OTGW with Atag One thermostat and Atag I36C boiler
Posted: Sat Mar 24, 2018 3:16 pm
I hooked up an OTGW (with esp8266) from Nodo shop to my Atag boiler and Atag One thermostat. In gateway mode it is working as it is supposed to. However in monitor mode it stops working with lots of errors 3. Also in gateway mode after a few hours my thermostat looses connection with the boiler without restoring the connection (and no error messages in otmonitor). I think it might be a timing problem. I did some testing:
What could be the cause of my lost connections?
1. LED test
2. Bit timing thermostat
3. Bit timing boiler
4. Delay symmetry
5. Voltage levels
6. Idle times
The outcome of test number 2 seems to be ok.
The outcome of test number 3 is not.
Enter test number: 3
60402,1036,4080,1040,4081,1040,4081,1041,4079,1041,4081,1041,4080,1040,4081,1041,4080,1041,4080,1041,4080,1041,4080,1041,4080,1041,4080,1041,4080,1040,4080,1041,4080,1041,4081,1040,4080,1041,4080,1040,4081,1041,4080,1041,4079,1041,4080,1041,4080,1041,4080,1041,4080,1040,4081,1040,4081,1040,4081,1041,4079,1040,4081,1041,4080,1040,4081,1041,4080,1040,4081,1040,4081,1040,4081,1040,4080,1041,4080,1050.
Error 03
1040,4081,1040,4081,1040,4080,1040,4082,1040,4080,1040,4081,1040,4081,1041,4080,1040,4081,1040,4081,1040,4081,1041,4081,1039,4081,1040,4081,1040,4081,1040,4081,1040,4081,1039,4081,1041,4080,1040,4081,1040,4081,1040,4080,1041,4081,1039,4082,1040,4080,1040,4081,1040,4081,1040,4081,1040,4080,1050,4071,1040,4081,1040,4081,1040,4081,1040,4081,1040,4081,1040,4081,1040,4081,1040,4080,1041,4080,1041,4081.
Error 03
1039,4082,1040,4081,1040,4080,1040,4081,1040,4081,1040,4081,1039,4081,1040,4081,1039,4082,1039,4081,1040,4081,1040,4081,1040,4081,1040,4080,1040,4081,1040,4082,1039,9682,493,2537,998,6072,998,5567,493,517,493,1527,493,517,493,1022,998.
Error 03
530,1031,1042,476,549,475,548,1007,508,516,508,526,498,516,1042,1040,474,534,1025,1006,1042,476,549,475,549,1006,508,516,508,517,507,516,508,517,507,517,508,517,507,516,509,516,508,524,500,576,448,516,508,516,508,516,580,445,508,517,1019.
70970000 Unk-DataId Message ID 151: 0
59.
494,516,494,2536,75,9016,493,517,493,517,493,517,493,517,493,517,494,516,494,516,494,516,494.
Error 03
529,1032,1042,1007,507,517,507,517,507,517,517,507,564,460,1042,1007,566,458,507,517,508,516,508,516,508,516,508,517,507,517,507,517,508,516,1042,478,547,475,549,1006,1042,476,548,476,548,1007,553,471,508,516,507,517,1113,406,548,470,531,35106,75.
Error 03
59.
59,951,75,936,75,935,75,936,75,935,75,936,75,935,75,936,75,1440,75.
Error 01
59.
59,1457,75,935,75,936,75,935,75,936,81,930,513,1002,75,1441,75,936,75,935,75,936,75,935,75,936,75,936,509,501,75,936,75,935,75,936,75,935,75,936,75,935,75,936,75,936,505,505,75,936,504,506,75,936,503,507,75,936,75,1440,75,31969,538,1024,1042,1006,507,517,508,517,507,517,507,517,508,540,1018,1007,507,614.
Error 01
59.
59,952,75,935,75,936,502,508,75,935,75,936,75,935,75,936,75,935,75,935,75,936,75,935,75,1441,75,935,75,1441,75,935,75,936,75,935,75,936,495,515,75,935,75,936,75,935,75,936,75,935,75,935,75,936,75,935,75,936,491,1024,75,47042,529,1031,1043,1006,507,517,507,517,507,517,508,525,499,517,507,517,507,517.
Error 01
59.
59,952,75,935,75,936,75,935,75,936,490,520,75,935,75,936,75,935,75,936,75,935,75,1441,75,935,75,1441,75,936,486,524,75,935,75,936,75,935,75,935,75,935,75,935,75,935,75,935,75,935,75,935,75,936,485,525,75,935,75,1440,75,59574,530,500,549,475,549,1007,507,516,508,517,507,517,508,516,508,516,565,459.
Error 01
59.
59,951,75,935,75,936,75,935,75,935,75,935,75,1440,75,1440,75,936,485,525,75,935,75,935,75,1440,75,1440,75,935,75,935,75,935,75,935,75,935,75,935,75,935,75,935,75,936,485,525,75,935,75,935,75,935,75,935,75,1440,75,10663,530,501,548,476,548,1007,507,517,508,516,508,525,499,517,507,517,1080,969,507,517.
Error 01
59.
59,1456,75,936,75,935,75,935,75,935,75,935,75,935,75,935,75,936,485,525,485,525,485,525,75,935,75,935,75,935,75,935,75,935,75,935,75,935,75,935,75,1440,75,1440,75,935,75,935,75,936,485,525,485,525,75,935,75,935,75,1440,75,21965,529,501,548,476,549,1006,508,516,508,516,508,516,508,517,507,517,555,469.
Error 01
59.
59,1457,75,1440,75,1441,75,935,75,935,75,935,75,935,75,935,75,935,75,936,485,525,75,1439,75,1441,75,935,75,935,75,935,75,935,75,935,75,935,75,1440,75,1440,75,1440,75,935,75,1440,75,935,75,935,75,1440,75,37575,528,1032,1042,1007,1042,1007,506,518,507,527,497,517,507,526,499,589,434,519,506,517,507,519,505,518.
Error 01
495,1066,1007,1042,1007,1042,472,551,473,552,473,551,532,492,473,551,472,552,533,491,473,551,474,551,1007,1042,473,550,473,551,473,552,473,551,473,551,473,552,472,552,1007,1041,473,551,1008,510,514,1041,473,551,474,550,474,629,906.
50020130 Write-Ack Master configuration: 00000001 48
494,1067,1006,1042,472,552,472,553,472,552,472,591,433,552,472,552,1052,466,513,511,514,1041,472,552,1007,511,514,1041,472,552,473,552,472,553,471,552,473,551,473,551,473,552,472,552,473,559,465,601,423,552,472,552,472,552,498,526,473,553,983.
40730000 Read-Ack OEM diagnostic code: 0
481,576,473,522,503,1041,1007,1042,471,553,472,552,472,552,529,495,472,553,472,552,568,456,472,552,473,552,472,552,1007,1042,472,552,472,553,471,553,472,551,473,552,472,552,472,552,472,553,472,552,472,552,475,550,532,491,473,552,472,552,474,551,984.
D0010000 Write-Ack Control setpoint: 0.00
492,1068,1006,1043,1005,1045,469,553,472,577,447,552,472,553,471,583,441,553,575,449,1007,511,513,511,513,1042,472,552,1006,512,513,1042,471,564,995,1043,471,553,471,553,471,553,472,613,411,552,473,552,472,552,488,536,472,554,983.
500E6400 Write-Ack Maximum relative modulation level: 100.00
Enter test number: 4
OK1A high-to-low: 14us
OK1A low-to-high: 25us
OK1B high-to-low: 6us
OK1B low-to-high: 5us
Enter test number: 5
Thermostat: 0.88, 2.27
Boiler: 0.00, 4.14
Reference: 1.22
