Opentherm Gateway and HomeAssistant
davey400
Post by davey400 »
I am new to the Opentherm Gateway; I just installed it.
My OTGW uses a wifi module to connect it to my network; the web interface is fully accessible.
I am able to connect to the OTGW using Opentherm monitor.
However: I do not have any idea how to add the OTGW to Home Assistant.
The official integration documentation is not very clear on this: https://www.home-assistant.io/integrati ... ntherm_gw/
It points me to https://pythonhosted.org/pyserial/url_handlers.html which does not seem to make much sense, since I can access the OTGW directly through the network.
Any help here would be appreciated.
Best Regards,
Dave
Re: Opentherm Gateway and HomeAssistant
Without any knowledge of Home Assistant and very little knowledge of python, the provided links suggest to me that you should use socket://192.168.1.13:6638 as the path, assuming you use 192.168.1.13 and 6638 as the remote host and remote port settings when connecting using OTmonitor.
Note: This way you can only connect either Home Assistant or OTmonitor to the OTGW, but not both at the same time.
davey400
Post by davey400 »
Great, thanks!
I seem to have another issue; the OTGW seems to cause reboots off the ESPEasy/NodeMCU every few seconds.
Working on that right now.
