Please add Access-Control-Allow-Origin header on JSON
Postby RedNax » Wed May 18, 2016 6:30 am
Could you please add the Access-Control-Allow-Origin "*" header to the json output? I'm trying to display some of the otgw output on my magicmirror by getting the JSON using a js script, but modern browsers have CORS implemented and won't allow it when the header isn't present. You'll receive the following error:
MMM-OpenTherm.js:185 XMLHttpRequest cannot load http://xxx.xxx.xxx.xxx:/json. No 'Access-Control-Allow-Origin' header is present on the requested resource. Origin 'http://xxx.xxx.xxx.yyy:8080' is therefore not allowed access.
Thanks!
RedNax
Re: Please add Access-Control-Allow-Origin header on JSON
Postby RedNax » Sat May 21, 2016 12:27 pm
Nevermind, made my own version with the appropriate header. Everything now works as it should :D
RedNax
Postby timoline » Sat May 21, 2016 8:08 pm
still it would be nice it's included by default
timoline
