BC558A vs BC558B
BC558A vs BC558B
Postby markieman » Fri Nov 27, 2015 8:35 am
I'm fairly new to electronics and i'm trying to learn, but the documents/datasheets on this topic are too technical for me (yet), so I try to ask the question here.
I've recently ordered an OpenTherm GateWay kit, and I'm now halfway into the soldering process.
When I was about to solder the transistors on, I noticed that the part list stated the BC558A and BC548A transistors while the parts I received are the BC558B and BC548B.
(I also noticed the Conrad links on the otgw site link to BC558BTA and BC548BG)
What is (in simple terms) the difference and are these really interchangeable within the OpenTherm gateway?
markieman
Re: BC558A vs BC558B
Postby Templar » Fri Nov 27, 2015 10:27 am
markieman wrote:I'm fairly new to electronics and i'm trying to learn, but the documents/datasheets on this topic are too technical for me (yet), so I try to ask the question here.
What I read in the datasheet, it refers to the so called "Hfe" parameter a.k.a. the current-gain of the transistor.
I've used the BC558B and BC548B transistors too and the OTGW works perfect.
Templar
Postby markieman » Sat Nov 28, 2015 1:09 pm
Thanks for the confirmation that it will work.. I can continue soldering :)
markieman
