Central heating water pressure mqtt
Postby timoline » Wed Oct 12, 2016 8:13 pm
Is it possible you add Central heating water pressure to mqtt?
timoline
Re: Central heating water pressure mqtt
Postby timoline » Fri Dec 23, 2016 1:51 pm
Another request:
can you also add Remote override room setpoint (override) to mqtt?
tia
timoline
Postby lsiepel » Fri Nov 17, 2017 10:38 pm
I'm missing more events like burnerhours/starts etc. It would be nice if OTGW monitor would post every message (with a changed value) to mqtt.
I tried to dig into the source code and i'm having trouble to figure it out. I think it has to do with the $signals object not containing all data items. But not familiair with the language and build environment.
# Publish all known persistent parameters
dict for {key args} $signals {
if {[llength $args] == 0} continue
set param [string tolower $key]
if {[info exists gui($param)]} {
mqttsignal $param $gui($param)
lsiepel
Postby timoline » Sat Nov 25, 2017 4:51 pm
Yes, i just mentioned 2, but all events would be welcome ofcourse :-)
I'm waiting for a year now.....but I still hope it will be implemented eventually...
timoline
Postby hvxl » Thu Nov 30, 2017 5:44 pm
timoline wrote:I'm waiting for a year now.....but I still hope it will be implemented eventually...
I admire your patience to wait a year for someone else to do something for you. Of course you could also have spent a rainy afternoon to figure out how to do it yourself.
Postby timoline » Sat Jun 16, 2018 6:05 pm
I wish I could, Ihen I had done it a long time ago. :D
But good to see you pushed it to github https://github.com/hvxl/otmonitor
It was just positive feedback to make OTGW better then it already is.
thx
timoline
Postby timoline » Sat Jun 16, 2018 8:54 pm
Where in otmonitor.tcl can I do this calculation?
DeltaT = BoilerWaterTemperature - ReturnWaterTemperature
And put it in set signals, I assume...
timoline
Postby timoline » Tue Jun 19, 2018 9:08 pm
ok, created a pull request to added some more mqtt events.
https://github.com/hvxl/otmonitor/pull/1
Hopefully it will be comitted soon
timoline
Postby hvxl » Sat Sep 29, 2018 10:03 am
I merged your code and fixed some issues with it. I also added a deltatemp value.
Postby timoline » Sun Sep 30, 2018 7:20 pm
wow great :-)
many thx
didnt checked it yet, but is deltatemp also send to mqtt?
timoline
Postby hvxl » Sun Sep 30, 2018 8:52 pm
It should now :)
Postby anoppe » Tue Oct 02, 2018 2:38 pm
This is nice, this will save me the effort to extract this data from the otgw by hand!
I've been able to compile the updated sources from Github into a binary that runs on my orange-pi otgw, and I've got several new topics available in my MQTT broker: https://imgur.com/a/Ej3oc8U
anoppe
Postby anoppe » Tue Oct 02, 2018 3:26 pm
It seems to work as expected:
Screen Shot 2018-10-02 at 16.20.10.png (57.97 KiB) Viewed 2698 times
Thanks for the effort to create that PR @timoline!
anoppe
Postby timoline » Sat Oct 06, 2018 12:58 pm
hvxl wrote:It should now :)
looking good ! thx
timoline
