Firmware update failed - now what?
Posted: Sat Oct 29, 2016 4:22 pm
Hopefully someone can help me out...
This week problem started when the house become cold.
Boiler was pumping water, but did not fire-up. (status 'antipendel mode'
Normal reset of both the boiler and OTGW did not help.
By taking out the OTGW and connecting the boiler directly to the danfos CF2 (on-off). the boiler worked fine agian.
So my conclusion was the problem was in the OTGW
Tried to reflash the latest firmware using OTmonitor over TCP/IP but this update slowed down after ~25%, after that only generating error's
Next tried to connect the OTGW via a USB-TTL connector and update firmware, but get result "could not switch to self programming mode"
The OTGW worked for ~1 year without issue over the network before.
I have a PIC programmer available (was deliverd with the kit) but no idea how to use it.
Can anyone help me by getting the OTGW to live again?
Thanks
Sjoerd
Thanks
Sjoerd
