Opentherm gateway plugin for Vera?
Postby MarQuez » Sun Dec 30, 2012 2:35 pm
I also posted this question already in the general topic of the gateway but maybe this was overlooked.
Is there someone who made (or still building) a plugin to use the OTG with Vera?
If not, is someone willing to help creating this plugin, because at the moment i have zero experience with creating a plugin for vera. I just started reading through the documentation for creating a plugin and looking into the basics.
Thanks
MarQuez
Re: Opentherm gateway plugin for Vera?
Postby flue » Sun Jan 06, 2013 12:54 am
I'm planning to build this plugin. I'm waiting for my LAN/WIFI converter. After this i will build a plugin which will be connected to this converter.
Because Vera always communicated thru a ser2net converter i expect a serial or USB interface will work fine also. I'll keep you updated.
Buy opentherm gateway PCB's, kits or assembled PCB's: http://www.opentherm-gateway.com/
Special discount for this forum using the following coupon code: domoticaforum.eu
flue
Postby MarQuez » Thu Jan 10, 2013 2:04 pm
That would be very nice!
Let us know when you have something ready to test.
For now i have i the gateway connected to Domotiga, but this is not ideal because i need to switch between apps to use the gateway.
MarQuez
Postby MarQuez » Mon Jan 28, 2013 11:45 pm
Flue,
You already started with building the plugin yet? I don't want to put pressure on it but was curious if some progress has been made.
If I maybe can help with something just let me know.
MarQuez
Postby flue » Tue Jan 29, 2013 5:34 pm
Marquez,
I'm very busy with helping every out with the opentherm gateway kit. In the spare time i have left i'm looking up all information about building the plugin. I'm experienced with Lua, this is not the problem. I've got some problem getting the right information how to build a thermostat plugin, using the existing templates which are compatible with android/iphone clients.
Lots of research. If anyone can help me in the right direction (besided micasaverde wiki and other projects source) this would be great.
flue
Postby phoenixb » Wed Aug 28, 2013 3:45 pm
Is there any update arround this plugin?
DJ
__________________
phoenixb
Postby nlrb » Sat Sep 28, 2013 1:55 pm
A plugin is now available on the MCV forum: OpenTherm Gateway plugin.
nlrb
Postby nlrb » Sat Oct 05, 2013 9:51 pm
Information & plugin code can now be found via the mios Wiki: http://code.mios.com/trac/mios_opentherm-gateway.
nlrb
