OTM : automatic reconnect to OTGW via network
Posted: Wed Dec 28, 2016 12:12 pm
by antst
I have setup where my OTGW embeds ESP8266 and automatically attach to AP, which is provided by RPi used for home management (separate from normal WiFi family uses).And last night I got situation when OTM stopped to receive information from OTGW. I restarted OTM and it works OK again. I suspect that it lost connection to OTGW for whatever reason. It would be nice if OTM, for network connection, would keep automatic reconnection attempts, till succeed.
Re: OTM : automatic reconnect to OTGW via network
Posted: Wed Dec 28, 2016 2:31 pm
by hvxl
It already does that. But if the ESP8266 didn't cleanly disconnect, OTMonitor may not be aware that the connection is gone. Did the icon in the status bar indicate that it thought it was connected (green) or disconnected (red)?
If the connection isn't properly closed, but silently disappears, OTMonitor won't detect that until it tries to send something. You can enable automatic clock updates (Options->Thermostat (F2) "Automatically update the gateway clock"). That will cause OTMonitor to send a command to the OTGW every minute. If the connection then breaks, it should be detected within a minute.
Posted: Wed Dec 28, 2016 7:10 pm
by Templar
hvxl wrote:Did the icon in the status bar indicate that it thought it was connected (green) or disconnected (red)?
I also have an ESP8266 attached to my OTGW setup flashed with the
esp-link firmware and have experienced OTmonitor not receiving data. The statusbar icon doesn't indicate
disconnected when that happens. However, in the esp-link
Microcontroller Console I still can see data being transferred.
Posted: Fri Dec 30, 2016 4:49 am
by antst
hvxl wrote:If the connection isn't properly closed, but silently disappears, OTMonitor won't detect that until it tries to send something. You can enable automatic clock updates (Options->Thermostat (F2) "Automatically update the gateway clock"). That will cause OTMonitor to send a command to the OTGW every minute. If the connection then breaks, it should be detected within a minute.
I have this enabled, and this is what I see in the message log
13:50:26.653073 T90013B00 Write-Data Control setpoint: 59.00
13:50:26.654488 B50013B00 Write-Ack Control setpoint: 59.00
13:50:26.655633 T00090000 Read-Data Remote override room setpoint: 0.00
13:50:26.656488 R00770000 Read-Data DHW burner starts: 0
13:50:26.657309 BC077FFFF Read-Ack DHW burner starts: 65535
13:50:26.658213 AC0090000 Read-Ack Remote override room setpoint: 0.00
13:51:00.001003 Command: SC=13:51/3
13:52:00.001281 Command: SC=13:52/3
13:53:00.000541 Command: SC=13:53/3
13:54:00.000746 Command: SC=13:54/3
13:55:00.001002 Command: SC=13:55/3
13:56:00.001253 Command: SC=13:56/3
13:57:00.000476 Command: SC=13:57/3
13:58:00.000680 Command: SC=13:58/3
13:59:00.000883 Command: SC=13:59/3
14:00:00.001169 Command: SC=14:00/3
14:01:00.001442 Command: SC=14:01/3
14:02:00.000689 Command: SC=14:02/3
14:03:00.000860 Command: SC=14:03/3
14:04:00.001052 Command: SC=14:04/3
14:05:00.001284 Command: SC=14:05/3
14:06:00.000508 Command: SC=14:06/3
14:07:00.000799 Command: SC=14:07/3
14:08:00.001015 Command: SC=14:08/3
14:09:00.001198 Command: SC=14:09/3
And then silence.
Posted: Sat Dec 31, 2016 3:02 pm
by hvxl
If you get into this situation again, please create an html directory next to your otmonitor executable if it doesn't yet exist. Unzip the attached file in there. If necessary, enable the web server. Then direct your browser to http://<ip>:<port>/connection.html and report what it produces.
Posted: Tue Jan 03, 2017 8:19 pm
by Templar
hvxl wrote:If you get into this situation again, ......... Then direct your browser to http://<ip>:<port>/connection.html and report what it produces.
It happend again. Opentherm Monitor ver. 4.3.0.2 (windows executable) running on a 64 bit Windows 10 machine stopped receiving information. The statusbar indicates that it still has a connection and the esp-link Microcontroller Console still transfers the OTGW data packets.
Socket information
Socket sock0597F250:
IP address: ::1
Hostname: DESKTOP-xxxxxx
Remote port: 58080
Local port: 8080
Translation: crlf/crlf
Encoding: cp1252
Pending: 0/0
Blocking: 0
Buffering: full
Socket sock0409D588:
IP address: 192.168.1.70
Hostname: OTGW.lan
Remote port: 23
Local port: 49741
Encoding: binary
Handler: receive
Pending: 0/0
Blocking: 0
Buffering: line
Last error
can't read "gui(chwsetpoint)": no such element in array
while executing
"expr {$float != $gui($name)}"
Hmm, I F5-ed the page several times and something was happening with the Encoding on the receiving side, it changed from
cp1252 to
binary.
Socket information
Socket sock05BE12E0:
IP address: ::1
Remote port: 56410
Local port: 8080
Encoding: binary
Pending: 0/0
Blocking: 0
Buffering: full
Hostname: OTGW.lan
Remote port: 23
Local port: 49741
Encoding: binary
Handler: receive
Pending: 0/0
Blocking: 0
Buffering: line
Last error
while executing
Posted: Fri Jan 06, 2017 11:09 am
by antst
BTW, I think ESP-link is a bad choice of firmware for OTGW. It has thing of automatic inactivity disconnect. And while it should be not an issue, as OTGW normally flows enough of information, I think that something like ESP-bridge is better suited.
Posted: Sat Jan 07, 2017 12:36 pm
by hvxl
Everything on the OTmonitor side looks exactly as it should. And since this problem only seems to happen with esp-link, the most likely reason is that esp-link stops sending data to OTmonitor, despite what esp-link Microcontroller Console says. Then again, that console uses a different TCP connection and is only designed to show what happens on the serial line, without any guarantee that the same information is also sent to any other TCP connection. To be sure where the problem lies, I suggest you use wireshark to monitor the actual traffic between esp-link and OTmonitor.
