OEM fault code 132
Posted: Wed Nov 18, 2015 11:34 pm
by rpav
Hi folks,
I've seen OEM fault code 132 on the OTGW status page.
Anybody know what "OEM fault code 132" for Geminox THRi means?
Thanks!
Re: OEM fault code 132
Posted: Thu Nov 19, 2015 12:43 am
by hvxl
According to the manual it means: Safety device activated. Check that shunt X10-03 is present and that the wires are properly connected.
Note that the OEM fault code is only relevant when the fault indication bit is on.
Posted: Fri Nov 20, 2015 4:55 pm
by rpav
Thank you for reply.
Fault indication bit is not on, so I wll ignore all OEM fault code on status page (today I've seen OEM fault code 3)
But i try to find fault code in otlog log file, but can't see it. Is it loged to otlog file?
Posted: Fri Nov 20, 2015 10:15 pm
by hvxl
Given that otmonitor shows the OEM fault code, it must have received the message. That message will then also be logged.
