255308 T80190000 Read-Data Boiler water temperature: 0.00
13:09:17.375049 B401917BD Read-Ack Boiler water temperature: 23.74
13:09:17.793360 T10010A00 Write-Data Control setpoint: 10.00
13:09:17.914208 BD0010A00 Write-Ack Control setpoint: 10.00
13:09:18.338753 T80000200 Read-Data Status: 00000010 00000000
13:09:18.457397 B40000200 Read-Ack Status: 00000010 00000000
13:09:18.878624 T80000200 Read-Data Status: 00000010 00000000
13:09:18.998810 B40000200 Read-Ack Status: 00000010 00000000
13:09:19.417173 T80000200 Read-Data Status: 00000010 00000000
13:09:19.537979 B40000200 Read-Ack Status: 00000010 00000000
13:09:19.957141 T80000200 Read-Data Status: 00000010 00000000
13:09:20.078570 B40000200 Read-Ack Status: 00000010 00000000
13:09:20.500094 T80000200 Read-Data Status: 00000010 00000000
13:09:20.621889 B40000200 Read-Ack Status: 00000010 00000000
13:09:21.037517 T80000200 Read-Data Status: 00000010 00000000
13:09:21.160803 B40000200 Read-Ack Status: 00000010 00000000
13:09:21.578393 T80000200 Read-Data Status: 00000010 00000000
13:09:21.695955 B40000200 Read-Ack Status: 00000010 00000000
13:09:22.113686 T00050000 Read-Data Application-specific flags: 00000000 0
13:09:22.234546 BC0050000 Read-Ack Application-specific flags: 00000000 0
13:09:22.654461 T80190000 Read-Data Boiler water temperature: 0.00
13:09:22.775670 B401917BD Read-Ack Boiler water temperature: 23.74
13:09:23.197334 T10010A00 Write-Data Control setpoint: 10.00
13:09:23.316904 BD0010A00 Write-Ack Control setpoint: 10.00
13:09:23.743894 T80000200 Read-Data Status: 00000010 00000000
13:09:23.859666 B40000200 Read-Ack Status: 00000010 00000000
13:09:24.281182 T80000200 Read-Data Status: 00000010 00000000
13:09:24.398939 B40000200 Read-Ack Status: 00000010 00000000
13:09:24.816875 T80000200 Read-Data Status: 00000010 00000000
13:09:24.936387 B40000200 Read-Ack Status: 00000010 00000000
13:09:25.363099 T80000200 Read-Data Status: 00000010 00000000
13:09:25.481783 B40000200 Read-Ack Status: 00000010 00000000
13:09:25.905258 T80000200 Read-Data Status: 00000010 00000000
13:09:26.027206 B40000200 Read-Ack Status: 00000010 00000000
13:09:26.445986 T00050000 Read-Data Application-specific flags: 00000000 0
13:09:26.562612 BC0050000 Read-Ack Application-specific flags: 00000000 0
13:09:26.987566 T80190000 Read-Data Boiler water temperature: 0.00
13:09:27.107368 B401917B8 Read-Ack Boiler water temperature: 23.72
13:09:27.529319 T10010A00 Write-Data Control setpoint: 10.00
13:09:27.646593 BD0010A00 Write-Ack Control setpoint: 10.00
13:09:28.067688 T80000200 Read-Data Status: 00000010 00000000
13:09:28.187534 B40000200 Read-Ack Status: 00000010 00000000
13:09:28.606907 T80000200 Read-Data Status: 00000010 00000000
13:09:28.725712 B40000200 Read-Ack Status: 00000010 00000000
13:09:29.148326 T80000200 Read-Data Status: 00000010 00000000
13:09:29.275365 B40000200 Read-Ack Status: 00000010 00000000
13:09:29.684100 T80000200 Read-Data Status: 00000010 00000000
13:09:29.805917 B40000200 Read-Ack Status: 00000010 00000000
13:09:30.225962 T80000200 Read-Data Status: 00000010 00000000
13:09:30.343829 B40000200 Read-Ack Status: 00000010 00000000
13:09:30.763619 T80000200 Read-Data Status: 00000010 00000000
13:09:30.883201 B40000200 Read-Ack Status: 00000010 00000000
13:09:31.309816 T80000200 Read-Data Status: 00000010 00000000
13:09:31.395108 Command: CH=1
13:09:31.422173 CH: 1
13:09:31.476854 B40000200 Read-Ack Status: 00000010 00000000
13:09:31.850854 T00050000 Read-Data Application-specific flags: 00000000 0
13:09:31.969210 BC0050000 Read-Ack Application-specific flags: 00000000 0
13:09:32.391371 T80190000 Read-Data Boiler water temperature: 0.00
13:09:32.511339 B401917B8 Read-Ack Boiler water temperature: 23.72
13:09:32.930545 T10010A00 Write-Data Control setpoint: 10.00
13:09:33.054102 BD0010A00 Write-Ack Control setpoint: 10.00
13:09:33.468935 T80000200 Read-Data Status: 00000010 00000000
13:09:33.589802 B40000200 Read-Ack Status: 00000010 00000000
13:09:34.007038 T80000200 Read-Data Status: 00000010 00000000
13:09:34.129758 B40000200 Read-Ack Status: 00000010 00000000
13:09:34.548890 T80000200 Read-Data Status: 00000010 00000000
13:09:34.668579 B40000200 Read-Ack Status: 00000010 00000000
13:09:35.088563 T80000200 Read-Data Status: 00000010 00000000
13:09:35.205974 B40000200 Read-Ack Status: 00000010 00000000
13:09:35.629368 T80000200 Read-Data Status: 00000010 00000000
13:09:35.749308 B40000200 Read-Ack Status: 00000010 00000000
13:09:36.170454 T80000200 Read-Data Status: 00000010 00000000
13:09:36.291825 B40000200 Read-Ack Status: 00000010 00000000
13:09:36.707650 T00050000 Read-Data Application-specific flags: 00000000 0
13:09:36.829029 BC0050000 Read-Ack Application-specific flags: 00000000 0
13:09:37.248661 T80190000 Read-Data Boiler water temperature: 0.00
13:09:37.367931 B401917B8 Read-Ack Boiler water temperature: 23.72
13:09:37.784374 T10010A00 Write-Data Control setpoint: 10.00
13:09:37.903568 BD0010A00 Write-Ack Control setpoint: 10.00
13:09:38.328907 T80000200 Read-Data Status: 00000010 00000000
13:09:38.449570 B40000200 Read-Ack Status: 00000010 00000000
13:09:39.375721 T80000200 Read-Data Status: 00000010 00000000
13:09:39.493731 B40000200 Read-Ack Status: 00000010 00000000
13:09:39.915009 T80000200 Read-Data Status: 00000010 00000000
13:09:40.034742 B40000200 Read-Ack Status: 00000010 00000000
13:09:40.456825 T80000200 Read-Data Status: 00000010 00000000
13:09:40.575420 B40000200 Read-Ack Status: 00000010 00000000
13:09:40.993351 T80000200 Read-Data Status: 00000010 00000000
13:09:41.115726 B40000200 Read-Ack Status: 00000010 00000000
13:09:41.535819 T90800002 Write-Data Message ID 128: 2
13:09:41.654507 B50800002 Write-Ack Message ID 128: 2
13:09:42.075891 T80383C00 Read-Data DHW setpoint: 60.00
13:09:42.194772 B40383C00 Read-Ack DHW setpoint: 60.00
13:09:42.612987 T00395A00 Read-Data Max CH water setpoint: 90.00
13:09:42.731157 BC0395A00 Read-Ack Max CH water setpoint: 90.00
13:09:43.153680 T80000200 Read-Data Status: 00000010 00000000
13:09:43.271887 B40000200 Read-Ack Status: 00000010 00000000
13:09:43.696074 T00050000 Read-Data Application-specific flags: 00000000 0
13:09:43.815925 BC0050000 Read-Ack Application-specific flags: 00000000 0
13:09:44.234861 T80190000 Read-Data Boiler water temperature: 0.00
13:09:44.356338 BC01917B5 Read-Ack Boiler water temperature: 23.71
13:09:44.775666 T10010A00 Write-Data Control setpoint: 10.00
13:09:44.894981 BD0010A00 Write-Ack Control setpoint: 10.00
13:09:45.318173 T900E6400 Write-Data Maximum relative modulation level: 100.00
13:09:45.387342 Command: CS=45
13:09:45.414940 CS: 45.00
13:09:45.469492 BF00E6400 Unk-DataId Maximum relative modulation level: 100.00
13:09:45.861410 T90181400 Write-Data Room temperature: 20.00
13:09:45.980978 BF0181400 Unk-DataId Room temperature: 20.00
13:09:46.399918 T10101080 Write-Data Room setpoint: 16.50
13:09:46.519555 B70101080 Unk-DataId Room setpoint: 16.50
13:09:46.574015 AD0101080 Write-Ack Room setpoint: 16.50
13:09:46.943146 T00050000 Read-Data Application-specific flags: 00000000 0
13:09:47.057945 BC0050000 Read-Ack Application-specific flags: 00000000 0
13:09:47.484114 T80190000 Read-Data Boiler water temperature: 0.00
13:09:47.604152 BC01917B5 Read-Ack Boiler water temperature: 23.71
13:09:48.022992 T10010A00 Write-Data Control setpoint: 10.00
13:09:48.076127 R10012D00 Write-Data Control setpoint: 45.00
13:09:48.142216 BD0012D00 Write-Ack Control setpoint: 45.00
13:09:48.202162 AD0010A00 Write-Ack Control setpoint: 10.00
13:09:48.565882 T801C0000 Read-Data Return water temperature: 0.00
13:09:48.685644 B701C0000 Unk-DataId Return water temperature: 0.00
13:09:49.104548 T00110000 Read-Data Relative modulation level: 0.00
13:09:49.223476 BF0110000 Unk-DataId Relative modulation level: 0.00
13:09:49.643348 T00090000 Read-Data Remote override room setpoint: 0.00
13:09:49.761745 BF0090000 Unk-DataId Remote override room setpoint: 0.00
13:09:49.814160 AC0091E00 Read-Ack Remote override room setpoint: 30.00
13:09:50.184254 T00090000 Read-Data Remote override room setpoint: 0.00
13:09:50.302589 BF0090000 Unk-DataId Remote override room setpoint: 0.00
13:09:50.352137 AD004AA96 Write-Ack Remote command: 170 150
13:09:50.726826 T00090000 Read-Data Remote override room setpoint: 0.00
13:09:50.850287 BF0090000 Unk-DataId Remote override room setpoint: 0.00
13:09:50.903892 AC0091E00 Read-Ack Remote override room setpoint: 30.00
13:09:51.267192 T00090000 Read-Data Remote override room setpoint: 0.00
13:09:51.384424 BF0090000 Unk-DataId Remote override room setpoint: 0.00
13:09:51.436601 AD004AA96 Write-Ack Remote command: 170 150
13:09:51.844009 T80000200 Read-Data Status: 00000010 00000000
13:09:51.861596 R00000300 Read-Data Status: 00000011 00000000
13:09:51.931751 BC0000300 Read-Ack Status: 00000011 00000000
13:09:51.986385 A40000200 Read-Ack Status: 00000010 00000000
13:09:52.344041 T00050000 Read-Data Application-specific flags: 00000000 0
13:09:52.464209 BC0050000 Read-Ack Application-specific flags: 00000000 0
13:09:52.885350 T80190000 Read-Data Boiler water temperature: 0.00
13:09:53.006234 BC01917AE Read-Ack Boiler water temperature: 23.68
13:09:53.423699 T10010A00 Write-Data Control setpoint: 10.00
13:09:53.474817 R10012D00 Write-Data Control setpoint: 45.00
13:09:53.598202 BD0012D00 Write-Ack Control setpoint: 45.00
13:09:53.644564 AD0010A00 Write-Ack Control setpoint: 10.00
13:09:53.967454 T00090000 Read-Data Remote override room setpoint: 0.00
13:09:54.087991 BF0090000 Unk-DataId Remote override room setpoint: 0.00
13:09:54.141271 AC0091E00 Read-Ack Remote override room setpoint: 30.00
13:09:54.505774 T801A0000 Read-Data DHW temperature: 0.00
13:09:54.626091 B601ABAE2 Data-Inv DHW temperature: -69.12
13:09:54.678777 AD004AA96 Write-Ack Remote command: 170 150
13:09:55.048553 T801A0000 Read-Data DHW temperature: 0.00
13:09:55.172439 B601ABAE2 Data-Inv DHW temperature: -69.12
13:09:55.587063 T001B0000 Read-Data Outside temperature: 0.00
13:09:55.708736 BC01B0FB8 Read-Ack Outside temperature: 15.72
13:09:56.126852 T80130000 Read-Data DHW flow rate: 0.00
13:09:56.245524 B70130000 Unk-DataId DHW flow rate: 0.00
13:09:56.664098 T00050000 Read-Data Application-specific flags: 00000000 0
13:09:56.783930 BC0050000 Read-Ack Application-specific flags: 00000000 0
13:09:57.203696 T80190000 Read-Data Boiler water temperature: 0.00
13:09:57.325169 BC01917AE Read-Ack Boiler water temperature: 23.68
13:09:57.741554 T10010A00 Write-Data Control setpoint: 10.00
13:09:57.794620 R10012D00 Write-Data Control setpoint: 45.00
13:09:57.861177 BD0012D00 Write-Ack Control setpoint: 45.00
13:09:57.918750 AD0010A00 Write-Ack Control setpoint: 10.00
13:09:58.281959 T00120000 Read-Data CH water pressure: 0.00
13:09:58.403396 BF0120000 Unk-DataId CH water pressure: 0.00
13:09:58.825116 T10830000 Write-Data Message ID 131: 0
13:09:58.946034 BD0830000 Write-Ack Message ID 131: 0
13:09:59.368259 T80000200 Read-Data Status: 00000010 00000000
13:09:59.427893 R00000300 Read-Data Status: 00000011 00000000
13:09:59.487890 BC000030A Read-Ack Status: 00000011 00001010
13:09:59.534010 A4000020A Read-Ack Status: 00000010 00001010
13:09:59.909190 T80000200 Read-Data Status: 00000010 00000000
13:09:59.964487 R00000300 Read-Data Status: 00000011 00000000
13:10:00.030962 BC000030A Read-Ack Status: 00000011 00001010
13:10:00.086023 A4000020A Read-Ack Status: 00000010 00001010
13:10:00.449055 T80000200 Read-Data Status: 00000010 00000000
13:10:00.505304 R00000300 Read-Data Status: 00000011 00000000
13:10:00.566945 BC000030A Read-Ack Status: 00000011 00001010
13:10:00.619772 A4000020A Read-Ack Status: 00000010 00001010
13:10:00.989368 T80000200 Read-Data Status: 00000010 00000000
13:10:01.040748 R00000300 Read-Data Status: 00000011 00000000
13:10:01.109705 BC000030A Read-Ack Status: 00000011 00001010
13:10:01.164837 A4000020A Read-Ack Status: 00000010 00001010
13:10:01.539604 T80000200 Read-Data Status: 00000010 00000000
13:10:01.590804 R00000300 Read-Data Status: 00000011 00000000
13:10:01.649351 BC000030A Read-Ack Status: 00000011 00001010
13:10:01.707798 A4000020A Read-Ack Status: 00000010 00001010
13:10:02.070741 T00050000 Read-Data Application-specific flags: 00000000 0
13:10:02.190963 BC0050000 Read-Ack Application-specific flags: 00000000 0
13:10:02.617645 T80190000 Read-Data Boiler water temperature: 0.00
13:10:02.732560 BC01917AE Read-Ack Boiler water temperature: 23.68
13:10:03.152789 T10010A00 Write-Data Control setpoint: 10.00
13:10:03.208110 R10012D00 Write-Data Control setpoint: 45.00
13:10:03.274924 BD0012D00 Write-Ack Control setpoint: 45.00
13:10:03.327925 AD0010A00 Write-Ack Control setpoint: 10.00
13:10:03.691458 T80000200 Read-Data Status: 00000010 00000000
13:10:03.750343 R00000300 Read-Data Status: 00000011 00000000
13:10:03.811422 BC000030A Read-Ack Status: 00000011 00001010
13:10:03.864218 A4000020A Read-Ack Status: 00000010 00001010
13:10:04.232796 T80000200 Read-Data Status: 00000010 00000000
13:10:04.286298 R00000300 Read-Data Status: 00000011 00000000
13:10:04.353004 BC000030A Read-Ack Status: 00000011 00001010
13:10:04.409466 A4000020A Read-Ack Status: 00000010 00001010
13:10:04.773109 T80000200 Read-Data Status: 00000010 00000000
13:10:04.826526 R00000300 Read-Data Status: 00000011 00000000
13:10:04.893650 BC000030A Read-Ack Status: 00000011 00001010
13:10:04.949520 A4000020A Read-Ack Status: 00000010 00001010
13:10:05.316532 T80000200 Read-Data Status: 00000010 00000000
13:10:05.362463 R00000300 Read-Data Status: 00000011 00000000
13:10:05.435468 BC000030A Read-Ack Status: 00000011 00001010
13:10:05.487828 A4000020A Read-Ack Status: 00000010 00001010
13:10:05.860535 T80000200 Read-Data Status: 00000010 00000000
13:10:05.912066 R00000300 Read-Data Status: 00000011 00000000
13:10:05.981513 BC000030A Read-Ack Status: 00000011 00001010
13:10:06.033903 A4000020A Read-Ack Status: 00000010 00001010
13:10:06.400312 T80000200 Read-Data Status: 00000010 00000000
13:10:06.452217 R00000300 Read-Data Status: 00000011 00000000
13:10:06.518048 BC000030A Read-Ack Status: 00000011 00001010
13:10:06.569896 A4000020A Read-Ack Status: 00000010 00001010
13:10:06.943123 T00050000 Read-Data Application-specific flags: 00000000 0
13:10:07.059204 BC0050000 Read-Ack Application-specific flags: 00000000 0
13:10:07.478090 T80190000 Read-Data Boiler water temperature: 0.00
13:10:07.601339 BC01917AE Read-Ack Boiler water temperature: 23.68
13:10:07.666976 Command: CS=0
13:10:07.701601 CS: 0.00
13:10:08.021936 T10010A00 Write-Data Control setpoint: 10.00
13:10:08.141519 BD0010A00 Write-Ack Control setpoint: 10.00
13:10:08.560524 T80000200 Read-Data Status: 00000010 00000000
13:10:08.682757 B4000020A Read-Ack Status: 00000010 00001010
13:10:09.099984 T80000200 Read-Data Status: 00000010 00000000
13:10:09.275912 B4000020A Read-Ack Status: 00000010 00001010
13:10:09.639733 T80000200 Read-Data Status: 00000010 00000000
13:10:09.760700 B4000020A Read-Ack Status: 00000010 00001010
13:10:10.179578 T80000200 Read-Data Status: 00000010 00000000
13:10:10.297800 B4000020A Read-Ack Status: 00000010 00001010
13:10:10.718887 T80000200 Read-Data Status: 00000010 00000000
13:10:10.839227 B4000020A Read-Ack Status: 00000010 00001010
13:10:11.256783 T80000200 Read-Data Status: 00000010 00000000
13:10:11.379580 B4000020A Read-Ack Status: 00000010 00001010
13:10:11.795966 T80000200 Read-Data Status: 00000010 00000000
13:10:11.916243 B4000020A Read-Ack Status: 00000010 00001010
13:10:12.335464 T00050000 Read-Data Application-specific flags: 00000000 0
13:10:12.455053 BC0050000 Read-Ack Application-specific flags: 00000000 0
13:10:12.875620 T80190000 Read-Data Boiler water temperature: 0.00
13:10:12.995556 BC01917AE Read-Ack Boiler water temperature: 23.68
13:10:13.417096 T10010A00 Write-Data Control setpoint: 10.00
13:10:13.537172 BD0010A00 Write-Ack Control setpoint: 10.00
13:10:13.960577 T80000200 Read-Data Status: 00000010 00000000
13:10:14.081952 B4000020A Read-Ack Status: 00000010 00001010
13:10:14.504602 T80000200 Read-Data Status: 00000010 00000000
13:10:14.626261 B4000020A Read-Ack Status: 00000010 00001010
13:10:15.048823 T80000200 Read-Data Status: 00000010 00000000
13:10:15.165938 B4000020A Read-Ack Status: 00000010 00001010
13:10:15.585325 T80000200 Read-Data Status: 00000010 00000000
13:10:15.703189 B4000020A Read-Ack Status: 00000010 00001010
13:10:16.127046 T80000200 Read-Data Status: 00000010 00000000
13:10:16.248434 B4000020A Read-Ack Status: 00000010 00001010
13:10:16.667169 T80000200 Read-Data Status: 00000010 00000000
13:10:16.788737 B4000020A Read-Ack Status: 00000010 00001010
13:10:17.224919 T00050000 Read-Data Application-specific flags: 00000000 0
13:10:17.328204 BC0050000 Read-Ack Application-specific flags: 00000000 0
13:10:17.745461 T80190000 Read-Data Boiler water temperature: 0.00
13:10:17.865592 BC01917AB Read-Ack Boiler water temperature: 23.67
13:10:18.290359 T10010A00 Write-Data Control setpoint: 10.00
13:10:18.409178 BD0010A00 Write-Ack Control setpoint: 10.00
13:10:18.828062 T80000200 Read-Data Status: 00000010 00000000
13:10:18.949657 B4000020A Read-Ack Status: 00000010 00001010
13:10:19.366832 T80000200 Read-Data Status: 00000010 00000000
13:10:19.486668 B4000020A Read-Ack Status: 00000010 00001010
13:10:19.907992 T80000200 Read-Data Status: 00000010 00000000
13:10:20.028681 B4000020A Read-Ack Status: 00000010 00001010
13:10:20.450363 T80000200 Read-Data Status: 00000010 00000000
13:10:20.567689 B4000020A Read-Ack Status: 00000010 00001010
13:10:20.989809 T80000200 Read-Data Status: 00000010 00000000
13:10:21.105979 B4000020A Read-Ack Status: 00000010 00001010
13:10:21.525983 T80000200 Read-Data Status: 00000010 00000000
13:10:21.647446 B4000020A Read-Ack Status: 00000010 00001010
13:10:22.069582 T80000200 Read-Data Status: 00000010 00000000
13:10:22.192579 B4000020A Read-Ack Status: 00000010 00001010
13:10:22.609900 T00050000 Read-Data Application-specific flags: 00000000 0
13:10:22.733087 BC0050000 Read-Ack Application-specific flags: 00000000 0
13:10:23.149262 T80190000 Read-Data Boiler water temperature: 0.00
13:10:23.267788 BC01917AB Read-Ack Boiler water temperature: 23.67
13:10:23.691896 T10010A00 Write-Data Control setpoint: 10.00
13:10:23.809500 BD0010A00 Write-Ack Control setpoint: 10.00
13:10:24.231392 T80000200 Read-Data Status: 00000010 00000000
13:10:24.349279 B4000020A Read-Ack Status: 00000010 00001010
13:10:24.769802 T80000200 Read-Data Status: 00000010 00000000
13:10:24.889798 B4000020A Read-Ack Status: 00000010 00001010
13:10:25.313301 T80000200 Read-Data Status: 00000010 00000000
13:10:25.433276 B4000020A Read-Ack Status: 00000010 00001010
13:10:25.853135 T80000200 Read-Data Status: 00000010 00000000
13:10:25.972909 B4000020A Read-Ack Status: 00000010 00001010
13:10:26.396856 T80000200 Read-Data Status: 00000010 00000000
13:10:26.516880 B4000020A Read-Ack Status: 00000010 00001010
13:10:26.935650 T00050000 Read-Data Application-specific flags: 00000000 0
13:10:27.054576 BC0050000 Read-Ack Application-specific flags: 00000000 0
13:10:27.476831 T80190000 Read-Data Boiler water temperature: 0.00
13:10:27.594036 BC01917A8 Read-Ack Boiler water temperature: 23.66
13:10:28.017951 T10010A00 Write-Data Control setpoint: 10.00
13:10:28.138977 BD0010A00 Write-Ack Control setpoint: 10.00
13:10:28.564774 T80000200 Read-Data Status: 00000010 00000000
13:10:28.684934 B4000020A Read-Ack Status: 00000010 00001010
13:10:29.102002 T80000200 Read-Data Status: 00000010 00000000
13:10:29.221516 B4000020A Read-Ack Status: 00000010 00001010
13:10:29.643840 T80000200 Read-Data Status: 00000010 00000000
13:10:29.761780 B4000020A Read-Ack Status: 00000010 00001010
13:10:30.186353 T80000200 Read-Data Status: 00000010 00000000
13:10:30.303271 B4000020A Read-Ack Status: 00000010 00001010
13:10:30.727112 T80000200 Read-Data Status: 00000010 00000000
13:10:30.845775 B4000020A Read-Ack Status: 00000010 00001010
13:10:31.269374 T80000200 Read-Data Status: 00000010 00000000
13:10:31.391220 B4000020A Read-Ack Status: 00000010 00001010
13:10:31.809260 T80000200 Read-Data Status: 00000010 00000000
13:10:31.931547 B4000020A Read-Ack Status: 00000010 00001010
13:10:32.354167 T00050000 Read-Data Application-specific flags: 00000000 0
13:10:32.474112 BC0050000 Read-Ack Application-specific flags: 00000000 0
13:10:32.900247 T80190000 Read-Data Boiler water temperature: 0.00
13:10:33.018077 B401917A6 Read-Ack Boiler water temperature: 23.65
13:10:33.439349 T10010A00 Write-Data Control setpoint: 10.00
13:10:33.558865 BD0010A00 Write-Ack Control setpoint: 10.00
13:10:33.983312 T80000200 Read-Data Status: 00000010 00000000
13:10:34.102871 B4000020A Read-Ack Status: 00000010 00001010
13:10:34.523841 T80000200 Read-Data Status: 00000010 00000000
13:10:34.644247 B4000020A Read-Ack Status: 00000010 00001010
13:10:35.060725 T80000200 Read-Data Status: 00000010 00000000
13:10:35.181412 B4000020A Read-Ack Status: 00000010 00001010
13:10:35.602763 T80000200 Read-Data Status: 00000010 00000000
13:10:35.721549 B4000020A Read-Ack Status: 00000010 00001010
13:10:36.141435 T80000200 Read-Data Status: 00000010 00000000
13:10:36.261382 B4000020A Read-Ack Status: 00000010 00001010
13:10:36.683534 T80000200 Read-Data Status: 00000010 00000000
13:10:36.799031 B4000020A Read-Ack Status: 00000010 00001010
13:10:37.218706 T00050000 Read-Data Application-specific flags: 00000000 0
13:10:37.336376 BC0050000 Read-Ack Application-specific flags: 00000000 0
