Room setpoint was set to 22.0 C.
Control setpoint (calculated by QAA73) was 41.92 C.
After OTG reset and without any other modification, the control setpoint was 46.30 C
Here is the log:
17:49:13.610686 T80001300 Read-Data Status: 00010011 00000000
17:49:13.879016 BC000132A Read-Ack Status: 00010011 00101010
17:49:14.650487 T90101600 Write-Data Room setpoint: 22.00
17:49:14.932857 B50101600 Write-Ack Room setpoint: 22.00
17:49:15.601870 T10171600 Write-Data Room Setpoint CH2: 22.00
17:49:15.921637 BD0171600 Write-Ack Room Setpoint CH2: 22.00
17:49:16.641923 T101814A4 Write-Data Room temperature: 20.64
17:49:16.909458 BD01814A4 Write-Ack Room temperature: 20.64
17:49:17.628326 T80800000 Read-Data Message ID 128: 0
17:49:17.898363 BE0800000 Data-Inv Message ID 128: 0
17:49:18.617321 T10821953 Write-Data Message ID 130: 6483
17:49:18.885905 BD0821953 Write-Ack Message ID 130: 6483
17:49:19.605968 T807F0000 Read-Data Slave product version: 0 0
17:49:19.875735 B407F6401 Read-Ack Slave product version: 100 1
17:49:20.595818 T80001300 Read-Data Status: 00010011 00000000
17:49:20.864489 BC000132A Read-Ack Status: 00010011 00101010
17:49:21.584270 T100129EC Write-Data Control setpoint: 41.92
17:49:21.852986 BD00129EC Write-Ack Control setpoint: 41.92
17:49:22.573047 T10081FF8 Write-Data Control setpoint 2: 31.97
17:49:22.840622 BD0081FF8 Write-Ack Control setpoint 2: 31.97
17:49:23.610986 T90383700 Write-Data DHW setpoint: 55.00
17:49:23.963271 B50383700 Write-Ack DHW setpoint: 55.00
17:49:24.582425 T80200000 Read-Data DHW2 temperature: 0.00
17:49:24.951301 BE0200000 Data-Inv DHW2 temperature: 0.00
17:49:25.570940 T801A0000 Read-Data DHW temperature: 0.00
17:49:25.939808 B401A3154 Read-Ack DHW temperature: 49.33
17:49:26.558570 T80001300 Read-Data Status: 00010011 00000000
17:49:26.928359 BC000132A Read-Ack Status: 00010011 00101010
17:49:27.547228 T001B0000 Read-Data Outside temperature: 0.00
17:49:27.915819 B401B03F4 Read-Ack Outside temperature: 3.95
17:49:28.586815 T80190000 Read-Data Boiler water temperature: 0.00
17:49:28.905586 BC0192CAC Read-Ack Boiler water temperature: 44.67
17:49:29.575537 T801C0000 Read-Data Return water temperature: 0.00
17:49:29.894035 B401C2068 Read-Ack Return water temperature: 32.41
17:49:30.564010 T801F0000 Read-Data Flow temperature CH2: 0.00
17:49:30.882876 B401F1ED8 Read-Ack Flow temperature CH2: 30.84
17:49:31.552979 T00110000 Read-Data Relative modulation level: 0.00
17:49:31.870921 BC0110000 Read-Ack Relative modulation level: 0.00
17:49:32.540942 T80001300 Read-Data Status: 00010011 00000000
17:49:32.859272 BC000132A Read-Ack Status: 00010011 00101010
17:49:33.533721 T80130000 Read-Data DHW flow rate: 0.00
17:49:33.846949 B70130000 Unk-DataId DHW flow rate: 0.00
17:49:34.519199 T001D0000 Read-Data Solar storage temperature: 0.00
17:49:34.835934 BF01D0000 Unk-DataId Solar storage temperature: 0.00
17:49:35.558502 T001E0000 Read-Data Solar collector temperature: 0.00
17:49:35.824829 B601E0000 Data-Inv Solar collector temperature: 0.00
17:49:36.545990 T00210000 Read-Data Exhaust temperature: 0.00
17:49:36.814720 B40210025 Read-Ack Exhaust temperature: 0.14
17:49:37.534814 T9081020E Write-Data Message ID 129: 526
17:49:37.801285 B5081020E Write-Ack Message ID 129: 526
17:49:38.522199 T80001300 Read-Data Status: 00010011 00000000
17:49:38.790785 BC000132A Read-Ack Status: 00010011 00101010
17:49:39.510834 T90101600 Write-Data Room setpoint: 22.00
17:49:39.779162 B50101600 Write-Ack Room setpoint: 22.00
17:49:40.499792 T10171600 Write-Data Room Setpoint CH2: 22.00
17:49:40.883691 BD0171600 Write-Ack Room Setpoint CH2: 22.00
17:49:41.488548 T101814A4 Write-Data Room temperature: 20.64
17:49:41.756154 BD01814A4 Write-Ack Room temperature: 20.64
17:49:42.527375 T80800000 Read-Data Message ID 128: 0
17:49:42.808548 BE0800000 Data-Inv Message ID 128: 0
17:49:43.479269 T10821953 Write-Data Message ID 130: 6483
17:49:43.797062 BD0821953 Write-Ack Message ID 130: 6483
17:49:44.518439 T80001300 Read-Data Status: 00010011 00000000
17:49:44.786667 BC000132A Read-Ack Status: 00010011 00101010
17:49:45.505763 T100129EC Write-Data Control setpoint: 41.92
17:49:45.775229 BD00129EC Write-Ack Control setpoint: 41.92
17:49:46.495117 T10081FF8 Write-Data Control setpoint 2: 31.97
17:49:46.762895 BD0081FF8 Write-Ack Control setpoint 2: 31.97
17:49:47.483799 T90383700 Write-Data DHW setpoint: 55.00
17:49:47.752366 B50383700 Write-Ack DHW setpoint: 55.00
17:49:48.472057 T80200000 Read-Data DHW2 temperature: 0.00
17:49:48.740679 BE0200000 Data-Inv DHW2 temperature: 0.00
17:49:49.462051 T801A0000 Read-Data DHW temperature: 0.00
17:49:49.729507 B401A3154 Read-Ack DHW temperature: 49.33
17:49:50.449232 T80001300 Read-Data Status: 00010011 00000000
17:49:50.716835 BC000132A Read-Ack Status: 00010011 00101010
<---reset--->
17:49:57.802246 ü^DOpenTherm Gateway 4.2.5
17:49:58.048873 T00000000 Read-Data Status: 00000000 00000000
17:49:58.363788 B4000002A Read-Ack Status: 00000000 00101010
17:49:58.983706 T00000000 Read-Data Status: 00000000 00000000
17:49:59.352108 B40000008 Read-Ack Status: 00000000 00001000
17:50:00.023435 T90020004 Write-Data Master configuration: 00000000 4
17:50:00.341931 B50020004 Write-Ack Master configuration: 00000000 4
17:50:01.010902 T00030000 Read-Data Slave configuration: 00000000 0
17:50:01.328514 BC0032904 Read-Ack Slave configuration: 00101001 4
17:50:02.002384 T907E0101 Write-Data Master product version: 1 1
17:50:02.515160 B507E0101 Write-Ack Master product version: 1 1
17:50:02.996106 T807F0000 Read-Data Slave product version: 0 0
17:50:03.307315 B407F6401 Read-Ack Slave product version: 100 1
17:50:03.983881 T90012E4C Write-Data Control setpoint: 46.30
17:50:04.304888 B50012E4C Write-Ack Control setpoint: 46.30
17:50:04.975910 T00001100 Read-Data Status: 00010001 00000000
17:50:05.294914 BC0001100 Read-Ack Status: 00010001 00000000
17:50:05.964669 T00060000 Read-Data Remote parameter flags: 00000000 00000000
17:50:06.275973 BC0060707 Read-Ack Remote parameter flags: 00000111 00000111
17:50:06.993686 T90082088 Write-Data Control setpoint 2: 32.53
17:50:07.265160 B50082088 Write-Ack Control setpoint 2: 32.53
17:50:07.984658 T900E6400 Write-Data Maximum relative modulation level: 100.00
17:50:08.249322 B500E6400 Write-Ack Maximum relative modulation level: 100.00
roman
