Honeywell Lyric T6R/Nefit Proline Unk-DataIDs
Posted: Sun Jan 14, 2018 3:16 pm
by paulz
I have recently connected a nodo OTGW between my new Nefit Proline Nx24 and my new Honeywell Lyric T6R.
When the connection is made I see the following in the otmonitor logs:
09:41:15.899259 T907E0000 Write-Data Master product version: 0 0
09:41:16.008065 R007B0000 Read-Data DHW burner operation hours: 0
09:41:16.009684 B407B0002 Read-Ack DHW burner operation hours: 2
09:41:16.011837 Command: PR=A
09:41:16.013094 AF07E0000 Unk-DataId Master product version: 0 0
09:41:16.253577 PR: A=OpenTherm Gateway 4.2.5
09:41:16.256252 Command: SC=09:41/5
09:41:16.547468 SC: 09:41/5
09:41:16.749386 T907E0000 Write-Data Master product version: 0 0
09:41:16.761281 R00740000 Read-Data Burner starts: 0
09:41:16.878212 BC0740875 Read-Ack Burner starts: 2165
09:41:16.891805 AF07E0000 Unk-DataId Master product version: 0 0
09:41:17.796945 T907E0000 Write-Data Master product version: 0 0
09:41:17.808017 R00770000 Read-Data DHW burner starts: 0
09:41:17.933772 BC07701B5 Read-Ack DHW burner starts: 437
09:41:17.947196 AF07E0000 Unk-DataId Master product version: 0 0
09:41:18.840789 T907E0000 Write-Data Master product version: 0 0
09:41:18.852612 R00780000 Read-Data Burner operation hours: 0
09:41:18.988186 BC07800A9 Read-Ack Burner operation hours: 169
09:41:18.999934 AF07E0000 Unk-DataId Master product version: 0 0
09:41:19.888076 T907E0000 Write-Data Master product version: 0 0
After about 5 minutes it stops and the log changes to :
09:46:23.328313 AF07E0000 Unk-DataId Master product version: 0 0
09:46:24.171016 T907E0000 Write-Data Master product version: 0 0
09:46:24.383396 R007B0000 Read-Data DHW burner operation hours: 0
09:46:24.389472 B407B0002 Read-Ack DHW burner operation hours: 2
09:46:24.399345 AF07E0000 Unk-DataId Master product version: 0 0
09:46:26.299369 ^DOpenTherm Gateway 4.2.5
09:46:26.305745 Command: SC=09:46/5
09:46:26.480073 BF07E0000 Unk-DataId Master product version: 0 0
09:46:26.805472 T807F0000 Read-Data Slave product version: 0 0
09:46:27.113760 B407F0220 Read-Ack Slave product version: 2 32
09:46:27.848225 T807F0000 Read-Data Slave product version: 0 0
09:46:28.014734 B407F0220 Read-Ack Slave product version: 2 32
09:46:28.892826 T807F0000 Read-Data Slave product version: 0 0
09:46:29.033753 B407F0220 Read-Ack Slave product version: 2 32
09:46:29.938600 T807F0000 Read-Data Slave product version: 0 0
09:46:30.084815 B407F0220 Read-Ack Slave product version: 2 32
After a few more minutes I see:
09:50:06.396748 T807F0000 Read-Data Slave product version: 0 0
09:50:06.503400 B407F0220 Read-Ack Slave product version: 2 32
09:50:06.938693 T000A0000 Read-Data Number of TSPs: 0
09:50:07.066187 BF00A0000 Unk-DataId Number of TSPs: 0
09:50:07.986441 T000A0000 Read-Data Number of TSPs: 0
09:50:08.120937 BF00A0000 Unk-DataId Number of TSPs: 0
09:50:08.524155 T000A0000 Read-Data Number of TSPs: 0
09:50:08.682916 BF00A0000 Unk-DataId Number of TSPs: 0
09:50:09.063980 T000A0000 Read-Data Number of TSPs: 0
09:50:09.124746 R00060000 Read-Data Remote parameter flags: 00000000 00000000
09:50:09.242024 B40060301 Read-Ack Remote parameter flags: 00000011 00000001
- DHW setpoint transfer: enabled (1)
- max CH setpoint transfer: enabled (1)
- DHW setpoint: read/write (1)
- max CH setpoint: read-only (0)
09:50:09.274176 AF00A0000 Unk-DataId Number of TSPs: 0
09:50:10.109788 T000A0000 Read-Data Number of TSPs: 0
09:50:10.175762 R00300000 Read-Data DHW setpoint boundaries: 0 0
09:50:10.325221 BC0303C1E Read-Ack DHW setpoint boundaries: 60 30
09:50:10.330717 AF00A0000 Unk-DataId Number of TSPs: 0
09:50:11.153968 T000A0000 Read-Data Number of TSPs: 0
09:50:11.242962 R00740000 Read-Data Burner starts: 0
09:50:11.426805 BC0740875 Read-Ack Burner starts: 2165
09:50:11.432427 AF00A0000 Unk-DataId Number of TSPs: 0
09:50:12.199741 T000A0000 Read-Data Number of TSPs: 0
09:50:12.310699 R00770000 Read-Data DHW burner starts: 0
09:50:12.527649 BC07701B5 Read-Ack DHW burner starts: 437
09:50:12.533623 AF00A0000 Unk-DataId Number of TSPs: 0
09:50:13.246349 T000A0000 Read-Data Number of TSPs: 0
09:50:13.378159 R00780000 Read-Data Burner operation hours: 0
09:50:13.462175 BC07800A9 Read-Ack Burner operation hours: 169
09:50:13.467990 AF00A0000 Unk-DataId Number of TSPs: 0
09:50:14.292885 T000A0000 Read-Data Number of TSPs: 0
09:50:14.379555 R007B0000 Read-Data DHW burner operation hours: 0
09:50:14.545935 B407B0002 Read-Ack DHW burner operation hours: 2
09:50:14.551651 AF00A0000 Unk-DataId Number of TSPs: 0
09:50:14.833255 T000C0000 Read-Data Size of fault buffer: 0
09:50:14.946266 BF00C0000 Unk-DataId Size of fault buffer: 0
09:50:15.371904 T000C0000 Read-Data Size of fault buffer: 0
09:50:15.506137 BF00C0000 Unk-DataId Size of fault buffer: 0
09:50:15.912893 T000C0000 Read-Data Size of fault buffer: 0
09:50:16.067180 BF00C0000 Unk-DataId Size of fault buffer: 0
09:50:16.450194 T00030000 Read-Data Slave configuration: 00000000 0
09:50:16.581216 B40034183 Read-Ack Slave configuration: 01000001 131
- DHW: present (1)
- Control type: modulating (0)
- Cooling: not supported (0)
- DHW: instantaneous (0)
- Master pump control: allowed (0)
- CH2: not present (0)
- Remote water filling: not available (1)
- Heat/cool mode control: heat (0)
After that is looks more normal, temperatures get exchanged etc.
Is this normal ? Is there a way to reduce the minutes that are apparently needed to get communication going ?
Paul
