Help wanted troubleshooting newly assembled OTG.
Postby The Lord » Tue Feb 19, 2013 11:07 pm
Yesterday I assembled an OTG board purchased from http://www.opentherm-gateway.com.
Now there seems to be a problem with the PSU part. At the 7805 VCC pin I do measure slightly less then 3V DC.
At secondary pins of transformer I do measure roughly 3V AC. Also the transformer turns warm within seconds.
With the transformer taken from the board I measure about 20V DC open ended at the secondary side.
My first guess was I overheated one or more of the diodes D1-D4 during soldering. I've just replaced these, but the situation remains as before.
I'm wondering whether the 3V AC is a result of the transformer's short circuit protection. Can anyone either confirm or deny?
If it is not the short circuit protection I guess the most likely fault would be the transformer itself?
If it is the short circuit protection what would be the next step in troubleshooting? The zenerdiodes?
BTW:
- No caps blew.
- There are no signs of magic smoke.
The Lord
Re: Help wanted troubleshooting newly assembled OTG.
Postby flue » Thu Feb 21, 2013 12:06 am
Are you sure all components are mounted correctly and on the right position? Most of these problems are caused by this.
If you expect there is a malfunction of some part, please contact me on the contact form of the website. I can send you replacement parts for free. I can also offer you to take a look at the non-working gateway.
Maybe Schelte can clear something up. If not, you've got my offer.
Buy opentherm gateway PCB's, kits or assembled PCB's: http://www.opentherm-gateway.com/
Special discount for this forum using the following coupon code: domoticaforum.eu
flue
Postby hvxl » Thu Feb 21, 2013 5:45 pm
Indeed, sounds like a wrong transistor or something like that. Note that Q4 is the NPN transistor (BC548) and all others are PNP (BC558).
