I have connected the OTG at my home network trough the TP-Link703N.
The monitor can connect to it and it all works good.
Now I would like to connect to the OTG using Telnet.
I have read about commands like 'PS=1'.
But I can't find out what I have to do to send commands.
I have tried Telnet, Putty and WINScp.
Is there something that I miss??
André
How to?
Re: How to?
You said you can telnet to it. What happens when you type PS=1 (+ enter)?
Kind Regards,
Greg.
Greg.
Re: How to?
Hello Greg,
If I telnet without a portnumber it cannot make a connection.
If I use the ip and portnumber I only see 'SSH-Dropbear_2011.54'
After typing PS=1 + enter nothing is happening.
No response, en the monitor also keeps on showing the normal messages
André
André
Re: How to?
Greg,
Its working!!
What I did? To be true?
I don't know.
I gues it had to do someting with the TP-Link wr703n. I have made some changes tot ser2net.config. After some test, I have set it back to it's original. And since that moment PS=1 is working. I think there was a problem with sending de data to /dev/ttyUSB0.
Now I can start thinking about the way I want to work with the data.
Jumping in domotica?
Or trying to make a own way to get the data on my smartphone.
Thanks for the help so far!
Its working!!
I don't know.
