(SOLVED) OTMonitor on 64 bit architecture (aarch64)
Postby alpat59 » Sat Mar 25, 2017 3:33 pm
I kindly ask you (I'm very fun of OTGW project but not so expert to be completely autonomous . to run it!) an help about the possibility to run otmonitor on a 64 bit (Pine 64 with ARMv8 + debian) platform.
I downloaded the otmonitor version for ARM (at monitor-ahf) but when i launch it I obtain the following message error:
-bash: /opt/otmonitor/otmonitor-ahf: No such file or directory
After some research, I found that the problem is in that specific otmonitor-ahf executable because running the "file /opt/otmonitor/otmonitor-ahf" command the answer is:
ELF 32-bit LSB executable, ARM, EABI5 version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux.so.3, for GNU/Linux 2.6.26, stripped
and that seems to be the problem: it's not possible running a 32-bit LSB executable on the aarch64 platform.
I hope that someone of you already found and fixed the problem.
I'll look forward for your help and support.
I thank you in advance
alpat59
Re: (SOLVED) OTMonitor on 64 bit architecture (aarch64)
Postby alpat59 » Sun Mar 26, 2017 8:47 am
I found here the solution to my problem: viewtopic.php?f=75&t=11542
And I fixed with the following command: sudo ln -s /lib/ld-linux-armhf.so.3 /lib/ld-linux.so.3
Now otmonito run perfectly on Pine64.
Thank you hvxl
alpat59
cron
