Please add output of PS=1 to otmonitor webpage
Postby ThinkPad » Mon Nov 09, 2015 9:41 pm
Would it be possible to let the 'command' page display output of the PS=1 command?
Now it doesn't work when i call http://localhost:8080/command?PS=1
It shows the output of PS=1 in the otmonitor log, but unfortunately not in the webpage output, it only shows PS=1 again....
When showing the output from PS=1 also on the webpage output, i could scrape the contents much easier with something like a PHP-script and store it in my own application stuff. For now the only option seems to be to open a socket to the OTGW directly, which is much more work and quite difficult, especially when the OTGW is connected to a different physical machine.
Please add this option if possible :D
ThinkPad
Re: Please add output of PS=1 to otmonitor webpage
Postby timoline » Tue Nov 10, 2015 6:55 pm
I'm not sure it shows the info you want....but maybe you can use the json output?
http://<ip>:<port>/json
timoline
Postby ThinkPad » Tue Nov 10, 2015 9:19 pm
timoline wrote:I'm not sure it shows the info you want....but maybe you can use the json output?
That's perfect, thank you very much!
Too bad that such things are not documented at all @ the official website... would have saved quite some time if i found this out earlier.
ThinkPad
Postby hvxl » Tue Nov 10, 2015 10:41 pm
Agreed, the documentation at the web site is horrible and incomplete. I might just as well shut it down.
Postby timoline » Wed Nov 11, 2015 8:38 pm
yes please shut it down...it's rubbish...
Ok,now serious....you did/do an amazing job by making this all possible, great great great respect :!:
timoline
cron
